Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
1.5b6 (Release date: 2017-11-24)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until June 2017
- WEC 7 Updates: Installed Microsoft WEC7 Updates until June 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until August 2017
WC-2484New FeatureAdd support for VMINI and generic network adapter to VSDebuggerColibri VF50, Colibri VF61WinCE FeatureCE6, WEC7, WEC2013
Description: VSDebugger.exe uses the default ethernet devices of the different modules. This new release supports also the VMINI adapter, allowing debugging of OS using Platform Builder and application using Visual Studio debugger. If the device does not use the ethernet interface but has a different kind of connection supporting TCP/IP (wi-fi, modem etc.), adding the CheckAdapterName DWORD parameter under HKLM\SOFTWARE\Toradex\Debugger and setting it to zero will allow the debugger to run without checking the adapter used.
