Apalis iMX6
The Apalis iMX6 is a Toradex System on Module based on the NXP iMX6 SoC, and a member of the Apalis Family.
This page provides hardware design resources, documentation, revision history, erratas, compatibility details, and getting started guides for developers working with the Apalis iMX6 module.
Getting Started
Recommendation for the first-time order
Quickstart Guide
Check out our guide for detailed instructions on how to get your board up and running with Torizon:
Having trouble?
Product Features
Hardware Features
Compatible Products
Block Diagram
Apalis iMX6
Pinout Evaluation & Planning
Power Consumption
Additional Information
Software modifications needed in order to silence the (non-fatal) errors that appear on these modules.
Product Documents
Datasheets
Apalis iMX6 V1.1
Design Resources
Toradex provides two different 3D models for Apalis Systems on Module:
Generic 3D Mechanical Models: This model has the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
- Specific 3D Mechanical Models: These models are simplified models of the respective Apalis module. They contain only the PCB and the CPU and are intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different.
The generic Apalis 3D model contains the PCB and the maximum component height on top and bottom of modules from the Apalis Module Family. This model should be used to test the mechanical fit, ensuring that the mechanical design fits all current Apalis modules as well as future releases.
The Apalis iMX6 3D model is simplified and contains only the PCB and the CPU. It is intended to be used for heat spreader or heat sink designs. The CPU height is a typical value. Due to production tolerances, the actual height of the assembled component can be different. Please use the Generic 3D Mechanical Models with the maximum component height for testing the mechanical fit. This ensures the mechanical design fits all current Apalis modules as well as future releases.
Hardware Ecosystem
Carrier Boards
Off-the-shelf Carrier Boards
Learn more on the Apalis Product Family Specification.
Custom Carrier Board Design
Find free reference designs, schematics, 3D designs, and tools to build your carrier board easily in the link below:
Accessories & Add-ons
Accessories
- EDT Display
- Capacitive Touch Display 7" Parallel
- Resistive Touch Display 7" Parallel
- Capacitive Touch Display 10.1" LVDS
- Carrier Board Accessory Kit
- Apalis Heatsink Type 1 & 3
- LM816 USB WiFi
- Analogue Camera Adapter
- Apalis iMX6 Mezzanine
Check other options and compatibility information on the add-ons product pages.
Software Ecosystem
Torizon OS - open source, easy to use industrial Linux operating system
Yocto Project Reference Images - reference images for Yocto Project, a great starting point for customized Linux images
Windows Embedded Compact (EOL)
Development Resources
Connecting to the Board
Revision History
Product Number (PID8) Format
| Field | Description |
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0028 Apalis iMX6Q 2GB IT (WinEC)
| Product # | Product Description | Changes from Previous Version | Release Date | Pre-Installed Software | Related Documents |
00281000 | Apalis iMX6Q 1GB IT V1.0A | Initial Release | 2014-04-30 | Sample Product, No PCN | |
00281100 | Apalis iMX6Q 2GB IT V1.1A |
| 2014-12-31 | PCN Apalis iMX6Q 2GB IT V1.1A 2015-01-08 | |
00281101 | Apalis iMX6Q 2GB IT V1.1B |
| 2015-12-25 | PCN Apalis iMX6Q 2GB IT V1.1B 2017-04-19 | |
00281102 | Apalis iMX6Q 2GB IT V1.1C |
| 2017-05-30 | TPIN Apalis iMX6
V1.1Z 2021-04-15 PCN 00281102 Apalis iMX6Q 2GB IT V1.1C | |
00281103 | Apalis iMX6Q 2GB IT V1.1D |
| Q4, 2021 | ToradexEasyInstaller_5.3 | EOL PCN Apalis iMX6Q 2GB IT |
00281125 | Apalis iMX6Q 2GB IT V1.1Z |
| Q2, 2020 | ToradexEasyInstaller_1.8-20181019 | Software Adjustments for Colibri / Apalis iMX6 V1.1Z ModulesTPIN Apalis iMX6
V1.1Z 2021-04-15 PCN 00281125 Apalis iMX6Q 2GB IT V1.1Z |
00281124 | Apalis iMX6Q 2GB IT V1.1Y |
| Q4, 2021 | ToradexEasyInstaller_5.3 | Software Adjustments for Colibri / Apalis iMX6 V1.1Z and V1.1Y Modules PCN Apalis iMX6 Temporary versions EOL 2024-03-14 |
0027 Apalis iMX6Q 1GB (WinEC)
00271000 | Apalis iMX6Q 1GB V1.0A | Initial Release | 2014-04-30 | Sample Product, No PCN | |
00271001 | Apalis iMX6Q 1GB V1.0B |
| 2014-06-18 | Sample Product, No PCN | |
| 00271100 | Apalis iMX6Q 1GB V1.1A |
| 2014-12-31 | PCN Apalis iMX6Q 1GB
V1.1A 2017-05-02 | |
| 00271101 | Apalis iMX6Q 1GB V1.1B |
V1.1Z 2021-04-15 PCN Apalis iMX6Q 1GB V1.1B 2021-12-13 | |
| 00271102 | Apalis iMX6Q 1GB V1.1C |
| Q4, 2021 | ToradexEasyInstaller_5.3 | PCN Apalis iMX6Q 1GB V1.1C
2021-12-13 |
| 00271103 | Apalis iMX6Q 1GB V1.1D |
| Q1, 2022 | ToradexEasyInstaller_5.3 | EOL PCN Apalis iMX6Q 1GB |
00271125 | Apalis iMX6Q 1GB V1.1Z |
V1.1Z 2021-04-15 PCN Apalis iMX6 V1.1Z 2021-12-13 PCN Apalis iMX6 Temporary versions EOL 2024-03-14 |
00271124 | Apalis iMX6Q 1GB V1.1Y |
| Q1, 2022 | ToradexEasyInstaller_5.3 | Software Adjustments for Colibri / Apalis iMX6 V1.1Z and V1.1Y Modules PCN Apalis iMX6 Temporary versions EOL 2024-03-14 |
0035 Apalis iMX6D 1GB IT (WinEC)
00351100 | Apalis iMX6D 1GB IT V1.1A | Initial Release | 2016-07-20 | PCN Apalis iMX6D 1GB IT V1.1A | |
00351101 | Apalis iMX6D 1GB IT V1.1B |
| 2017-06-28 | ToradexEasyInstaller_1.8-20181019 | PCN 00351101 Apalis iMX6D 1GB
IT V1.1B |
00351102 | Apalis iMX6D 1GB IT V1.1C |
| Q4, 2021 | ToradexEasyInstaller_5.3 | TPIN Apalis iMX6D
1GB IT V1.1Y 2022-04-07 EOL PCN Apalis iMX6D 1GB IT |
00351124 | Apalis iMX6D 1GB IT V1.1Y |
0029 Apalis iMX6D 512MB (WinEC)
00291000 | Apalis iMX6D 512MB V1.0A |
00291100 | Apalis iMX6D 512MB V1.1A |
| 2014-12-31 | PCN Apalis iMX6D 512MB V1.1A 2017-04-12 | |
00291101 | Apalis iMX6D 512MB V1.1B |
| 2017-06-30 | ToradexEasyInstaller_1.8-20181019 | TPIN Apalis iMX6
V1.1Z 2021-04-15 PCN Apalis iMX6D 512MB V1.1B 2021-12-13 |
00291102 | Apalis iMX6D 512MB V1.1C |
| Q1 2022 | ToradexEasyInstaller_5.3 | EOL PCN Apalis iMX6D 512MB |
0082 Apalis iMX6D 512MB
| Product # | Product Description | Changes from Previous Version | Release Date | Pre-Installed Software | PCN Document |
00821100 | Apalis iMX6D 512MB V1.1A | Initial Version | 2024-04-01 | ToradexEasyInstaller_5.7.5 | New Product Configurations Without WinEC |
0083 Apalis iMX6Q 1GB
00831100 | Apalis iMX6Q 1GB V1.1A | Initial Version | 2024-04-01 | ToradexEasyInstaller_5.7.5 | New Product Configurations Without WinEC |
0084 Apalis iMX6D 1GB IT
00841100 | Apalis iMX6D 1GB IT V1.1A | Initial Version | 2024-04-01 | ToradexEasyInstaller_5.7.5 | New Product Configurations Without WinEC |
0085 Apalis iMX6Q 2GB IT
00851100 | Apalis iMX6Q 2GB IT V1.1A | Initial Version | 2024-04-01 | ToradexEasyInstaller_5.7.5 | New Product Configurations Without WinEC |
Errata/Known issues
SoC Errata Document
- Filter by
Errataon the: i.MX 6Dual/6Quad Documentation on the NXP website.
