Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V1.4beta2 (Release date: 2015-05-29)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2015M03
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2015M03
- WEC 2013 Updates: Installed Updates until 2015M03
Note: To make use of feature WC-2002 (Improve durability of NAND Flash on T20), you have to update your image with nvflash (recovery mode). Downgrading again only works with NVFlash too.
WC-2006FixedNew CE7 SDK Required Because Silverlight Compatibility was BrokenColibri T20, Colibri T30WinCE FeatureWEC7
Description: The Silverlight references in the Toradex SDK do not match the Windows CE image 1.3b2 and later. See workaround for more information.
Workaround: Applications running on Images before 1.3 have to be rebuilt with SDK v0.2, applications running on 1.3 and later on have to be rebuilt with SDK v2.0. You get the SDKs from here: https://docs.toradex.com/102481
