Version: 5.0
Splash Screen on TorizonCore
TorizonCore uses Plymouth splash screen running in user space. Plymouth is started from an initial minimal root file system (initramfs) very early during boot. Hence customizing the splash screen requires customizing the initramfs. TorizonCore ships with a script that allows adding a custom splash screen logo to the initramfs.
There are different phases of development with different methods for customizing the splash screen:
  • Evaluation and prototyping: you can use the convenient script ostree-customize-playmouth.sh provided in the TorizonCore image.
  • Development and production: you must use the TorizonCore Builder Tool.
Limitations​
The Apalis iMX8 does not have a splash screen on HDMI. The splash screen is only present when using the Capacitive Touch Display 10.1" LVDS with the HDMI Device Tree Overlay disabled.
Prerequisites​
  • The custom splash screen needs to be a png file with a maximum size of your screen's resolution (-32 pixel in height for the waiting animation). Typically a resolution of around 600x400 is used. Currently, the background is always black.
  • A Toradex SoM with Torizon installed.
  • A TorizonCore image downloaded.
Evaluation: Add a Custom Splash Screen Directly from TorizonCore​
Since the initramfs is stored in OSTree, customizing the splash screen requires a new OSTree commit. TorizonCore ships with the ostree-customize-plymouth.sh script which does most of the work. It requires three parameters:
# ostree-customize-plymouth.sh [splash] [ostree ref] [new ostree branch]
Being:
  • splash: the path to the png image.
  • ostree ref: the reference to the base tree from OSTree.
  • new ostree branch: the name of a new branch to which you will commit the changes.
caution
you are advised to always start from a vanilla TorizonCore OSTree reference before running the tool for the second time.
Get the Current OSTree Reference​
To get the reference to the base tree (typically the current running tree) you can use ostree admin status to display the current reference:
# ostree admin status
* torizon e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990.0
Version: 4.0.0-devel-20200218+build.118
origin refspec: e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
The value is displayed as origin refspec.
Create New OSTree Commit​
With the png in place and the base reference above a new OSTree commit with the customized initramfs can be created. See an example below that uses an image named fast-banana.png and creates a new branch named apalis-imx6/torizon/torizon-core-docker-customized:
# sudo ostree-customize-plymouth.sh fast-banana.png \
e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990 \
Deploy New OSTree Commit​
This new OSTree commit can be deployed using:
# sudo ostree admin deploy "apalis-imx6/torizon/torizon-core-docker-customized"
# sudo reboot
On reboot, you should be able to see the new splash screen showing up.
Revert to the Vanilla TorizonCore OSTree Reference​
The script ostree-customize-plymouth.sh "overwrites" the default splash screen by appending a new splash screen to the initramfs of the currently running root file system. This means that if the tool is used on an already customized root file system, the initramfs will append another splash screen, making the initramfs unnecessary larger.
Given the origin refspec from the previous example, run ostree admin switch [ostree ref] to revert to the vanilla TorizonCore OSTree reference:
# sudo ostree admin switch e0d44cf2f894bf834f7d799abeccd4ad1e5226cd1caff2324179950ca3676990
# sudo reboot
Development and Production: Add a Custom Splash Screen with TorizonCore Builder​
The TorizonCore Builder Tool is the recommended method for customizing TorizonCore.
Additional prerequisites​
Installing TorizonCore Builder​
Create and enter a working directory where your customization will be stored:
$ mkdir ~/tcbworkdir
$ cd ~/tcbworkdir
Use the setup script named tcb-env-setup.sh, available on the Toradex Github, to setup TorizonCore Builder:
$ wget https://raw.githubusercontent.com/toradex/tcb-env-setup/master/tcb-env-setup.sh
$ source tcb-env-setup.sh
For advanced usage, run source tcb-env-setup.sh -h, or see the project README.
If using Windows, you must pass extra parameters to the script when using the following commands:
tip
The setup script installs a bash completion script for TorizonCore Builder, making it possible to autocomplete commands and parameters by just pressing the TAB key.
Verify that the command torizoncore-builder is available:
$ torizoncore-builder --help
caution
Make sure to: (1) source the script, (2) every time you open a new terminal, (3) inside the working directory you have previously created. Otherwise, it will not work as intended and, most importantly, the torizoncore-builder alias will not be created properly.
Applying a Splash Screen to a Custom Image​
Approach 1: Applying a Splash Screen to a Custom Image: Using the Build Command​
TorizonCore Builder build command generates a custom TorizonCore image with the splash screen, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yml as default.
It requires a Toradex Easy Installer image of TorizonCore (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The splash screen image is passed as customization: splash-screen.
tcbuild.yaml
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert a Splash Screen
customization:
# >> Splash screen:
splash-screen: splash.png
output:
easy-installer:
The file splash.png should be available before running the build command. A demo image can be downloaded by clicking on the link below:
Example Splash Screen Image
Build The Custom Toradex Easy Installer Image​
Build The Custom Image​
To generate the TorizonCore image, run the command below, in the same directory where the tcbuild.yaml file is:
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
Deploy The Custom Toradex Easy Installer Image​
  • Through Torizon Platform Services server, the recommended method to perform updates on a device already deployed to the field.
Despite the recommendations, it is also possible to use a different method, using the Torizon Platform Services method during development for example.
Toradex Easy Installer​
Directly, through SSH​
tip
caution
Torizon Platform Services​
To deploy it to the Torizon Platform Update Service, use the command below:
caution
To deploy the image from the Torizon Platform Remote Update Service to the board, please follow the steps in the OTA Web Interface article.
To obtain credentials (credentials.zip file) and to obtain more information on how to sign and securely deploy a custom image using Torizon Platform Updates, check the Signing and pushing the image to Torizon OTA article.
Approach 2: Applying a Splash Screen to a Custom Image: Using Standalone Commands​
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom TorizonCore with the splash screen is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with different splash screens (or other customizations like different device tree overlays). As you will see, applying a splash screen to an image of TorizonCore that has other customizations is just a matter of performing the apply, merge and deploy stages.
To generate a custom Toradex Easy Installer image with the splash screen follow the sequence of steps below.
Unpack an Input Image​
You just need to execute this once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying a splash screen, you can also apply an external kernel module, a new device tree, among other possibilities.
If you have not unpacked an image yet, download a base TorizonCore image (preferably without containers) inside the TorizonCore Builder working directory, then run the command below to unpack it. In the example below the torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar image is used as a reference:
If you want to change the TorizonCore base image, download the new image and run the images unpack command again, passing the new image as the argument.
Instead of using the images unpack you can use the images download command. This command checks which is the connected Toradex SoM, downloads the compatible latest quarterly release of a TorizonCore image without containers, and unpacks this image.
Apply The Splash Screen​
To apply the splash screen file, in this case splash.png, to the custom Toradex Easy Installer image, run the command below:
/storage/splash/usr/share/plymouth/themes/spinner/
splash screen merged to initramfs
A demo splash.png image can be downloaded by clicking on the button below:
For more details about the splash command, please check the spash command in the commands manual.
Merge Changes​
Merge the splash screen (as well as other customizations like an external kernel module or a new device tree) into the base Toradex Easy Installer image of TorizonCore - use whatever branch name you want.
caution
tip
caution
Torizon Platform Remote Update Service​
To deploy it to the Torizon Platform Remote Update Service, use the command below:
caution
To obtain credentials (credentials.zip file) and to obtain more information on how to sign and securely deploy a custom image using Over-the-Air (OTA) updates, check the Signing and pushing the image to Torizon OTA article.
Verifying The New Custom Image On The Device​
After rebooting, in your target device's terminal, verify that your new custom image of TorizonCore is active on the device with the command below:
# sudo ostree admin status
Password:
