Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
Not Planned
WC-1416Known IssueSystem time does not behave correctly when DST is not activated and SoftRTC is disabledColibri T20, Colibri T30, Apalis T30RTCWEC7, WEC2013
Description: When DST is not active and SoftRTC is disabled (default on Tegra Modules is Enabled) the current date/time reported by the system is not precise and lags few minutes per hours during runtime. This is a bug in the MS code.
Workaround: If you have issues with DST not running correctly there are two ways to fix this. 1. Enable SoftRTC. 2. Go into registry under HKLM\Time Zones and select your timezone. There is a subkey "Dynamic DST" with entries for each year. To fix it create a new entry for year when you have issues and copy value from previous year.
