Version: 5.0
CPU (Linux)
This article shows how to enable/disable CPU cores on Toradex modules. It only applies to modules that have more than one core.
NXP i.MX-Based SoMs​
Boot-up CPU Configuration​
The Linux kernel parameter maxcpus can be used to configure the maximum SMP processors Linux should make use of. Use the U-Boot serial console to add the maxcpus boot argument:
Colibri iMX6 # setenv defargs $defargs maxcpus=1
Colibri iMX6 # saveenv
CPU Hotplugging​
The CPU hotplugging allows to enable/disable CPU cores without a system reboot, see below:
root@colibri-imx7:~# echo 0 > /sys/devices/system/cpu/cpu1/online
[ 25.213855] CPU1: shutdown
NVIDIA Tegra-Based SoMs​
Colibri T30 # setenv defargs $defargs maxcpus=1
Colibri T30 # saveenv
CPU Hotplugging​
The CPU hotplugging allows to enable/disable CPU cores without a system reboot.
Manual​
Manually turn off CPU cores:
root@colibri-t30:~# echo 0 > /sys/devices/system/cpu/cpu3/online
[ 1190.700711] CPU3: shutdown
This is only useful if automatic CPU hotplugging (mentioned below) is turned off.
Automatic​
The Linux Kernel supports automatic core aka CPU hotplugging based on the current load in order to minimize power usage.
On T30 the low-power core migration is disabled as it has some issues.
Turn off low-power core migration:
root@colibri-t30:~# echo Y > /sys/module/cpu_tegra3/parameters/no_lp
Turn on automatic CPU hotplugging:
root@colibri-t30:~# echo 1 > /sys/module/cpu_tegra3/parameters/auto_hotplug
[ 2043.597297] Tegra auto-hotplug enabled
For more information on the Tegra specific CPU hotplugging driver refer to the documentation file within the L4T Linux kernel trees: Documentation/arm/nvidia/tegra_parameters.txt resp. Documentation/arm/nvidia/tegra_parameters.txt
