Search by Tags
WEC T20 / T30 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Tegra Windows CE BSPs and images.
Issues which are scheduled for a specific version (e.g. V1.3beta1) will be integrated in the mentioned version of the BSP.
View All Submitted (open) Released (closed)
Clear Filter
V2.0 (Release date: 2017-03-10)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2016M10
- WEC 7 Updates: Installed Microsoft CE7 Updates until 2016M09
- WEC 2013 Updates: Installed Updates until 2016M11
This release contains all changes from V2.0 beta 1 to V2.0 beta 4.
To Upgrade to 2.0 use the new UpdateTool (https://docs.toradex.com/103231-tegra-update-tool.zip). Select the Layout Config file for your target OS.
WC-1472FixedRegistry size too smallColibri T20, Colibri T30, Apalis T30WinCE FeatureCE6, WEC7, WEC2013
Description: The CE Test kit did not pass the registry tests due to size limitations of the registry partition. The wize for registry partition was increased from 1 to 3 MB. This change was done in the *.CFG files. The image was not touched.
