Search by Tags
WEC iMX6 BSP Release
View All Submitted (open) Released (closed)
Clear Filter
1.4b4 (Release date: 2018-10-05)
- WEC 7 Updates: Installed Microsoft CE7 Updates until wave 5 update
- WEC 2013 Updates: Installed Microsoft CE8 Updates until April 2018
The format used to store registry has been changed between 1.3 and 1.4 releases and this image can't load registry images saved using versions earlier than 1.4b2. Please export and re-import your registry settings using reg files when you update the OS image.
WC-419FixedUpdated catalog file allow selection of individual components from binary BSPApalis iMX6, Colibri iMX6WinCE FeatureWEC7, WEC2013
Description: The catalog now shows the different components supported by the binary BSP and they can be selected individually.
Workaround: For releases older than 1.4b4 BSP_* variables can be set in workspace configuration.
