Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-399FixedTouch does not work correctly with some panelsApalis iMX6, Colibri iMX6Resistive TouchWEC7, WEC2013
Description: Using some resistive touch panels the touch does not behave correctly. Touches are not detected correctly or dragging is stopped even if the stylus/finger is still touching the screen.
