How To Load and Run Firmware on Alternative Cores (NXP)
This article describes how to load and run firmware compiled for alternative cores using the MCUXpresso SDK.
Hardware prerequisites:
- A module with Torizon OS or a Linux BSP image installed
- Access to the U-Boot console
Software prerequisites:
- A firmware binary compiled for the alternative core, as described in How To Compile Firmware for Alternative Cores (NXP) article
- This article uses the
hello_worldfirmware binary as an example
Load Firmware From U-Boot
The following procedure describes how to load the compiled firmware on the alternative cores using the ext4load command from the U-Boot terminal.
To be able to connect to U-Boot console and to the alternative core serial console, refer to the tabs below for the pinout and connection details for each module:
- i.MX 95
- i.MX 8M Plus
- i.MX 8M Mini
- i.MX 8X
- iMX 8
After connecting to the USB Debug port, the U-Boot console can be accessed through the ttyUSB3 port and the alternative core serial console can be accessed through the ttyUSB2 port.
After connecting to the USB Debug port, the U-Boot console can be accessed through the ttyUSB0 port. Note that access to the alternative core serial console requires a USB-to-TTL converter for the target module.
The table below shows the pinout for the connection with the Colibri Evaluation Board:
| USB/TTL Signal | Colibri Evaluation Board |
| RX | A40 (SODIMM_144) |
| TX | A41 (SODIMM_146) |
| GND | GND |
For more information, refer to the Colibri Evaluation Board Datasheet.
The table below shows the pinout for the connection with the Apalis Evaluation Board:
| USB/TTL Signal | Apalis Evaluation Board (M4_0) | Apalis Evaluation Board (M4_1) |
| RX | A40 (UART1_DTR) | B13 (PWM3) |
| TX | A35 (UART1_DSR) | B12 (PWM4) |
| GND | GND | GND |
For more information, refer to the Apalis Evaluation Board Datasheet.
For Torizon OS, Toradex recommends placing the firmware binary in a directory not managed by OSTree. Refer to OSTree documentation for more information.
- i.MX 95
- i.MX 8M Plus
- i.MX 8M Mini
- i.MX 8X
- iMX 8
Copy the firmware binary to the target module using an SD card, USB drive, SCP, or another suitable method.
Identify the firmware path from the U-Boot point of view using the
ext4lscommand:- Torizon OS
- Linux BSP
> ext4ls mmc 0:1> ext4ls mmc 0:2 -
Set the
load_cmdvariable according to the installed image:- Torizon OS
- Linux BSP
> setenv load_cmd "ext4load mmc 0:1"> setenv load_cmd "ext4load mmc 0:2"warningSelect the correct device and partition according to the installed image.
Set the firmware binary path.
For example, if the firmware binary is placed under
/varin a Torizon OS image, use:> setenv cm_image "/ostree/deploy/torizon/var/hello_world_cm7.bin" -
Set the Cortex-M4 instruction Tightly-Coupled Memory (TCM) size:
> setenv cm_isize 20000The
cm_isizevalue corresponds to 128 KiB. -
Create the commands used to load the firmware binary into RAM and copy it to the Cortex-M4 TCM address:
> setenv load_cm_image "${load_cmd} ${loadaddr} ${cm_image}"
> setenv cm_boot "run load_cm_image; cp.b ${loadaddr} 0x203c0000 ${cm_isize}; dcache flush; bootaux 0x20000000" -
Save the U-Boot environment:
> saveenv
- Linux BSP
> ext4ls mmc 2:1> ext4ls mmc 2:2 -
Set the
- Linux BSP
> setenv load_cmd "ext4load mmc 2:1"> setenv load_cmd "ext4load mmc 2:2"warningSelect the correct device and partition according to the installed image.
Set the Cortex-M7 instruction Tightly-Coupled Memory (TCM) size:
Create the commands used to load the firmware binary into RAM and copy it to the Cortex-M7 TCM address:
> setenv cm_boot "run load_cm_image; cp.b ${loadaddr} 0x7e0000 ${cm_isize}; dcache flush; mw.w 0x550ff000 0 64; bootaux 0x7e0000" -
> saveenv
- Linux BSP
Set the
- Linux BSP
/varin a Torizon OS image, use:> setenv cm_image "/ostree/deploy/torizon/var/hello_world_cm4.bin" -
> setenv cm_boot "run load_cm_image; cp.b ${loadaddr} 0x7e0000 ${cm_isize}; dcache flush; bootaux 0x7e0000" -
> saveenv
- Linux BSP
Set the
- Linux BSP
/varin a Torizon OS image, use:> setenv m4_0_image "/ostree/deploy/torizon/var/hello_world.bin" -
Update the
loadm4image_0alias to load the firmware binary into RAM:> setenv loadm4image_0 "${load_cmd} ${loadaddr} ${m4_0_image}" -
> saveenv
- Linux BSP
Set the
- Linux BSP
/varin a Torizon OS image, use:> setenv m4_0_image "/ostree/deploy/torizon/var/hello_world_m40.bin" -
Update the
> saveenv
The steps for loading firmware on the second Cortex-M4 core on Apalis iMX8 module are the same as above, using m4_1_image and loadm4image_1 instead of m4_0_image and loadm4image_0.
Start the Application
Before starting the firmware, connect to the alternative core serial console using another terminal.
To start the application, run the U-Boot command below:
- i.MX 95
- i.MX 8M Plus
- i.MX 8M Mini
- i.MX 8X
- iMX 8
> run cm_boot
> run cm_boot
> run cm_boot
> run m4boot_0
> run m4boot_0
To start the firmware on the second Cortex-M4 core on the Apalis iMX8 module, start the m4boot_1 alias instead of m4boot_0.
After running the preceding command, the firmware is loaded and executed on the alternative core. The output can be seen on the alternative core serial console, as shown below:
hello world.
Run the Firmware Automatically at Boot
Changing bootcmd modifies the boot flow. Validate the commands manually before saving the U-Boot environment.
To run the firmware automatically at boot, add the firmware loading and start commands to the bootcmd U-Boot environment variable. After saving the environment, U-Boot loads and starts the firmware during each boot.
- i.MX 95
- i.MX 8M Plus
- i.MX 8M Mini
- i.MX 8X
- iMX 8
> setenv bootcmd "run cm_boot; ${bootcmd}"
> saveenv
> reset
> saveenv
> reset
> saveenv
> reset
> setenv bootcmd "run m4boot_0; ${bootcmd}"
> saveenv
> reset
> saveenv
> reset
To run the firmware on the second Cortex-M4 core on Apalis iMX8 module, update the bootcmd variable with the m4boot_1 alias instead of m4boot_0.
Next Steps
Follow the How To Run a Custom Application on the Alternative Core (NXP) article to understand how to create a custom firmware application for the alternative cores.
