Video Tutorials
Apalis Tutorials
In this section, you will find a range of tutorials which will help you get started with the Apalis ARM Family of products and understand more about how to use the range of tools and utilities that we provide.
Apalis Evaluation Board Quick Start Tutorial
Unpack and setup the Apalis Evaluation Board. The tutorial provides also an overview of the available interfaces on the Evaluation Board.
Colibri Tutorials
In this section, you will find a range of tutorials which will help you get started with the Colibri ARM Family of products and understand more about how to use the range of tools and utilities that we provide.
Colibri Evaluation Board Quick Start Tutorial
Unpack and setup the Colibri Evaluation Board. The tutorial provides also an overview of the available interfaces on the Evaluation Board.
Hello World
Microsoft Embedded Visual C++ (eVC++) is a legacy tool and not supported by Microsoft and Toradex anymore. We recommend to use Visual Studio 2008 or Visual Studio 2013 depending on the Windows CE version you are using. The video Tutorial still uses eVC++, but VS2008 is quite similar to this tool.
Setup the freely available embedded Visual C++ Software Development Environment on your desktop PC. Establish an ActiveSync connection, create and run your first "Hello World" Application on Colibri.
Flashing Linux or Windows CE/Embedded Compact
Guide to flashing Linux or Windows CE using recovery mode
Colibri Update Tool
Update Bootloader/Image, Save and Clear Registry, Automate Production Setup (Flash file system backup/restore functionality available in Image 3.4beta2 and newer)
Colibri Tweak
Change Display settings, CPU frequency and Flash layout on the fly.
AutoRun and AutoCopy
Automatically run programs or copy files to the RAM file system upon Colibri Boot or upon inserting a removable storage device.
Edit the Registry
Edit the registry to deactivate certain system drivers. Make the changes persistent.
Flash File System
Create a Flash File system on Colibri's on-board Flash memory.
Remote Control
Control the Colibri hardware remotely by your Desktop PC, using ActiveSync.
Colibri Fastener
Inserting a Colibri module using Colibri Fasteners
Robin Tutorials
Robin Computer Module Quick Start Tutorial
In this episode we demonstrate the steps involved in powering up our Robin Nano CoM Express™ embedded computer module, which based on the Intel Atom x86 processor. We also take you through the steps involved in transferring Windows Embedded Standard onto the Robin module’s onboard Solid State Disk (SSD - up to 4GB), allowing you to boot Windows directly from the SSD on start-up.
