Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta1 (Release date: 2016-05-17)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M03
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M03
- WEC 2013 Updates: Installed Updates until 2016M03
To Upgrade to 2.0 beta 1 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1518FixedSD Interface disapears after suspend - resume cycleColibri T20SDIO/SD/MMCCE6, WEC7
Description: If you use -1 for the card detect pin (non removable card) the card will disappear after a suspend - resume cycle.
Workaround: Set a any GPIO pin as card detect pin and toggle it manually after resuming using the GPIO library.
