Embedded Linux Support Strategy
This article presents information about the Embedded Linux Support on Toradex SoMs. It covers the lifecycle, releases, and software alerts adopted by Toradex. It is valid for both Toradex's Torizon OS and Toradex BSP Layers and Reference Images for Yocto Project. To learn more about them, check the Embedded Linux Options for Toradex SoMs article.
For BSP 3.X and 2.X please see Toradex Software Versioning Convention (Legacy).
Upstream Strategy​
Starting with BSP 6.0, all our supported 32-bit i.MX-based SoMs (i.e. NXP i.MX6, i.MX6 ULL, and i.MX7 based modules) come to life with the mainline/upstream Linux kernel, for example, mainline kernel v6.0 for BSP 6.0.
Downstream-based​
The i.MX95, i.MX 8, i.MX 8X, i.MX 8M Mini and i.MX 8M Plus based modules use an NXP downstream-based kernel even for versions 6.0 and later of the BSP. Some of Verdin SoMs based on NXP SoCs (Verdin iMX8M Mini and Verdin iMX8M Plus) also have upstream-based BSP builds as an alternative to the downstream-based builds. The upstream build should be preferred if the supported features match your requirements.
The TI-based modules use a TI downstream-based kernel, with support available on versions 6.4 and later of the BSP for AM623 and AM625 and on 7.0 and later for AM69/TDA4.
Check the specific versions of U-Boot and Linux Kernel in the Release Matrix Article.
For more information, please check our Blog: Upstream First - Toradex Mainline Kernel Support is a Reality.
Embedded Linux Lifecycle and Releases​
Toradex provides frequent releases for the Embedded Linux Options, including Torizon OS and BSP Layers for Yocto. The releases align with the lifecycle of key building blocks of our Linux offerings: Yocto Project and Linux Kernel.
Check the lifecycle of our BSP Layers for Yocto in the table below - Note that our Torizon OS is built on top of our BSP Layers and their support status are aligned:
VersionStateInitial Release DateProjected EOLExtended EOLRelease Periodicity
Torizon/BSP 7ActiveOctober 20242028Contact usQuarterly
Torizon/BSP 6MaintenanceOctober 20222026Contact usQuarterly
Torizon/BSP 5EOLOctober 20202024Contact usNo Releases
BSP 3EOLJune 20192023Contact usNo Releases
BSP 2.8EOLDecember 20172021Contact usNo Releases
During a 3-state lifecycle - active, maintenance and EOL (End-of-Life) - we deliver a series of releases. The Toradex Embedded Linux release process follows the Major, Minor and Patch versioning scheme, known as semantic versioning. No breaking changes are supposed to happen between releases with the same major version number. The transition within the major version is expected to be low-effort and low-risk.
The graphic below demonstrates how we transition between states. It does not represent a commitment to dates or future software releases.
Active​
This is when we develop the most up-to-date software releases - the default ones to use. During the active state, we deliver:
  • Quarterly releases, meant to be used in production
  • Monthly and Nightly pre-releases, meant for development and evaluation
Maintenance​
While migrating to the latest version isn't feasible, you can continue using your current version as long as it's still in maintenance state. During the maintenance state, we deliver periodic Maintenance Releases, meant to be used in production. They provide security and bug fixes. The start of maintenance state is not fixed and depends on the maturity of the product and justified business needs.
  • To ensure Long Term Availability, Toradex fully supports and validates the new hardware versions and does any necessary software backports to support their hardware changes, such as changes caused by components going end-of-life.
  • Toradex provides updates for the software components. They consist of fixed versions of the U-Boot boot loader, Linux kernel and OpenEmbedded/Yocto Project components used on a specific Toradex release.
    • Those updates are provided as long as the respective version of the component still receives updates. They are typically maintained for 2 - 3 years and are subject to each component's release plan.
    • Toradex uses Longterm/Stable Linux kernels for its releases whenever possible. This ensures that Toradex releases receive kernel updates for an extended period.
End-Of-Life (EOL)​
After the EOL date, no new releases are expected. It is recommended to upgrade to a version in active state. In case that's not possible, Toradex offers extended support period as a service. Contact Us to discuss your case.
Long-Term Support (LTS)​
All the releases of Toradex Embedded Linux have Long-Term Support until they reach EOL.
Supported Modules​
Check the Release Matrix to learn which modules are supported by each release.
Live Updates on Software​
You can learn the latest status and work progress on our issue tracker for each software. Also, we highly recommend that you sign up for updates on each detailed software page:
Critical software issues get announced via customer information notification emails to customers who purchased affected products.
Release Types​
Production Releases​
Quarterly Embedded Releases​
  • Typical Content: Latest feature set, bug and security fixes
  • Release Cycle: During active state, typically at the start of each Quarter, 4 times a year
  • Maintenance Duration: 3 Months after the release. During this period, we can deliver critical fixes through patch releases.
Maintenance Releases​
  • Typical Content: Feature set of the latest release during active state, plus bug and security fixes
  • Release Cycle: Typically released during maintenance state, typically at the start of each Quarter, 4 times a year.
Pre-releases​
Engineering Pre-releases​
  • Typical Content: Early silicon enablement, upstream BSP integrations, experimental features, and initial support for new kernels and hardware accelerators
  • Release Cycle: Irregular, coupled with upstream SoC vendor updates and development milestones
  • Maintenance Duration: Short-term availability with no guaranteed maintenance, updates, or continuity1
Nightly Embedded Pre-releases​
  • Typical Content: Features and fixes, made that day
  • Release Cycle: On most nights, before midnight
  • Maintenance Duration: Not maintained as it is released on most days
Monthly Embedded Pre-releases​
  • Typical Content: New Features and bug fixes
  • Release Cycle: Typically every month
  • Maintenance Duration: Not maintained. For patches, use nightly builds
Footnotes​
  1. Engineering pre-releases follow a short-term, non-supported lifecycle and are provided as-is, with no guarantee of continuous updates, maintenance, or security fixes. Breaking changes across kernel, BSP layers, and userspace are expected, and forward compatibility or upgrade paths are not guaranteed. Validation, qualification, and certification remain the customer’s responsibility. Production systems should use Toradex-supported BSP releases. ↩
