Starting and Managing Containers with Portainer
Your progress
Portainer is a lightweight management UI that allows you to easily manage your different Docker environments.
Torizon comes with Portainer pre-loaded and it automatically starts after the module boot-up.
In this module you will:
  • Learn how to access Portainer through a web browser
  • Learn how to start a container execution using Portainer
Typographic Conventions
For this Quickstart Guide:
  • Development computer with Windows 10 version 2004 (a.k.a. May 2020 update) or higher.
Turn on the board. After boot, the Portainer login screen will be displayed on the monitor connected to the board. On the first access, it is necessary to set a username and password.
Alternatively, a host computer connected to the same network as the module can also access Portainer through a web interface. To access it, open a web browser (Chrome, Firefox, Edge) and access the address: <your-board-ip>:8840.
  • Login screen
    Login screen
Select the primary endpoint to access the board's container settings.
  • Select the primary endpoint
Step 3
Click on Containers.
  • Select Containers
    Select Containers
Step 4
Click on the button "Add container".
  • Add a new container
    Add a new container
Step 5
Type a name for your container. Type the following Docker image name: hello-world. Click on "Deploy the container".
  • New container settings
Step 6
The next screen will show the running containers. Press F5 to update the container status until your hello-world container finishes its execution and stops.
After the container stops, click on the Logs button.
  • Click on the Log button after the container stops
Step 7
See the container log. If you see the Hello from Docker! text, congratulations, your container has been successfully started from the Portainer interface.
  • Success!
    Success!
The hello-world container is only a simple container used to verify if the Docker engine is working correctly in the system and if the Portainer can start a container on the board. We will build more complex containers in the next sections.
Step 8
The image TorizonCore with evaluation containers has many different demos. Explore it by going to the App Templates section in Portainer and click on one of the templates.
  • Available Container Examples in Portainer
  • Start a template using Portainer
FAQ
I don't want to expose the Portainer service on a TCP/IP port. Can I disable it?
