Toradex Software Versioning Convention
Toradex provides several software items such as BSPs or images for Toradex Colibri and Apalis system on modules, configuration tools, installer tools, etc. The versioning convention mentioned here will be applied to new software releases starting in April 2017.
Software Versioning
We make use of two different versioning schemes, a package version and an item version. The package version is the version showed in public, e.g. on websites, file names, roadmaps, etc. The item version gets built-in in e.g. drivers, libraries, kernels, or other items. The item version is usually visible when running the software or doing version queries only. Example: We build a BSP with item version 1.2.4. We call the download package 1.2b4 to indicate it's a beta version. If we declare this version stable, the item version stays at 1.2.4 but the package version will be changed to 1.2. This allows us to declare software stable after some time w/o rebuilding it just to update the item version.
Software Package Version
Format
Major.Minor[bx[-nightly]]-YYYYMMDD
Type Description
Major Major version number which changes if major changes were done. This includes major incompatibilities with earlier versions. Can start at 0. Leading 0 are blanked (except for “0”).
Minor Minor version number which changes after a stable release. Can start at 0, Leading 0 are blanked (except for “0”).
bx Optional identifier. Used to identify beta releases. b is a constant letter and x is the ascending beta number starting from 1. Leading 0 are blanked.
-nightly Optional identifier. Specifies builds which were automatically done overnight.
-YYYYMMDD Mandatory date identifier.
Examples
2.5b1-nightly-20170306
2.5-20170307
2.5b1-20170301
Software Item Version
Format
Major.Minor.Patch[-YYYYMMDD]
Type Description
Patch Patch version number which changes during stabilizing a version. It can be a manually increased version number, or can also be a versioning system number, e.g. SVN revision number. Starts with 1. Leading 0 are blanked.
-YYYYMMDD Optional date identifier.
Examples
2.5.1
2.5.1-20170328
1.9.2394
