Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0 (Release date: 2017-03-10)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M10
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M09
- WEC 2013 Updates: Installed Updates until 2016M11
This release contains all changes from V2.0 beta 1 to V2.0 beta 4.
To Upgrade to 2.0 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1470FixedExternal PCIe devices are not enumeratedApalis T30PCIeWEC7, WEC2013
Description: Since 2.0 beta 4 on Apalis T30 external PCIe devices are not loaded any longer. This was fixed with a updated gpio.bootconf. This change affected the bootloader only.
Workaround: Set the gpio.bootconf string to the following value: "[gpio_146] pull=none [gpio_147] pull=up [gpio_148] pull=up [gpio_149] pull=up [gpio_150] pull=up [gpio_151] pull=up [gpio_170] pull=up [gpio_171] pull=up [gpio_186] outmode=tristate pull=none [gpio_187] outmode=tristate [gpio_231] pull=up [gpio_237] pull=up [gpio_238] pull=down [gpio_69] outmode=tristate [gpio_71] outmode=tristate [gpio_224] pull=none [gpio_146] outmode=tristate"
