Search by Tags
WEC VF50 / VF61 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the Vybrid Windows CE BSPs and images.
View All Submitted (open) Released (closed)
Clear Filter
V1.1beta1 (Release date: 2015-02-06)
- WinCE 6 Updates: Installed Microsoft CE6 Updates until 2014M11
- WEC 7 Updates: Installed Microsoft CE7 Updates until November 2014
- WEC 2013 Updates: Installed Microsoft CE8 Updates until November 5
WC-2560FixedOnly one stop bit supported on serial portColibri VF50, Colibri VF61UARTCE6, WEC7, WEC2013
Description: The hardware controller can support up to two additional bits after each byte of data. One bit is always used as stop bit, the other one may be used as additional stop bit or parity. Now the driver supports also 2 stop bits, but only with no parity. When selecting 8 data bits + parity the parity is now sent as 8th bit, driver can support 7 or 8 data bits, parity and 1 or 2 stop bits. The maximum number of bits is 10. So it's possible to have 8+parity+1 stop, 8 + 2 stop, but not 8+parity+2 stop bits This means that the serial controller supports the following combinations: - 8 data bits + 1 stop bit - 8 data bits + 1 parity bit + 1 stop bit - 8 data bits + 2 stop bits - 7 data bits + 1 partity bit + 1 stop bit Currently only the first and last combinations are supported by the driver
