Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-384FixedThere is no way to pop-up NetUI's WiFi SettingsApalis iMX6, Colibri iMX6Wi-FiWEC7, WEC2013
Description: On WEC7 and WEC2013 there is no way to open NETUI using code. We fixed NETUI by naming a window. Users can now use HWND handle = FindWindow(NULL, L"NETRTWLANU1”); PostMessage(handle, WM_WZCSYSTRAYICON, 1, WM_LBUTTONDBCLK); To get handle to a window and send message. Window name depends on network interface name.
