Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-281FixedIssue playing very short sound samplesApalis iMX6, Colibri iMX6Analog AudioWEC7, WEC2013
Description: When a short audio sample (less than one second) is played it is barely audible. Longer samples seem to not have this issue. This is due to the fact that the audio driver turns volume to zero when no sound is played and then increases it back to previous level when starting playback of a new sound. The volume by default is not increased immediately (to prevent popping sounds or noise) and this may lead to short sound played after at least 2 seconds without any sound played being barely audible.
Workaround: Remove slow volume ramp-up by adding registry entry: [HKLM\builtin\Audio] "Reg0x0E"=dword:03000000
