Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.3b2 (Release date: 2017-10-11)
- WEC 7 Updates: Installed Microsoft CE7 Updates until July 2017
- WEC 2013 Updates: Installed Microsoft CE8 Updates until September 2017
There is a known issue for 1.3b2 related to Toradex Easy Installer, see issue 31253 in the list: http://developer.toradex.com/software/windows-embedded-compact/imx6-wec-software/release-details?view=all&issue=31253
WC-264FixedSupport IOCTLs to read/write config block parameters.Apalis iMX6, Colibri iMX6BootloaderWEC7, WEC2013
Description: Currently the BSP does not support IOCTLs to read and write config block settings, this prevents the display tool from saving display configuration for the splash screen.
Workaround: The whole config block can be saved/restored using update tool or Toradex Easy Installer
