Updating Containers with Torizon OTA
Your progress
After adding your device to Torizon OTA in the previous lesson, now you can deploy your application.
In this section, you will:
  • Upload a Docker Compose file with example container information. In other words, add your application to Torizon OTA.
  • Remotely update your device with these new containers.
  • The example should execute a web browser on the device.
Typographic Conventions
For this Quickstart Guide:
  • Development computer with Ubuntu 18.04 LTS. Warning: Commands and instructions may vary slightly on other Ubuntu releases and Linux distributions.
  • Successfully completed the previous lessons from this guide.
* This is a requisite for the entire Quickstart, but our Torizon OTA app will run on any browser, on any Linux, Windows or MacOS.
Docker Compose is a tool for defining and running multi-container Docker applications.
For this Quickstart lesson, we will provide a Docker Compose file ready to use. Click the button below to download it:
Example Docker Compose file
After downloading the file, go to the dashboard and click on the "Add New Package" button.
  • Add a new package
    Add a new package
Step 3
Click on the "Attach Docker Compose File" button and then select the *.yml file you have just downloaded.
  • Attach your .yml file
After that, click on "Continue".
Step 4
Give your package a custom name and version. For example, you can use Quickstart and 1.0.0.
It is a good practice to adopt a versioning convention for your software. If you are new to the topic, one possibility is semantic versioning.
  • Select your SoM family accordingly
Click on "Upload" and wait until the process concludes.
  • Package Created
    Package Created
Step 5
Go to the dashboard again and click to initiate an update in your device:
  • Initiate Update
    Initiate Update
Step 6
Select the option "Custom Package" and then select the package you've just added.
  • Select the package
    Select the package
Click on "Continue". The update process will take some time. You can see the progress on the icon in the bottom-left part of the screen.
Note: by default, TorizonCore is configured to poll the OTA server once every 5 minutes. That may sound like a lot of time for evaluation, but it is a reasonable default configuration for production. After you finish the Quickstart, you can set a custom polling time.
  • Wait until the update finishes
Step 7
After the update is deployed, the board will automatically reboot and a browser will show up on the external monitor:
  • Web browser on Torizon
Step 8 - Optional
Edit the following line on the docker-compose (*.yml) file to modify the browser initial page:
    command: --browser-mode http://www.toradex.com
Note: Optionally, you can also replace --browser-mode by --window-mode in order to start the browser in fullscreen mode.
After editing and saving the docker-compose file, upload this new version following step 2 onwards. You might want to use the same package name and increase the version. For example, you can use Quickstart and 2.0.0.
FAQ
Is Torizon OTA free? What are the plan options?
Do I need to learn Docker Compose?
How can I learn more about Docker Compose?
Where do I find more information about the web browser example?
