Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
Clear Filter
V2.0beta3 (Release date: 2016-11-04)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M09
- WEC 2013 Updates: Installed Updates until 2016M09
To Upgrade to 2.0 beta 3 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1799New FeatureLVDS on Apalis T30 not supportedApalis T30LVDSCE6, WEC7
Description: Add possibility to configure Apalis T30 LVDS controller. Check this devleoper page for the new keys added to the registry: https://developer1.toradex.com/knowledge-base/display-driver-registry-settings#Settings_for_Colibri_Txx_and_Apalis_Txx_Modules_Only
Workaround: Use the GPIO lib to manually set up the right configuration.
