Colibri iMX8X DSI to HDMI Adapter
(Double-Click to Zoom)
Getting Started​
Some documents can refer to this product as "DSI to HDMI Adapter" instead of the full name.
This is an add-on product for the Colibri iMX8X which converts the MIPI DSI signal available on the display FFC connector (X2) of the Colibri iMX8X to an HDMI 1.4 signal. This provides pin compatibility on the HDMI interface with all Colibri SoMs providing an HDMI Interface.
What else do I need to order?​
This adapter can be ordered along with a Colibri iMX8X module.
Where do I order?​
Having trouble?​
Please contact our technical support. Various option of technical support are mentioned in the article below:
Features​
Main Features​
  • Connects directly to the HDMI FFC connector on the Colibri carrier boards using a 24-pin cable
  • Converts DSI signal into HDMI V1.4 1080p (1920x1080), 8-bit, up to 60Hz
  • Two FFC cables are included (FFC Cable 30 pin 51mm 0.5mm pitch, FFC Cable 24 pin 57mm 0.5mm pitch)
Datasheets​
Colibri iMX8X DSI to HDMI Adapter​
Colibri iMX8X DSI to HDMI Adapter Datasheet
Design Resources​
Design Data for Colibri iMX8X DSI to HDMI Adapter​
Mechanical Models​
A basic 3D model for the Colibri iMX8X DSI to HDMI Adapter can be downloaded here:
It is a generic STEP model that can be opened and modified in any 3D CAD.
It is a generic 3D pdf model that can be opened in Adobe Reader.
Altium Designer​
Compatible Products​
Revision History​
Product Number (PID8) Format
Product Numbering Scheme
FieldDescription
Example
0029: Apalis iMX6D 512MB
00: Assembly Variant A
0152 Colibri iMX8X DSI to HDMI Adapter​
01521000
Colibri iMX8X DSI to HDMI Adapter V1.0A
Initial Release
Q2 2019
01521100
Colibri iMX8X DSI to HDMI Adapter V1.1A
Fixed Errata #1: I2C address conflict with certain HDMI monitors
2019-07-12
PCN Colibri iMX8X DSI to HDMI Adapter V1.0A 2019-07-11
Errata​
Colibri iMX8X DSI to HDMI Adapter Errata
