Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
1.5b4 (Release date: 2017-10-19)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until June 2017
- WEC 7 Updates: Installed Microsoft WEC7 Updates until June 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until August 2017
WC-2446New FeatureChanged I2C driver to libraryColibri VF50, Colibri VF61I2CCE6, WEC7, WEC2013
Description: To use I2C it is recommended that you use latest library. We disabled I2C driver and will not support use of driver in the future.
Workaround: If you need to re-enable the driver because of backwards compatibility ( not recommended ) you can rename entry under [HKLM\Drivers\BuiltIn\I2CX] Dll=i2cdriver.dll This will re-enable the driver but new version of library will not work with this.
