WEC iMX7 BSP Release
The following table contains known issues, scheduled bug fixes, and feature improvements for the iMX Windows CE BSPs and images.
Any schedules are not guaranteed, but reflect the current planning. The planning could be shifted due to priority changes.
Issues which are scheduled for a specific version will be integrated in the mentioned version of the BSP.
We will update this table continuously in order to always provide the latest state of our development plan.
Odd beta versions, as 1.0b1 or 1.3b3, are internal releases only for testing. They are omitted from the table.
Clear Filter
Issue #StatusSubjectModuleSubsystemWinCE OS
1.3 (Release date: 2021-11-25)
- WinCE 7 Updates: Installed until 2021M03
- WinCE 8 Updates: Installed until 2021M09
WC-2833New FeatureImproved Resistive Touch Screen accuracyColibri iMX7Resistive TouchWEC7, WEC2013
Description: Using Codec internal Sample Averaging and reading X, Y and Z(Pressure) samples in parallel instead of sequentially improves samples consistency and avoids false touch coordinates especially when releasing touch (pen-up).
Additionally there are new Registry entries that can be set:
"MinZValue" (Minimum Z value (Pressure) in order to consider a X and Y measurement valid. Setting this helps to get rid of wrong sampling values on very light touch pressure. A value of 10 works fine for 5-12 inch touch panels, for bigger panels lower values might be needed, default is 0
"Wait" (Wait settling time between measurements in us, default 512us, increase for bug touch screens with high capacitance)
"PenUpTimeout" (Timeout to generate PenUp Event when no valid measurements are returned, default is 25ms)
"DebugRawValues" (Set to 1 to enable useful debug output when trying to find the right values for MinZValue)
WC-2832New FeatureAdded support for Custom Audio Codec Register Init through registryColibri iMX7Analog AudioWEC7, WEC2013
Description: Added support for setting any Codec Register through registry settings, see:
https://developer.toradex.com/knowledge-base/audio-driver-registry-settings#Custom_codec_configuration
WC-2831New FeatureSupport AC97 tweak toolColibri iMX7Analog AudioWEC7, WEC2013
Description: AC97 tweak tool (now called Audio Codec Tool) works now also with iMX7 modules:
https://developer.toradex.com/knowledge-base/ac97-tweak
WC-2830FixedSaving of registry hangs if there is a bad blockColibri iMX7FlashWEC7, WEC2013
Description: If a bad block is detected during saving of the registry, the system hangs, and the registry does not get saved. A reboot recovers from this condition.
Workaround: -
WC-948FixedSetting SPI Clock frequency has no effectColibri iMX7SPIWEC7, WEC2013
Description: Using Toradex Libraries to set the SPI Clock frequency has no effect.
WC-920New FeatureBSP release 1.3 is based on 1.3b2Colibri iMX7WEC7, WEC2013
Description: BSP release 1.3 is based on 1.3b2. At the moment there are no further changes planned.
1.3b2 (Release date: 2019-08-09)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until September 2018
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until October 2018
WC-914Fixed24 bit LCD DATABUS WIDTH not setting by the display driverColibri iMX7VGAWEC7, WEC2013
Description: Setting LDDS to 24 bit has not effect (still uses only 18 bit)
WC-912FixedFile read data corruption (SD/eMMC) WEC2013 iMX7Colibri iMX7Cache, FlashWEC2013
Description: Sometimes when reading data from SD Card it would return wrong value but data would stay uncorrected.
WC-910FixedUse latest UpdateTool to allow flashing large splash screensColibri iMX7Toradex Feature, Update SystemWEC7, WEC2013
Description: Large splash screen cannot be programmed with the UpdateTool
1.2 (Release date: 2019-03-19)
WC-938New FeatureBSP release 1.2 is based on 1.2b4Colibri iMX7WEC7, WEC2013
Description: BSP release 1.2 is based on 1.2b4. At the moment there are no further changes planned.
WC-916FixedMissing file associations for .bat files in CE8Colibri iMX7WinCE FeatureWEC2013
Description: Added missing .bat file associations.
1.2b4 (Release date: 2018-12-21)
Release was postponed to December due to some investigations which turned out to not be a BSP issue but a bug in certain older SD Cards.
WC-937FixedSPI clock is configured wrongColibri iMX7Power ManagementWEC7, WEC2013
Description: SPI clock is configured with wrong divider.
Workaround: Use latest BSP
WC-935FixedInclude more code pagesColibri iMX7WinCE FeatureWEC7, WEC2013
Description: - Added 936 (Simplified Chinese), 949 (Korean), 950 (Traditional Chinese) - Removed all Locales except English US (they can be re-added with cab installers) Cab installers can be found here ( https://developer.toradex.com/add-locales-to-an-existing-windows-embedded-compact-image )
WC-919FixedUART4 does not work in DMA modeColibri iMX7UARTWEC7, WEC2013
Description: UART DMA Event is not configured properly.
WC-906FixedSpi CS default state is Low till first SPI transfer startsColibri iMX7SPIWEC7, WEC2013
Description: After a power cycle, the ~CS pin of the SPI interface is low, which is wrong as ~CS low is the active state. After a power cycle, this pin should be high in all cases.
Workaround: Use latest libraries and BSP above 1.2b4
WC-905FixedRtcSync fails when using internal RTCColibri iMX7RTCWEC7, WEC2013
Description: System time is not restored from on-module RTC. Refer to this link for more information https://developer.toradex.com/internal-rtc-ce
WC-901FixedFreeze during reboot after a software reset while writing to the SD cardColibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: Some SD Cards may not reset properly after software reset.
WC-897FixedSometimes when booting system would generate NAND timeout warningsColibri iMX7FlashWEC7, WEC2013
Description: Sometimes NAND would generate ECC timeouts
Workaround: Disable network driver.
WC-895FixedUSB Host on Aster did not workColibri iMX7USBWEC7, WEC2013
Description: Bottom USB Host on Aster carrier board does not work
Workaround: Add this registry setting -> [HKLM\Drivers\Builtin\USBOTG\Hcd\Pinout_Default] "gpio_103"="altfn=-1 dir=out lvl=0"
WC-894New FeatureSD Card would get corrupted sometimesColibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: Sometimes cache would not be properly flushed and SD Card could corrupt the data.
Workaround: Contact support for replacement driver.
WC-893FixedI2c clock speed is not proportionally set to the library configurationColibri iMX7I2CWEC7, WEC2013
Description: Configured base clock was to low.
1.2b2 (Release date: 2018-09-07)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until March 2018
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until May 2018
WC-947FixedEarlyAutoCopy feature of WaitForFlashDisk does not work reliablyColibri iMX7Flash, WinCE FeatureWEC7, WEC2013
Description: The EarlyAutoCopy feature of WaitForFlashDisk driver does not always work.
WC-946FixedSetting breakpoints in Visual Studio causes data abort exceptions in NK.exeColibri iMX7WEC7
Description: VS2008 debugging crashes the Colibri iMX7 WEC7.
WC-945FixedLoading i2c3 driver during boot causes system to crashColibri iMX7I2CWEC7
Description: System hangs during boot, while loading i2c3 driver.
WC-943New FeatureAdd support to disable cursorColibri iMX7GraphicsWEC7, WEC2013
Description: Allow disabling the mouse cursor completely using a registry settings or extescape calls like in other Toradex BSPs. See https://developer.toradex.com/knowledge-base/mouse-cursor
Workaround: For BSPs older than 1.2b2, hide cursor in your application using ShowCursor API.
WC-942FixedAudio sometimes does not work after booting systemColibri iMX7Analog AudioWEC7, WEC2013
Description: After booting system sometimes audio will not work
WC-934FixedSDBUS patch for SDIO8787 WiFi and BT functions.Colibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: SDBUS patch needed in order to support both WiFi and BT functions on the SDIO8787 card.
WC-933FixedDisabling splash screen leads to a non-initialized display interface -> no display output in WinCEColibri iMX7BootloaderWEC7, WEC2013
Description: Display driver fails to configure LCD interface if splash screen is disabled
Workaround: Leave splash screen enabled. You can ask Toradex support to get a black splashscreen image.
WC-932FixedIssue on the dynamic changing resolution from splash screen to display driverColibri iMX7VGAWEC7, WEC2013
Description: An issue on the dynamic changing resolution from Spalsh screen to display driver
WC-931New FeatureUnify module information outputColibri iMX7Bootloader, WinCE FeatureWEC7, WEC2013
Description: Updated the output of Module Name and serial number while booting the device, in order to unify this between all the module families.
WC-928FixedWEC2013: Audio Files and Sound Scheme MissingColibri iMX7WEC2013
Description: System sounds are not available under WEC2013.
WC-927FixedAudio noise and malfunction when resetting device while playing soundColibri iMX7Analog AudioWEC7
Description: Resetting the system while playing audio can render the audio system to be silent until another reboot.
WC-926FixedNetUI's WiFi Settings don't pop-upColibri iMX7Wi-FiWEC7, WEC2013
Description: On WEC7 and WEC2013 there is no way to open NETUI using code. We fixed NETUI by naming a window. Users can now use HWND handle = FindWindow(NULL, L"NETRTWLANU1”); PostMessage(handle, WM_WZCSYSTRAYICON, 1, WM_LBUTTONDBCLK); To get handle to a window and send message. Window name depends on network interface name.
WC-924New FeatureAdd support for BusEnum2Colibri iMX7WinCE FeatureWEC7, WEC2013
Description: Busenum2 is available in the image for parallel driver loading. It is disabled by default. To enable it change [HKLM\Drivers\BuiltIn] DLL to "BusEnum2.dll"
WC-923New FeatureAdd support for LoadFilterColibri iMX7WinCE FeatureWEC7, WEC2013
Description: LoadFilter is now added to image and enabled by default.
WC-849FixedSGTL5000: Internal Charge Pump Is ActivatedColibri iMX7Analog AudioWEC7, WEC2013
Description: An internal charge pump of the SGTL5000 audio codec is activated, even though it is not used.
WC-834FixedTime can only be set upto year 2034Colibri iMX7RTCWEC7, WEC2013
Description: If a time beyond 2034 is set, there is kind of an overflow and the year be set back to 2007.
Workaround: Fixed
1.1 (Release date: 2018-05-25)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until December 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until April 2018
WC-850New FeatureBSP release 1.1 is based on 1.1b4Colibri iMX7WEC7, WEC2013
Description: BSP release 1.1 is based on 1.1b4. No further changes were done.
WC-833FixedRemove afd.dll patchColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Microsoft fixed issue when NTP server crashed services. This removes the patch we created.
1.1b4 (Release date: 2018-03-30)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until September 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until November 2017
WC-1014FixedTimezone can only be set once in RemoteAdmin interfaceColibri iMX7RTCWEC7
Description: When certain timezones are selected (e.g.: UTC+9:00 Osaka, Sapporo, Tokio) the page allowing to set time on the RemoteAdmin interface does not work.
Workaround: Change the timezone prior to using RemoteAdmin
WC-956New FeatureAdd support for multicoreColibri iMX7KernelWEC7, WEC2013
Description: Add support for the 2nd core on IMX7D
WC-866FixedAdded software filters for touchColibri iMX7Resistive TouchWEC7, WEC2013
Description: Touch screen detection can jitter depending on the environment (resistive touch screen, cables, etc.) This needs to be improved through special filtering in the driver. Use settings here to fine tune your touch -> https://developer.toradex.com/knowledge-base/resistive-touch-screen#Registry_settings_supported_by_Colibri_IMX7
WC-861New FeatureAdd support for cache in bootloaderColibri iMX7BootloaderWEC7, WEC2013
Description: Enable cache in the bootloader which will improve the boot time.
WC-860FixedSD Card clock was set to highColibri iMX7SDIO/SD/MMCCE6, WEC7, WEC2013
Description: Some SD Cards may not work because frequency was set higher than requested
Workaround: Use registry setting MaximumClockFrequency to limit frequency. You can find more information here -> https://developer.toradex.com/knowledge-base/colibri-i-mx7-sd-card-interface
WC-859Fixed[RegEdit] Strings of type REG_MUI_SZ are not shownColibri iMX7WinCE FeatureWEC7, WEC2013
Description: The Registry editor does not display certain multilanguage string settings.
WC-858Fixed[RegEdit] Key Default Value cannot be editedColibri iMX7WinCE FeatureWEC7, WEC2013
Description: The Key Default Value (the value assigned to the Key, shown as "(default)") cannot be edited
WC-857New FeatureAdd Registry Keys to Simplify Enabling of tchproxy.dllColibri iMX7Capacitive Touch, Resistive TouchWEC7, WEC2013
Description: We added registry settings to default images. [HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\TOUCH] "DriverName"="tchproxy.dll" [HKEY_LOCAL_MACHINE\Drivers\Touch] "Prefix" = "TCH" "Index" = dword:1 "Order" = dword:2 "Flags" = dword:8 ; DEVFLAGS_NAKEDENTRIES "IClass" = multi_sz:"{25121442-08CA-48dd-91CC-BFC9F790027C}", "{7119776D-9F23-4e4e-9D9B-9AE962733770}" "Priority256" = dword:6D ; touch ist priority = 109 "DLL" = "_touch.dll" [HKEY_LOCAL_MACHINE\System\GWE\TouchProxy] "tchcaldll" = "tchcaldll.dll"
WC-854New FeatureRemove sysgen_appdebugColibri iMX7WinCE FeatureWEC2013
Description: Reduce image size by removing sysgen_appdebug. We still support debugging under WEC2013 by adding webservices.dll in to the nk. For debugging it is not required to add any further dlls.
WC-853New FeatureSupport RNDIS on Debugger clientColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Currently application debugging over USB / RNDIS is not supported out of the box in the debugger client. Add support for RNDISFN to the debugger client.
WC-852New FeatureAdd Cortex-M4 supportColibri iMX7KernelWEC7, WEC2013
Description: Support loading and running code on the Cortex-M4 code. For example FreeRTOS or bare-metal code.
WC-846FixedBootloader Configuration gpio.bootconf Modification Flag Not ShownColibri iMX7BootloaderWEC7, WEC2013
Description: Bootloader does not show asterisk (*) to mark modified gpio bootloader setting.
WC-840FixedNotepad Selects Random FontColibri iMX7WinCE FeatureWEC7, WEC2013
Description: The text editor starts with a random font selection.
Workaround: Select the font manually in the Format -> Font... menu. Save the registry if you want to change this permanently.
1.1b2 (Release date: 2018-01-08)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until June 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until August 2017
WC-992New FeatureAdd support for analog audioColibri iMX7Analog AudioWEC7, WEC2013
Description: Add support for audio playback and recording
WC-889FixedAdd registry entry if eMMC is used as boot mediaColibri iMX7FlashWEC7, WEC2013
Description: There is an issue mounting the \FlashDisk storage folder that has a 5' timeout. The device takes more than 5' minutes to boot and does not mount \FlashDisk. This happens only on devices where Windows Embedded Compact was not installed or that had their flash memory erased before the installation.
Workaround: There are two workarounds: - Install image version 1.2 instead, boot it and then use update tool to install the new image and bootloader - Wait until the device has booted (5-6') and then use registry editor to add this entry to the device registry: [HKEY_LOCAL_MACHINE\System\StorageManager\Profiles\BootMMC\FATFS] "DisableAutoFormat"=dword:0 Save the registry and reboot, now the device will boot normally and mount \FlashDisk as expected
WC-887FixedDisabling splash screen leads to a non-initialized display interface -> no display output in WinCEColibri iMX7BootloaderWEC7, WEC2013
WC-884FixedSplash Screen update fails using Update Tool.Colibri iMX7WinCE FeatureWEC7, WEC2013
Description: Splash Screen update fails if no USB Flash stick is connected on Update tool version 7.5.0
WC-882New FeatureAdd support for VMINI and generic network adapter to VSDebuggerColibri iMX7WinCE FeatureWEC7, WEC2013
Description: VSDebugger.exe uses the default ethernet devices of the different modules. This new release supports also the VMINI adapter, allowing debugging of OS using Platform Builder and application using Visual Studio debugger. If the device does not use the ethernet interface but has a different kind of connection supporting TCP/IP (wi-fi, modem etc.), adding the CheckAdapterName DWORD parameter under HKLM\SOFTWARE\Toradex\Debugger and setting it to zero will allow the debugger to run without checking the adapter used.
WC-881New FeatureAdd DMA support for UARTColibri iMX7UARTWEC7, WEC2013
Description: To enable DMA use registry entry "EnableDMA" = 1
WC-880New FeatureAdd DMA support for SDColibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: Add DMA support for SD cards
WC-879FixedConfigBlock HWCfg cannot be readColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Using IOCTL_HAL_FLASHPARAMGET to get HWCfg from ConfigBlock returns a buffer filled with 0xff
WC-878FixedIncorrect BSP ID returned from IOCTL_HAL_GET_BSP_VERColibri iMX7WinCE FeatureWEC7, WEC2013
Description: iMX7 should return BSPID 5, but returns BSPID 4 (same as iMX6)
WC-876New FeatureAllow reading of config block parameters from static and/or dynamic config blockColibri iMX7ConfigBlockWEC7, WEC2013
Description: Allow reading of config block parameters from static and/or dynamic config block
WC-875New FeatureAdd a serial console message when registry is savedColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Add a serial console message when registry is saved
Workaround:
WC-874New FeatureAdd support for backlightColibri iMX7GraphicsWEC7, WEC2013
Description: Add support to control the backlight (on-off, no brightness).
WC-869New FeatureWEC2013: Include Bluetooth to standart imageColibri iMX7WinCE FeatureWEC2013
Description: Add Bluetooth support into the standard image.
WC-863New FeatureImplement Debug Message Buffer FeatureColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Details about this feature can be found here: http://developer.toradex.com/knowledge-base/debug-message-buffer
WC-862FixedBackground color is not configured correctlyColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Background color was set wrong
WC-844Fixed"Start Debugger Client" Does Not Start in WEC2013Colibri iMX7WinCE FeatureWEC7, WEC2013
Description: "Start Debugger Client" Does Not Start in WEC2013
Workaround: Open a WinCe command line, type the two commands: start conmanclient3.exe cmaccept3.exe
1.0 (Release date: 2017-10-02)
WC-890FixedMutliplexing PIN 28 to I2C3 SDA does not workColibri iMX7I2CWEC7, WEC2013
Description: Ask support for a modified driver
WC-870FixedUSB Over Current detection not working correctlyColibri iMX7USBWEC7, WEC2013
Description: Over-current pin is not properly multiplexed.
WC-868New FeatureOS image does not contain splash screenColibri iMX7WEC7, WEC2013
Description: Append the splash screen file directly to the standard image so it gets displayed after an image update.
WC-867FixedUSB Mass Storage Class takes long to mount/does not mountColibri iMX7USB, WinCE FeatureWEC7, WEC2013
Description: USB Mass Storage Class may take up to few minutes to mount. It may also fail to mount
WC-865New FeatureOutput serial number in bootloaderColibri iMX7BootloaderWEC7, WEC2013
Description: Printout serial number in bootloader
1.0b4 (Release date: 2017-08-11)
- WEC 7 Updates: Installed Microsoft WEC7 Updates until March 2017
- WEC 2013 Updates: Installed Microsoft WEC2013 Updates until April 2017
WC-1041New Feature[Wait4FlashDisk] Increase timeoutColibri iMX7WinCE FeatureWEC7, WEC2013
Description: If flash was written a lot it may happen that initial scan at boot will take more then 60s.
Workaround: Increase the timeout under [HKEY_LOCAL_MACHINE\Drivers\BuiltIn\Wait4FlashDisk] "Timeout"=dword:3C
WC-1040FixedUSB device connectivity is not reliableColibri iMX7USBCE6, WEC7, WEC2013
Description: USB device connectivity is not reliable and seen especially when using USBSER class.
WC-1035New FeatureHarmonize FlashDisk settingsColibri iMX7FlashWEC7, WEC2013
Description: We harmonized the registry settings for the FlashDisk driver. The settings will be the same on all our platforms.
WC-1033New FeatureAdd support for screen rotationColibri iMX7GraphicsWEC7, WEC2013
Description: Add support for screen rotation
WC-1032New Feature[Wait4FlashDisk] Use system files from FlashDisk or overwrite to Windows folder while loading Wait4FlashDisk driver.Colibri iMX7WEC7, WEC2013
Description: Investigate Use system files from FlashDisk or overwrite to Windows folder while loading Wait4FlashDisk driver.
WC-1001New FeatureAdd support for splash screenColibri iMX7VGAWEC7, WEC2013
Description: Add support for splash screen
1.0b2 (Release date: 2017-05-24)
WC-1042FixedDefault NTP servers are not longer operatingColibri iMX7RTC, WinCE FeatureCE6, WEC7, WEC2013
Description: Some of the time servers configured in the standard image are no longer active. We replace the NTP servers with the ones from the NTP Pool Project (See also: http://www.pool.ntp.org )
Workaround: Add additional time servers and remove the non-valid ones as described here: https://msdn.microsoft.com/en-us/library/ms884926.aspx?f=255&MSPPError=-2147217396
WC-1029FixedUsing application debugger fails most of the timeColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Application debugger is unable to connect to the target
WC-1025New FeatureI2cLib on iMX7: Make Timeout ConfigurableColibri iMX7I2CWEC7, WEC2013
Description: Use a programmable timeout for i2c operations, instead of a hard-coded constant timeout.
WC-1021New FeatureAdd support to IOCTL HAL REBOOTColibri iMX7WinCE FeatureWEC7, WEC2013
Description: IOCTL HAL REBOOT can be used to reboot the system
WC-1020New FeatureAdd icon to VSDebugger.exeColibri iMX7WEC7, WEC2013
Description: .
WC-1017FixedRNDISFN Driver should be built with SHIP_BUILD=1Colibri iMX7USBCE6, WEC7, WEC2013
Description: RNDIS driver generates a lot of debug output. Changed build type in order to remove debug output.
WC-1016New FeatureUse new naming and versioning convention for Toradex software packagesColibri iMX7WEC7, WEC2013
Description: We changed the naming and versioning format slightly in order to have a common approach for Linux, WinCE, and other Toradex software packages. Details about the versioning can be found here: https://developer.toradex.com/knowledge-base/toradex-software-versioning-convention
WC-1015New FeatureChange 1st boot loader and image outputColibri iMX7WEC7, WEC2013
Description: Standardize version output across all our images.
WC-1013FixedBuild explorer with SHIP_BUILD set to 1Colibri iMX7WinCE FeatureWEC2013
Description: Explorer.exe no longer outputs debug messages
WC-1006New FeatureAdd support for RS485Colibri iMX7UARTWEC7, WEC2013
Description: Add support for RS485
WC-1003New FeatureAdd support for I2CColibri iMX7I2CWEC7, WEC2013
Description: Add support for I2C on default pins
WC-1002New FeatureAdd basic support for SPIColibri iMX7SPIWEC7, WEC2013
Description: Support SPI including one CS on default SPI pins
WC-1000New FeatureAdd support for hardware watchdogColibri iMX7WatchdogWEC7, WEC2013
Description: Support hardware watchdog. Watchdog on IMX7 only supports timeout of 1,8,32 or 128 seconds
WC-999New FeatureAdd support for UpdateLibColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Add support for update library
WC-997New FeatureAdd support to configure GPIOs in bootloaderColibri iMX7GPIOWEC7, WEC2013
Description: Add support to configure GPIOs in bootloader
WC-993New FeatureAdd support for 4-wire touch screenColibri iMX7Resistive TouchWEC7, WEC2013
Description: Add support for touch screen
WC-987New FeatureCreate tools for recovery modeColibri iMX7Miscellaneous PeripheralsWEC7, WEC2013
Description: Add tools for easy recovery mode
WC-986New FeatureAdd support to boot from NAND flashColibri iMX7FlashWEC7, WEC2013
Description: Add support to boot from NAND flash
WC-975Fixed[RegEdit] Registry keys under HKEY_CURRENT_USER would not get importedColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Importing registry keys under HKEY_CURRENT_USER would fail.
Workaround: Contact support to get new version of registry editor.
WC-974Fixed[RegEdit] Silent option in registry editor does not workColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Using switch /S with registry editor still shows conformation and error windows.
WC-973New Feature[RegEdit] Right clicking on the listview did not open context menuColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Users can now right click on the listview and get context menu where they can add values to the current key.
WC-972Fixed[RegEdit] Export/import of keys other than HKLM does not workColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Users are not able to export custom keys from registry.
Workaround: Contact customer support for new registry editor tool.
WC-971New Feature[RegEdit] Add menu entry to save/clear registry to registry editorColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Users can now use menu inside registry editor to save or clear registry. There are also command line switches avalible -> /F to save /C to clear They can be used in combination with /S for silent.
WC-970New Feature[RegEdit] When opening modify window value is now focused automaticlyColibri iMX7WinCE FeatureWEC7, WEC2013
Description: When opening modify window in registry editor, value is automatically focused.
WC-969Fixed[RegEdit] When importing registry file some keys are duplicatedColibri iMX7WinCE FeatureWEC7, WEC2013
Description: When importing reg file some keys get shown twice. Key is still created only one but view is wrong.
WC-967New FeatureAdd RTCSync toolColibri iMX7RTCWEC7, WEC2013
Description: Provide the RTCSync tool
WC-966FixedUART baud rate is not using full precisionColibri iMX7UARTWEC7, WEC2013
Description: For some baud rates the actual bit rate is not very precise and this may lead to problems with devices that are not able to auto-adjust their baud rate, mostly when a large amount of data is transferred with no interruptions.
WC-965New FeatureAllow configuration of network Auto-reconnect parameters through registryColibri iMX7WinCE FeatureWEC7, WEC2013
Description: User can now configure time between re-connection attempts and number of times re-connection will be performed. Instructions can be found here: http://developer.toradex.com/knowledge-base/netui-additional-settings
WC-962New FeatureProvide the Update ToolColibri iMX7WinCE FeatureWEC7, WEC2013
Description: Provide the Update Tool
WC-959New FeatureAdd support for USB WiFiColibri iMX7Wi-FiWEC7, WEC2013
Description: Support WiFi modules that Toradex sels.
WC-950Fixed[RegEdit] When doing export registry exception is occurring.Colibri iMX7WEC7, WEC2013
Description: Exception will be occur when doing export registry.
Preview (V0.1beta1) (Release date: 2016-11-23)
This is a Preview release only with limited features.
- WEC 7 Updates: Installed Microsoft CE7 Updates until June 2016
- WEC 2013 Updates: Installed Microsoft CE8 Updates until July 2016
WC-990New FeatureAdd support for SD CardColibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: Add support for SD Card
WC-989New FeatureAdd support for USB HostColibri iMX7USBWEC7, WEC2013
Description: Add support for USB Host
WC-988New FeatureAdd support for USB DeviceColibri iMX7USBWEC7, WEC2013
Description: Add support for USB Device
WC-985New FeatureAdd support for Serial portColibri iMX7UARTWEC7, WEC2013
Description: Add support for Serial port
WC-984New FeatureAdd support for EthernetColibri iMX7EthernetWEC7, WEC2013
Description: Add support for Ethernet
WC-983New FeatureAdd display driver with support for the parallel RGB interfaceColibri iMX7VGAWEC7, WEC2013
Description: Add display driver with support for the parallel RGB interface
WC-981FixedRegistry Editor Import doesn't work with all .reg files and fails silentlyColibri iMX7WinCE FeatureWEC7, WEC2013
Description: The registry editor has some shortcomings when it comes to importing .reg files. Some keys might not be imported w/o error message.
Workaround: Add the missing registry entries manually.
WC-980New FeatureAutomatic USB host / client switchColibri iMX7USBWEC7, WEC2013
Description: Automatic USB host / client switch
WC-979New FeatureProvide the launcher toolColibri iMX7Miscellaneous PeripheralsWEC7, WEC2013
Description: Add support to launch apps at boot
WC-978New FeatureProvide the Colibri Monitor toolColibri iMX7WEC7, WEC2013
Description: Provide the Colibri Monitor tool
WC-964New FeatureAdd support SD Card cable detect polarityColibri iMX7SDIO/SD/MMCWEC7, WEC2013
Description: Add support to change card detect pin polarity
WC-957New FeatureAdd support for RTCColibri iMX7RTCWEC7, WEC2013
Description: Support RTC
WC-955New FeatureAdd USB Device fullspeed supportColibri iMX7USBWEC7, WEC2013
Description: Add support to lower the speed of USB
WC-953New FeatureAdd USB Host fullspeed supportColibri iMX7USBWEC7, WEC2013
Description: Add USB Device fullspeed support
WC-951New FeatureAdd support for 512MB ram on iMX7DColibri iMX7KernelWEC7, WEC2013
Description: iMX7D now supports 512MB of ram
Not Planned
WC-1038Feature RequestAdd support for alternative LCD pinsColibri iMX7VGAWEC7, WEC2013
Description: Currently display can not be connected to alternative pins
WC-1037Known IssueColibri Evaluation Board: USB 3.0 Devices Plugged in at Boot Time is not AccessibleColibri iMX7USB
Description: On the Colibri Evaluation Board V3, a USB 3.0 device plugged in at boot time is not accessible after boot. Furthermore, the device seems to influence the on-board USB hub in a way that any USB port 1-4 won't work anymore.
WC-1031Feature RequestSupport Colibri iMX7D 1GB V1.1A (1GB RAM, 4GB eMMC)Colibri iMX7Flash, RAMWEC7, WEC2013
Description: Support Colibri iMX7D 1GB V1.1A with 1GB RAM and 4GB eMMC. The other Colibri iMX7 SKUs use less RAM and NAND Flash instead of eMMC. Please contact your local sales office in case you are interested in WinCE support for this module version.
WC-1027Known IssueSetting USB device as "USBSER_class" does not workColibri iMX7WEC7, WEC2013
Description: Using USB Client as USBSER_class does not work with all the applications.
WC-1018Feature RequestSupport SD UHS mode (new feature of Colibri iMX7D V1.1D and Colibri iMX7S V1.1C)Colibri iMX7SDIO/SD/MMC
Description: Support SD UHS mode which is possible with the new Colibri module versions: Colibri iMX7D V1.1D and Colibri iMX7S V1.1C
WC-1005Feature RequestPWM will be supported as a library and not as part of the BSPColibri iMX7PWMWEC7, WEC2013
Description: We will add support for ADC through our libraries. Library page:
http://developer.toradex.com/software/windows-embedded-compact/toradex-ce-libraries-and-code-samples
Library roadmap and release notes:
http://developer.toradex.com/software/windows-embedded-compact/toradex-ce-libraries-and-code-samples/release-details
Workaround: Use the PWM Library.
WC-1004Feature RequestCAN will be supported as a library and not as part of the BSPColibri iMX7CANWEC7, WEC2013
Workaround: Use the CAN Library.
WC-998Feature RequestAdd support for suspend modeColibri iMX7Power ManagementWEC7, WEC2013
Description: Add support for suspend mode This is currently not planned as we don't have any request for it. Please contact us https://www.toradex.com/community/ if you need suspend mode.
WC-996Feature RequestAdd support for bootloader kitColibri iMX7BootloaderWEC7, WEC2013
Description: Provide a bootloader kit so customers can build their own bootloader
WC-994Feature RequestADC will be supported as a library and not as part of the BSPColibri iMX7Analog InputsWEC7, WEC2013
Workaround: Use the ADC Library.
WC-977Known IssueRemoteadmin interface does not ask for passwordColibri iMX7WinCE FeatureWEC7
Description: Web interface does not ask for password.
Workaround: If you are building your own BSP contact support and we will provide new DLL.
WC-976Known IssueSystem time does not behave correctly when DST is not activatedColibri iMX7RTCWEC7, WEC2013
Description: When DST is not active the current date/time reported by the system is not precise and lags few minutes per hours during runtime.
Workaround: If you have issues with DST not running correctly go into registry under HKLM\Time Zones and select your timezone. There is a subkey "Dynamic DST" with entries for each year. To fix it create a new entry for year when you have issues and copy value from previous year.
WC-949Known IssueMemory Leak When Connecting ActiveSync/WMDCColibri iMX7WinCE FeatureWEC7
Description: Minor memory leak when repeatedly connecting / disconnecting the USB cable between module and a PC.
Workaround: -
WC-941Known IssueMulti threaded application can't able to Debug - predictingColibri iMX7WEC2013
Description: A multi-threaded application can't able to Debug
WC-940Feature RequestInternal Version for Testing OnlyColibri iMX7WEC7, WEC2013
Description: This version was never officially released and is an internal version only.
WC-918Known IssueOnly English(United States) region can be usedColibri iMX7WinCE FeatureWEC7, WEC2013
Description: After adding additional locals through the Toradex .cab installer, still only the regional settings English(United States) can be used. Any other region setting prevents the system from booting correctly.
WC-917Known IssueThe debug message buffer cannot be activatedColibri iMX7WEC2013
Description: The Debug Message Buffer feature cannot be activated
WC-915Known IssueUser Credentials for WPA2 Enterprise WiFi connections are not persisted across rebootsColibri iMX7Wi-FiWEC7, WEC2013
Description: Issue was identified as problem with Microsoft code. As WEC7 and WEC2013 are in extended support ( https://support.microsoft.com/en-us/lifecycle/search?alpha=Windows%20Embedded%20Compact%202013 ) this is not going to be fixed by Microsoft updates.
WC-913Known Issue.NET CF V3.9 bug when comparing to (constant) 0LColibri iMX7WinCE FeatureWEC2013
Description: Comparing 0L and 0L in .NET Compact Framework 3.9 leads to wrong result.
Workaround: You can find a workaround from Microsoft here https://social.msdn.microsoft.com/Forums/en-US/a187a5da-d46f-440c-9e40-e201636c042d/bug-in-net-cf-justintimecompiler-with-roslyn-generated-ilcode-windows-embedded-compact-2013?forum=netfxcompact
WC-911Known IssueTouch coordinates jump while releasing the screenColibri iMX7Resistive TouchCE6, WEC7, WEC2013
Description: Buttons sometimes don't react on touch click events.
WC-888Known Issue800 x 480 display registry configuration failsColibri iMX7CE6, WEC7, WEC2013
Description: 800 x 480 display registry configuration fails.
Workaround: Set display parameters in splash screen configuration and Set UseSplashSettings on Display registry.
WC-885Known IssueTCP DHCP settings "Lease Expires" date is wrongColibri iMX7EthernetWEC7
Description: The "Lease Expires" date is always set to 1/1/1970 initially. This seems to be WEC7 related issue. This is not an issue on CE6.
Workaround: Do a ip renew (ipconfig /release, ipconfig /renew) to get a correct "Lease Expires" date. If you build your own Image, you can also use a legacy dhcp.dll.
WC-864Feature RequestAdd support for 2nd EthernetColibri iMX7EthernetWEC7, WEC2013
Description: Add support for 2nd Ethernet PHY over RMII
WC-842Known IssueThreads with higher priority (<101) can freeze the device (iMX7D only)Colibri iMX7WinCE FeatureWEC7, WEC2013
Description: If you are running a a thraed with high priority (above 101) this can freeze the device. The device will not be able to handle any other interrupt.
Workaround: Prevent forcing high priority threads to core 1. Do not use high priority threads (above prio 101) whenever possible.
WC-841Feature RequestAdd support for compressed imageColibri iMX7BootloaderWEC7, WEC2013
Description: Add support for compressed image
WC-836Known IssueExplorer Crashes When Showing a Folder Containing TRE.exeColibri iMX7WinCE FeatureWEC7
Description: Explorer Crashes When a Folder is Opened
Backlog
WC-1028Feature RequestSupport new iMX7 versions with new Macronix Flash MX30LF4G28AC-TIColibri iMX7FlashWEC7, WEC2013
Description: Add support for the new NAND flash from Macronix (MX30LF4G28AC-TI) used on Colibri iMX7S 256MB V1.1C Colibri iMX7D 512MB V1.1D
WC-960Feature RequestSupport Toradex PCAPColibri iMX7Miscellaneous PeripheralsWEC7, WEC2013
Description: Supported the capacitive touch screens from the webshop
WC-930Known IssueSaving Registry does not work after a while on IMX7D 1GB (eMMC)Colibri iMX7FlashWEC7, WEC2013
Description: If you try to save the registry after running the system for a while, the registry save will fail and you will not be able to write to the flashdisk any longer.
Workaround: In order to save the registry reboot the device and then save the registry.
WC-909Known IssueUART_C transmit is not workingColibri iMX7UART, USBWEC7, WEC2013
Description: UART3 does not transmit any data, because the Tx pin's alternate function is configured to OTG1_OC.
Workaround: remove the registry setting [HKLM\Drivers\BuiltIn\USBOTG\Hcd\Pinout_Default] colibripin_21="altfn=1" and save the registry
WC-908Feature RequestSend Eboot source code to customerBootloader
Description: generate Eboot source code package
WC-900Feature RequestHigh-level SW feature overview for Colibri iMX7 Roadmap
Description: iMX7 Roadmap SW features WinCE
WC-896Feature RequestDocument SRAM used by Windows CEColibri iMX7RAMCE6, WEC7, WEC2013
Description: In WinCe versions before V1.1, some SRAM areas were used by WinCe and therefore could not be used for any M4 application.
Workaround: Use Image V1.1 or newer
WC-892Known Issue18BPP and 24BPP not valid settingsColibri iMX7GraphicsWEC7, WEC2013
Description: WinCE doesn't support 18 bpp and 24 bpp. Only 16 bpp and 32 bpp are valid settings.
