Version: 5.0
Wi-Fi Cables and Antennas for Toradex Modules
Toradex offers a range of Computer on Modules (COMs) with WiFi/BlueTooth integrated:
System on ModuleProduct NumberVersion
Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth IT0037V1.0A and newer
Apalis iMX8 QuadPlus 2GB Wi-Fi / Bluetooth0048V1.0A and newer
Colibri iMX8X QuadXPlus 2GB Wi-Fi / Bluetooth IT0038V1.0A and newer
Colibri iMX8X DualX 1GB Wi-Fi / Bluetooth0051V1.0A and newer
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT0040V1.1A and newer
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth0045V1.1A and newer
Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT0055V1.0B and newer
Verdin iMX8M Mini DualLite 1GB Wi-Fi / Bluetooth IT0060V1.1A and newer
Verdin iMX8M Plus Quad 4GB Wi-Fi / Bluetooth IT0058V1.0B and newer
Wi2Wi WM828CC6 has been replaced by Azurewave AW-CM276NF on newer Toradex SoMs.
System on ModuleVersion
Colibri iMX6ULL 512MB Wi-Fi / BluetoothV1.0x
Wi-fi AdapterWi-Fi StandardsBluetooth versionAdapter's ChipsetAntenna Configuration
AzureWave AW-CM276NF802.11 a/b/g/n/ac5.0 compliant with 2.1NXP 88W8997Dual-Band 802.11ac 2x2 MU-MIMO
Wi2Wi WM828CC6802.11 a/b/g/n/ac4.2NXP 88W8887Dual-Band 802.11ac 1x1 spatial stream
This article will show RF cables and antenna recommendations for AzureWave AW-CM276NF integrated modules.
Pre-certification​
The AW-CM276NF implements the NXP 88W8997 (formerly by Marvell) Reference Design, therefore the certificates of the 88W8997 apply to the AW-CM276NF as well. The processes of certifying radio equipment vary from one region to the other. This article concentrates on the certification of the AW-CM276NF to be used in combination with the antennas listed below in the following regions: USA, Canada, European Economic Area (EEA) with Switzerland, India as well as Japan. With regards to end-devices, these certifications are to be understood as pre-certifications. Depending on the country in question, end devices might still need to undergo final testing and certification of the overall product.
Pre-certification is:​
Pre-certification measurements are carried out by an accredited laboratory. Pre-certification of the AW-CM276NF with selected Wi-Fi accessories allows customers to use combinations of those devices in a compliant way and provides additional trust that the pre-certified device combinations will not impede final certification of the respective end-devices.
Pre-certification is not:​
Pre-certification is not related to the Wi-Fi Alliance and the β€œWiFi CERTIFIED" logo found on the packaging of many Wi-Fi capable products.
List of certification status for RF cables and antennas to be used with the AW-CM276NF​
Dipole Antennas​
caution
Note that availability may vary between different regions
Dipole Antennas (Rubber Ducky)​
AntennaCable lengthUSA (FCC)Canada (IC)EEA (CE)India (WPC)Japan (TELEC)Where to buy
Chang Hong DA-2458-02-SMR-βœ”βœ”βœ”βœ”βœ”Toradex Webshop
LSR 001-0012-βœ”βœ”βœ”βœ”βœ”Mouser / Digikey
Taoglas GW.59.3153-βœ”βœ”βœ”βœ”βœ”Mouser / Digikey
Laird MAF94051-βœ”βœ”βœ”βœ”βœ”Mouser / Digikey
Dipole Antenna Cables​
The following cables are used in the pre-certification with the above-mentioned dipole antennas.
Antenna cableCable lengthWhere to buy
Antenna Cable MHF4 to RP-SMA100mmToradex Webshop
Antenna Cable MHF4 to RP-SMA200mmToradex Webshop
Antenna Cable MHF4 to RP-SMA Outdoor (IP67)200mmToradex Webshop
PCB Antennas​
Unictron H2B1PD1A1C385L100mmβœ”βœ”βœ”βœ”βœ”Toradex Webshop
Unictron H2B1PC1A1C175L100mmβœ”βœ”βœ”βœ”βœ”Unictron
Molex 146153-1100100mmβœ”βœ”βœ”βœ”βœ”Mouser / Digikey
Molex 204281-1100100mmβœ”βœ”βœ”βœ”βœ”Mouser / Digikey
