MPU 6050 - InvenSense TDK
Manufacture: InvenSense TDK
Device Type: Sensor
Interface: I2C
Operating Temperature: -40 °C a +85 °C
Features: Accelerometer
Gyroscope
Temperature Sensor
Device Page
Compatible Setups
No results found.
How to Use with Embedded Linux
  • Enable it in the device tree, see example on Device Tree Customization Examples.
  • Enable corresponding kernel drivers.
  • The RTC on some of our carrier boards use the same I2C address. Make sure to use the alternative I2C address of the MPU-6050.
MPU 6050
According to Invensense.com:
The MPU-6050™ parts are the world’s first MotionTracking devices designed for the low power, low cost, and high-performance requirements of smartphones, tablets,y and wearable sensors.
Toradex kindly advises you to take a look at MPU 6050 Invensense Page for technical information and for the whole buying process.
Datasheet
See Also
