Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V1.4 (Release date: 2015-09-25)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2015M06
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2015M06
- WEC 2013 Updates: Installed Updates until 2015M06
Note: To make use of feature WC-2002 (Improve durability of NAND Flash on T20), you have to update your image with nvflash (recovery mode). Downgrading again only works with NVFlash too.
WC-2042FixedClosing Application increases interrupt handling timeoutColibri T20, Colibri T30, Apalis T30WinCE FeatureCE6, WEC7, WEC2013
Description: When closing an application longer interrupt delays can be introduced. These due to some higher priority tasks in the OS (L2 Cache Handling) which are non interruptible.
