Supported displays
For a general overview about all the different display interfaces, see our Display Interface page.
The Toradex ARM Computer Modules supports almost every active and passive LCD without any glue logic. You can attach TFT (active) and STN (passive) displays glueless (without any CPLD) to the Colibri display interface.
EDT Unified Interface Display
The Unified TFT Interface form EDT allows you to use several different displays with exact the same connector on the base board. Toradex provides 2 EDT displays in the webshop but there are even more available form 3rd parties. Here the complete list:
Size Part Number Touch Resolution
3.5" ET035080DM6 No QVGA 320*240
3.5" ET035080DH6 resistive QVGA 320*240
4.3" ET043080DM6 No WQVGA 480*272
4.3" ET043080DH6 resistive WQVGA 480*272
5.0" ET050080DM6 No WVGA 800*480
5.0" ET050080DH6 resistive WVGA 800*480
5.7" ET057080DM6 No QVGA 320*240
5.7" ET057080DH6 resistive QVGA 320*240
7.0" ET070080DM6 No WVGA 800*480
7.0" ET070080DH6 resistive WVGA 800*480
Please note we have not tested all these displays.
Tested Displays
The following displays have been used by Toradex customers:
RGB & LVDS Displays
Size Resolution Type Manufacturer Comment
3.5" 240x320 TD035STED4 Toppoly
3.5" 480x640 TD035STEE1 Toppoly
6.4" 640x480 LB064V02-A1 Philips
15.4" 1024x768 G150XG01 AUO LVDS converter needed
10.4" 800x600 G104SN03 AUO LVDS converter needed
3.7" 480x640 LS037V7DW01 Sharp with touch
5.7" 320x240 AM-320240N1TMCW-00H Ampire
10.4" 800x480 AM800480E3TMQW-00H Ampire
4.3" 640x480 AM640480ATMCW00 Ampire
7" 480x272 TFT-GG1N4014DTSW-W-TP-Ev1.1 Truly LED
7" 800x480 TFT-G800480DTSW-15W-E(7D)v1.2 Truly LED
12.1" 800x600 LQ121S1DG11 Sharp
5.5" 320x240 nl3224bc35-22-0065 NEC Sunlight Readable
6.5" 640x480 nl6448bc20-20-0126 NEC Sunlight Readable
10.4" 640x480 nl6448bc33-64c-0157 NEC Sunlight Readable
7" 1280x800 HSD070PWW1 HannStar LVDS converter needed
10.1" 1024x600 B101AW03 V.1 HannStar LVDS converter needed
10.1" 1280x800 HSD101PWW1 HannStar LVDS converter needed
10.1" 1280x800 HSD101PWW1-A HannStar LVDS converter needed
8.4" 800x600 TM084SDHG01 Tianma LVDS converter needed
15.6" 1366x768 B156XW04 V.5 AU Optronics LVDS converter needed
15.6" 1920x1080 N156HGE-LG1 CHIMEI INNOLUX LVDS converter needed
Toradex carrier boards also provide a connector for the Unified TFT Display interface which gives the possibility to test a lot of different displays without the need of an adapter.
For other displays where adaptation is required, we have done some examples as mentioned below: (CAE data is freely available)
Displays with Capacitive Touch
Some of the capacitive touch displays which our customers have tested.
Size Resolution Type Manufacturer Touch Interface
10" 1024x600 FA1012 Lilliput USB HID
9" 1280x800 ODROID-VU HARDKERNEL USB HID
7" 1280x800 7" HDMI Display with black panel Chalkboard Electronics USB HID
7" 1280x800 7" HDMI Display open frame Chalkboard Electronics USB HID
10" 1366x768 10" HDMI Display Chalkboard Electronics USB HID
14" 1366x768 14" HDMI Display Chalkboard Electronics USB HID
15.6" 1366x768 15.6" HDMI Display Chalkboard Electronics USB HID
Generic USB HID Driver can be downloaded from here.
Size Resolution Type Manufacturer Touch Interface Software Driver & Hardware Adaptation
5" 480x272 ER-TFT050-2 EAST RISING I2C (GSL1680) Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
7" 800x480 ER-TFT070-4 EAST RISING I2C (FT5206) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example
4.3" 480x272 FT800CB-HY43B HAOYU ELECTRONICS SPI (FT800) Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
5.0" 480x272 FT800CB-HY50B HAOYU ELECTRONICS SPI (FT800) Driver adaptation is required, display can be interfaced using Generic RGB Display Adapter Board Example
7.0" 800x480 HY070CTP HAOYU ELECTRONICS I2C (FT5206) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example with small change, please refer NOTE1.
10.1" 1024x600 HY101CTP HAOYU ELECTRONICS I2C (FT5406) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example with small change, please refer NOTE1.
4.3" 480x272 NHD-4.3-480272EF-ATXL#-CTP New Heaven Display I2C (FT5306) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
5.0" 800x480 NHD-5.0-800480TF-ATXL#-CTP New Heaven Display I2C (FT5306) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
7.0" 800x480 NHD-7.0-800480EF-ATXL#-CTP New Heaven Display I2C (FT5406) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
7.0" 800x480 NHD-7.0-800480EF-ATXV#-CTP New Heaven Display I2C (FT5406) Driver is available, display can be interfaced using Generic RGB Display Adapter Board Example, small change is required to be done, please refer NOTE2.
NOTE1: LED driver side, disconnect Pin 1, 2 of lcd from led driver circuit and give 5V input as led driver is integrated with the lcd and connect pwm signal for backlight dimming control to Pin 35 of lcd.
NOTE2: Remove resistors(R98, R99, R100, R101) on Pin 37, 38, 39, 40 and using jumper wire connect these to I2C_SCL_B, I2C_SDA_B, TOUCH_INT_B and TOUCH_RESET_B signals of X8.
Display Manufacturers
Some possible display suppliers:
Please contact us at support.arm [at] toradex [dot] com for any feedback or further support.
