Toradex’s Linux Images - How to setup the Wi-Fi interface for Access Point Mode
Article updated at 08 Jul 2020
This article describes how to set up a Wi-Fi Access Point, sometimes mentioned as AP mode, using open-source software Hostapd in Embedded Linux.
Other Wi-Fi related articles
Hostapd Example
Toradex provides a package in the BSP demo images called hostapd-example which provides basically what is written in this article.
To start the AP configured in that demo image on a Toradex demo image once, enter:
systemctl start hostapd-example
If the AP should be started upon boot, enter:
systemctl enable hostapd-example
You can find the related openembedded recipe for this package in:
http://git.toradex.com/cgit/meta-toradex-demos.git/tree/recipes-connectivity/hostapd-example
First of all, make sure that the Wi-Fi adapter supports Access Point mode. You can check a list of tested modules in the 3rd Party Modules Tested with Toradex COMs section of Wi-Fi Connectivity on Toradex’s Computer on Module (CoM) article.
Note: Toradex Computer on Modules (COMs) with integrated Wi-Fi/Bluetooth supports Access Point mode
This setup was tested using the following hardware and software:
  • Embedded Linux BSP release 2.8
  • Colibri iMX6ULL 512MB WB IT V1.1A.
Instructions may vary when using other Wi-Fi adapters.
Configure AP Mode
Steps are provided for configuring AP mode.
Get the Correct Interface Name
Check current mode and available interfaces, you should see a single interface in AP mode, like this:
$ iw dev
phy#0
        Interface <IF_NAME>
                ifindex 5
                wdev 0x2
                addr d0:c5:d3:33:cd:31
                type **AP**
                txpower 0.00 dBm
Considering the test environment from Prerequisites section, the name of the AP-interface that is defined by the mwifiex kernel driver is uap0. This name can be different depending on userspace.
Configure Hostapd
Set the Access Point interface IP and SSID in Hostapd configuration file. Change the following variables in /etc/hostapd.conf:
/etc/hostapd.conf
interface=uap0 ssid=access-point hw_mode=g channel=1 own_ip_addr=192.168.8.1
An alternate hostapd.conf file that creates a WLan in the 5GHz range, protected with WPA2:
/etc/hostapd.conf
interface=uap0 ssid=testwifi hw_mode=a channel=40 ieee80211n=1 own_ip_addr=192.168.8.1 wpa=2 wpa_passphrase=MyNotSoSecretPassword1234
The hostapd.conf is documented in the default hostapd.conf file that is deployed, as well as here: https://w1.fi/cgit/hostap/plain/hostapd/hostapd.conf
To provide the Access Point interface with a static IP address and DHCP, it is necessary to create the file /etc/systemd/network/hostapd.network:
[Match] Name=<IF_NAME> [Network] Address=192.168.8.1/24 DHCPServer=yes
The Hostapd service starts by default after the network.target. This target is only loosely defined and means just "start after the network stack is up". This will fail by default because the network device (uap0 by default) is not up yet, or not every time.
To fix this we can tell systemd that the hostapd.service file is depending on a device. First step is to find out how the "*.device" file is named that is associated with the network device. This can be done with:
systemctl --all --full -t device
In our demo-image case this is named sys-subsystem-net-devices-uap0.device Edit the properties BindsTo and After from file /lib/systemd/system/hostapd.service:
BindsTo=sys-subsystem-net-devices-uap0.device After=sys-subsystem-net-devices-uap0.device
Both BindsTo and After are necessary in order to tell systemd the strong dependence that hostapd.service has on our case uap0.
Reload the systemd configuration:
systemctl --system daemon-reload
Enble Hostapd
At last, activate the following services:
$ connmanctl enable wifi
$ systemctl enable hostapd
$ systemctl start hostapd
Check the Access Point interface:
$ ip a s dev <IF_NAME>
Now you can connect to this Access Point from other Wi-Fi devices. Access Point will automatically start after reboot.
Automate Enabling Wifi
To make sure wifi is enabled at every boot you can also do a service for it. Create a service for example like this one:
/etc/systemd/system/enable-wifi.service
[Unit] Description=Enable wifi BindsTo=sys-subsystem-net-devices-uap0.device After=sys-subsystem-net-devices-uap0.device [Service] Type=oneshot ExecStart=/usr/bin/connmanctl enable wifi ExecStop= RemainAfterExit=yes [Install] WantedBy=multi-user.target
The hostapd.service can then be started After this, so change After= of hostapd.service to:
After=enable-wifi.service
Don't forget to also enable this new service:
systemctl daemon-reload
systemctl enable enable-wifi.service
Configure Internet Sharing
Once AP Mode is configured, it's a common scenario to share an internet connection from another interface. This section relies on the Internet Sharing article from the Arch Wiki.
Enable Packet Forwarding
Create a file to add the packet forwarding rules:
/etc/sysctl.d/30-ipforward.conf
net.ipv4.ip_forward=1
net.ipv6.conf.default.forwarding=1
net.ipv6.conf.all.forwarding=1
The changes will take effect after a reboot.
Enable NAT
NAT relies on kernel configuration and userspace tools. This section is thus split into two.
Kernel Configuration
For the example from this article, we have to make sure that the following kernel parameters are enabled. You have to evaluate if additional parameters are required for your use case:
CONFIG_IP_NF_IPTABLES=y
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
You will find those configs in Networking support > Networking options > Network packet filtering framework (Netfilter). See an illustration (you may click it to see in higher resolution):
  • Core Netfilter Configuration
    Core Netfilter Configuration Menu
It may be possible to compile those configs as modules - check the kernel documentation. For instructions on how to build the kernel or modules, read the article Build U-Boot and Linux Kernel from Source Code.
After the new kernel is deployed, you can verify if it has the correct configs:
zcat /proc/config.gz | grep IP_NF_IPTABLES
zcat /proc/config.gz | grep NETFILTER_XT_MATCH_CONNTRACK
iptables Configuration and Setup
You might have to enable some kernel modules, depending on your configuration.
You can use iptables to enable NAT and a systemd service to make it start on reboot. First, enable the rules for the current session:
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
iptables -A FORWARD -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT
iptables -A FORWARD -i uap0 -o eth0 -j ACCEPT
Save the current config to /etc/iptables/iptables.rules:
mkdir /etc/iptables/
iptables-save > /etc/iptables/iptables.rules
Create a systemd service file iptables.service. The example is modified from the iptables package from Arch Linux:
/lib/systemd/system/iptables.service
[Unit]
Description=IPv4 Packet Filtering Framework
Before=network-pre.target
Wants=network-pre.target
[Service]
Type=oneshot
ExecStart=/usr/sbin/iptables-restore /etc/iptables/iptables.rules
ExecReload=/usr/sbin/iptables-restore /etc/iptables/iptables.rules
RemainAfterExit=yes
[Install]
Notice that in the example above we don't have the rule to stop the service. Carefully evaluate if you need it and the best method for stopping the service, where a good starting point is the iptables package aforementioned.
Reload the systemd services and enable:
systemctl enable iptables
Enable DHCP and DNS
Some utils can enable both DHCP and DNS servers. You might want to use dhcpd or dnsmasq.
