In this lesson you will:
- Understand how to translate the hardware pin names to the correspondent Linux sysfs interface numbers.
- Assemble the additional hardware - an LED and a switch.
- Use the Toradex GPIO Tool to validate the hardware setup.
- Configure and use GPIO pins through the Linux sysfs.
- Debug GPIO configuration.
- Write minimal sample applications in C.
Since Iris Carrier Board doesn't have buttons and LEDs available for debbuging purposes, we present two alternatives to test GPIOs: the first connects two GPIOs configured as input and output respectively; whereas the second alternative uses an external button and LED to achieve a better user experience, however, the following items are required:
- 1x LED
- 1x Button
- 1x Transistor BC548
- 2x 2k2Ω Resistor
- 1x 470Ω Resistor
- 1x Breadboard
- Jumper wires
Note: On this getting started we are going to use 2x Resistor 2k2Ω, but you can use anyone between 1kΩ and 10kΩ. For Resistor 470Ω, you can use anyone between 100Ω and 1kΩ. For the transistor BC548, you can use any switch component you want, as MOSFET, just change the circuit according to the component.
To find out which GPIO number to use in the Linux sysfs interface, you have to know the correspondence between available pins in the carrier board, number of the correspondent pins on the SODIMM connector of the Colibri computer on module and number of the pins on Linux.
Download or open in a web browser the Iris Carrier Board and the Colibri T30 datasheets from the respective products pages of the developer website:
Iris Carrier Board datasheet
For this introduction guide, some pins configured by default as GPIO in the Toradex BSP were chosen. The choice of pins was made based on their availability on all the carrier boards covered by the getting-started guide. This module will not go through the configuration of other pins as GPIO, although it is possible.
First of all, you need to find the correspondence between the SODIMM and the connectors exposed for the developer on the Iris Carrier Board. Consult the Iris Carrier Board datasheet and fill the table below based in the example provided:
Note: The notation CONNECTOR.PIN will be employed in this lesson, e.g. X12.5 means pin 5 of the X12 connector.
Iris Carrier Board (connector.pin) |
SODIMM pins |
X16.19 |
79 |
85 |
97 |
98 |
101 |
103 |
133 |
Table 1 filled
SODIMM pins |
X16.19 |
79 |
X16.18 |
85 |
X16.17 |
97 |
X16.13 |
98 |
X16.16 |
101 |
X16.15 |
103 |
X16.14 |
133 |
Have a look at the table available in the "List Functions" chapter of the Colibri T30 datasheet. It provides a list of most of the Tegra pins available on the SODIMM connector.
The SODIMM pins we are interested at are connected to the Tegra SoC and have names defined by the Tegra Pin Name function. Each pin is multiplexed to have a specific function - among them GPIO, therefore the GPIO function is the column that we are interested at.
Having a look at the GPIO Alphanumeric to GPIO Numeric Assignment article, the correspondence between GPIO and the Linux numeric representation of the GPIO pins is provided as a table. To find it from the GPIO it is possible to use the formula below:
GPIO-(Character).Digit
Linux numeric representation = 8 x (Character - 'A') + Digit
Either by consulting the table from the article pointed above or calculating it, the previous table with the correspondence between Colibri Evaluation Board pins and SODIMM pins can be extended to have the Tegra pin name (GPIO), formed by GPIO character and digit, as example GPIO-T.02, and the Linux numeric representation. Fill the table below based in the example provided:
SODIMM pins |
Tegra pin name (GPIO) |
Linux GPIO number |
X16.19 |
79 |
GPIO-Y.05 |
197 |
X16.18 |
85 |
X16.17 |
97 |
X16.13 |
98 |
X16.16 |
101 |
X16.15 |
103 |
Table 2 filled
SODIMM pins |
Linux GPIO number |
X16.19 |
79 |
GPIO-Y.05 |
197 |
X16.18 |
85 |
GPIO-V.03 |
171 |
X16.17 |
97 |
GPIO-Y.04 |
196 |
X16.13 |
98 |
GPIO-Z.01 |
201 |
X16.16 |
101 |
GPIO-Y.07 |
199 |
X16.15 |
103 |
GPIO-Y.06 |
198 |
Choose two of the GPIO pins from the list above to make a loopback test. This lesson will use the following pins (Linux GPIO number):
- 201 as Input
- 196 as Output
Use jumper wires to connect GPIO 201 to GPIO 196.
Note: You need a display and a mouse connected to the system in order to use the GPIO tool. Please go to the beginning of the getting-started guide for more information about assembling the peripherals.
Starting the GPIO tool
GPIO tool initial screen
Locate the pins 201 and 196 in the table. Right click the direction of each of them and configure pin 201 as INPUT and pin 196 as OUTPUT. See the changes reflected in the application.
Configuring SODIMM pin
Click the Logic checkbox of pin 196 and see the logic checkbox of pin 201 switch on/off.
From the Linux terminal, export the pins 201 and 196:
echo 201 > /sys/class/gpio/export
echo 196 > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio201/direction
echo "out" > /sys/class/gpio/gpio196/direction
Read the INPUT value as you toggle OUTPUT value:
echo 1 > /sys/class/gpio/gpio196/value
cat /sys/class/gpio/gpio201/value
echo 0 > /sys/class/gpio/gpio196/value
The following steps are meant for readers that have the optional items listed in the beginning of this lesson. If you want to go through them, click the dropdown link below:
Steps 10 to 17
The steps below will use the following pins (Linux GPIO number) to toggle an LED and read the value of a switch:
Use jumper wires to connect GPIO 196 to 2k2Ω resistor, connect the resistor to transistor base pin, connect pin X16.12 (5V) from iris to 470Ω resistor, connect the resistor to one LED and connect to transistor collector pin, connect the transistor emitter pin to pin X16.2 (GND) on Iris Carrier Board. Use jumper wires to connect pin X16.33 (3,3V) to 2k2Ω resistor, connect the resistor to one switch and to GPIO 201, and connect the node to pin X16.21 (GND) on Iris Carrier Board.
Breadboard connection
Schematic
Read the switch value as you toggle it:
Note: If the module was rebooted the GPIO must be configured again as explained in Step 8.
Toggle the LED GPIO:
There is a debug interface provided by the kernel debugfs for GPIO, which holds information about GPIO pins already reserved for drivers, as well as pin configuration and state. See the example below for the Colibri T30, and try it yourself:
root@colibri-t30:~# cat /sys/kernel/debug/gpio
GPIOs 0-255, tegra-gpio:
gpio-10 (SODIMM pin 154 ) in lo
gpio-17 (SODIMM pin 81 ) in lo
gpio-23 (sdhci_cd ) in lo
gpio-26 (THERMD_ALERT ) in hi
gpio-29 (sysfs ) out hi
gpio-67 (SODIMM pin 130 ) in lo
gpio-70 (SODIMM pin 132 ) in lo
gpio-85 (USBC_DET ) in lo
gpio-86 (KEY_MENU ) in hi
gpio-90 (sysfs ) out lo
gpio-91 (sysfs ) out hi
gpio-94 (sysfs ) out hi
gpio-110 (SODIMM pin 162 ) in lo
gpio-111 (hdmi_hpd ) in lo
gpio-144 (SODIMM pin 73 ) in lo
gpio-153 (EN_MIC_GND ) out hi
gpio-157 (KEY_BACK ) in hi
gpio-158 (KEY_HOME ) in hi
gpio-168 (TOUCH_PEN_INT ) in hi
gpio-169 (KEY_POWER ) in lo
gpio-170 (BL_ON ) out hi
gpio-171 (SODI-85, Iris X16-18) out lo
gpio-178 (usb_host_vbus ) out lo
gpio-181 (SODIMM pin 75 ) in lo
gpio-188 (SODIMM pin 134 ) in lo
gpio-190 (102, I X13 ForceOFF#) in lo
gpio-191 (104, I X14 ForceOFF#) in lo
gpio-196 (sysfs ) out lo
gpio-197 (sysfs ) out lo
gpio-198 (sysfs ) out lo
gpio-199 (sysfs ) out hi
gpio-201 (sysfs ) out lo
gpio-220 (SODIMM pin 166 ) in lo
gpio-221 (SODIMM pin 168 ) in lo
gpio-222 (SODIMM pin 170 ) in lo
gpio-223 (SODIMM pin 172 ) in lo
gpio-226 (KEY_FIND ) in lo
gpio-230 (KEY_VOLUMEDOWN ) in hi
gpio-231 (SODIMM pin 94 ) in lo
gpio-232 (LAN_RESET ) out hi
gpio-234 (LAN_V_BUS ) out hi
gpio-237 (SODIMM pin 69 ) in hi
gpio-238 (SODIMM pin 65 ) in hi
gpio-239 (KEY_VOLUMEUP ) in hi
GPIOs 256-264, i2c/4-002d, tps6591x, can sleep:
gpio-262 (fixed_reg_en_hdmi ) out lo
See that the pins 201 and 196, configured as input and output in the previous steps, are the only ones taken by sysfs and are correctly configured as in and out respectively.
Export, unexport, configure and toggle the GPIO pins as you read the debugfs information to see the changes.
Note: If you want additional pin configuration debug, explore the */sys/kernel/debug/tegra_pinctrl/ directory.
Write a small C application that toggles the LED GPIO. A small source-code is given below for reference and you may copy-paste it to your previously configured Eclipse environment.
Warning: The source-codes provided in this guide are distributed under the 3-clause BSD license terms. See below:
License
Copyright (c) 2017, Toradex
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
notice, this list of conditions and the following disclaimer in the
documentation and/or other materials provided with the distribution.
* Neither the name of the Toradex nor the
names of its contributors may be used to endorse or promote products
derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL Toradex BE LIABLE FOR ANY
DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Source code 1
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
int main(int argc, char *argv[]){
int fd;
// export GPIO
fd = open("/sys/class/gpio/export", O_WRONLY);
write(fd, "196", 3);
close(fd);
// Configure as output
fd = open("/sys/class/gpio/gpio196/direction", O_WRONLY);
write(fd, "out", 3);
close(fd);
// Blink GPIO once
fd = open("/sys/class/gpio/gpio196/value", O_WRONLY | O_SYNC);
write(fd, "0", 1);
usleep(1000000);
write(fd, "1", 1);
close(fd);
return EXIT_SUCCESS;
Write a small C application that reads the switch GPIO. A small source-code is given below for reference and you may copy-paste it to your previously configured Eclipse environment.
Source code 2
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
int fd;
char value;
// export GPIO
write(fd, "201", 3);
close(fd);
// configure as input
fd = open("/sys/class/gpio/gpio201/direction", O_WRONLY);
write(fd, "in", 2);
close(fd);
// read GPIO once
fd = open("/sys/class/gpio/gpio201/value", O_RDONLY);
read(fd, &value, 1); // read GPIO value
printf("GPIO value: %c\n", value); // print GPIO value
close(fd); //close value file
The GPIO sysfs interface enables the use of interrupts from user space, as long as it is supported by the underlying hardware. Read the sysfs GPIO documentation, have a look at the poll system call and try to implement an application that handles the interrupt. Have a look at the source code below for reference:
Source code 3
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <poll.h>
int fd;
char value;
struct pollfd poll_gpio;
poll_gpio.events = POLLPRI;
// export GPIO
close(fd);
write(fd, "in", 2);
close(fd);
// configure interrupt
fd = open("/sys/class/gpio/gpio201/edge", O_WRONLY);
write(fd, "rising", 6); // configure as rising edge
close(fd);
// open value file
poll_gpio.fd = fd;
poll(&poll_gpio, 1, -1); // discard first IRQ
// wait for interrupt
while(1){
if((poll_gpio.revents & POLLPRI) == POLLPRI){
lseek(fd, 0, SEEK_SET);
printf("Interrupt GPIO val: %c\n", value);
break;
To prevent the main loop from blocking, run the GPIO IRQ handling in a separate thread. Try to implement it.
Improve the code from the previous steps to handle errors and add other functionality you want. The code below implements a frequency meter by measuring the elapsed time between GPIO interruptions:
Source code 4
#include <stdio.h>
#include <stdlib.h>
#include <fcntl.h>
#include <unistd.h>
#include <poll.h>
#include <time.h>
#include <string.h>
#include <errno.h>
// high priority or an error occured in SW
#define POLL_GPIO POLLPRI | POLLERR
#define TIMEOUT 10
#define SAMPLES 500
#define EXPORT_PATH "/sys/class/gpio/export"
#define SW_VAL_PATH "/sys/class/gpio/gpio201/value"
#define SW_INT_PATH "/sys/class/gpio/gpio201/edge"
#define SW_DIR_PATH "/sys/class/gpio/gpio201/direction"
int configure_pins();
const char *sw = "201"; // Linux GPIO representation
void close_fd(int);
int fd, fd_edge, fd_export, count, poll_ret;
double period, cpu_time_used;
char value;
time_t t0, t1;
configure_pins();
while(fd = open(SW_VAL_PATH, O_RDONLY) <= 0);
printf("Opened SW value sucessfully\n");
// file descriptor from SW is being polled
poll_gpio.fd = fd;
// poll events in GPIO
poll_gpio.events = POLL_GPIO;
while(1){
t0 = time(0);
for(count = 0; count < SAMPLES; count++){
poll_ret = poll(&poll_gpio, 1, TIMEOUT*1000);
if(!poll_ret){
printf("Timeout\n");
return 0;
else{
if(poll_ret == -1){
perror("poll");
return EXIT_FAILURE;
if(poll_gpio.revents & POLLPRI){
//printf("GPIO changed state!\n");
t1 = time(0);
period = difftime(t1, t0) * 1000;
period /= SAMPLES; // divide by n samples
printf("Period (ms): %f \n", period);
void close_fd(int fd){
// close file from file descriptor
if(close(fd) < 0){
perror("Warning: Unable to close file correctly");
int configure_pins(){
int fd_export, fd_edge, fd_input;
/*******************EXPORT*******************/
// open export file
if((fd_export = open(EXPORT_PATH, O_WRONLY)) <= 0){
perror("Unable to open export file\n");
}else printf("Opened export file successfully\n");
// export SW GPIO
if(write(fd_export, sw, strlen(sw)) < 0){
if(errno != EBUSY){ // does not end if pin is already exported
perror("Unable to export SW GPIO\n");
close_fd(fd_export);
perror("Warning: Unable to export SW GPIO\n");
} else printf("Exported SW successfully\n");
// close export file
/******************DIRECTION******************/
// open direction file
if(fd_input = open(SW_DIR_PATH, O_WRONLY) <=0){
perror("Unable to open direction file for PIN 58\n");
} else printf("Opened direction file successfully\n");
if(write(fd_input, "in", 2) < 0){ // configure as input
if(errno != EBUSY){
perror("Unable to change direction from SW\n");
close_fd(fd_input);
perror("Warning: unable to change direction from SW\n");
}else printf("Changed direction from SW successfully\n");
close_fd(fd_input); // close direction file
/********************EDGE*********************/
while(fd_edge = open(SW_INT_PATH, O_RDWR) <=0);
printf("Opened edge file successfully\n");
while(write(fd_edge, "rising", 6) < 0);
printf("Changed edge from SW successfully\n");
close_fd(fd_edge);
What is the sysfs interface
Quoting the Linux kernel documentation:
sysfs is a ram-based filesystem initially based on ramfs. It provides
a means to export kernel data structures, their attributes, and the
linkages between them to userspace.
See the kernel documentation for additional information:
sysfs
Often there are kernel modules for dedicated purposes, which are preferred to implementing on your own. Examples of such are the control of LEDs, display backlight and power management.
In addition, there are hardware interfaces that may best suit your purposes, such as the PWM interface and other peripherals.
Browse this FAQ for reference regarding these alternatives.
All Toradex modules come configured to control a display backlight. For such purpose, one of the hardware PWM interfaces and a GPIO, as well as the Linux kernel backlight API, are employed.
The PWM interface is responsible for controlling the display brightness, and the GPIO for toggling it on/off.
For more details please consult the correspondent section of the GPIO article:
[Backlight (Linux)]http://developer.toradex.com/knowledge-base/backlight-(linux "Backlight (Linux)")
To use a GPIO as a power management input, you have to alter the device-tree and create a udev rule.
Power Management Keys
Additionally, a GPIO can be used as an interrupt source to wake-up the system from a low-power state. The SODIMM 45 is defined as the wake-up pin by default.
For more details please consult the Suspend/Resume article:
Suspend/Resume
If there isn't a kernel driver that suits your needs, you can access GPIO from kernel space rather than user space, and use the gpio.h kernel library.
There are other ways to access GPIO registers directly either from user space (using mmap) or kernel space (using ioremap). Those are problematic since they bypass the kernel handling of the GPIO controllers and might lead to unexpected behavior.
The behavior is not well defined for every module, depending on the provided BSP. If this knowledge is really required, you might verify the kernel GPIO/pinctrl subsystem.
