Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b2 (Release date: 2018-06-20)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed and this image can't load registry images saved using previous versions. Please export and re-import your registry settings using reg files when you update the OS image.
WC-387FixedUseSplashSettings display configuration parameter does not work with LVDSApalis iMX6GraphicsWEC7, WEC2013
Description: If this parameter is set and an LVDS display is configured, the device hangs at boot.
Workaround: You can configure both the splash screen and the registry entries in the OS, this will generate a very brief flash on the screen when it's re-initialized by Windows CE but will work.
