Ethernet/Network (Linux)
Introductionβ
This article provides instructions on how to use utilities for network configuration provided in the Toradex BSP reference images. It contains information on how to use connman and/or systemd-networkd, or how to replace connman with NetworkManager using Yocto.
Yocto BSP Reference Imagesβ
The Toradex BSP reference images currently provide two utilities for network configuration: connman and systemd-networkd. By default, the Ethernet port is managed by connman, and the USB RNDIS interface by systemd-networkd. Depending on the application, it might make sense to use one of those utilities over the other.
By default, connman will try to configure any available network interfaces and tries to keep only (the best) connection connected at any time. The design is targeted toward interactive, wireless devices such as tablets, etc. The systemd-provided utility systemd-networkd, on the other hand, emphasizes headless server systems with static configuration.
