Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
Clear Filter
1.7b2 (Release date: 2019-12-06)
- WinCE 6 Updates: Installed until 2018M03
- WinCE 7 Updates: Installed until 2019M09
- WinCE 8 Updates: Installed until 2019M09
WC-2808FixedNAND flash blocks are marked as bad too earlyColibri VF50, Colibri VF61FlashCE6, WEC7, WEC2013
Description: A NAND flash block will be marked as bad as soon as a single bit-flip is detected. The error correction can correct up to 24 bit-flips. This can lead to early reduction of the available memory in the flash filesystem, and prevent an application from storing more data.
Workaround: The flash does not really get defective by this error. Low-level formatting and updating the OS to the latest version solves the problem.
