AirPrime MC7354 - Sierra Wireless
Manufacture: Sierra Wireless
Device Type: Cellular
Interface: PCIe
Features: GNSS: Yes
GSM/GPRS/EDGE
LTE
UMTS/HSPA
Device Page
Compatible Setups
No results found.
If your setup is not listed above, the following table provides some generic setups that are expected to work with this device:
- / -Any Module (Any Version)Any Carrier Board (Any Version)Yocto (Linux) (Any) -
Mini PCIe Modems
Attention: The form factor is mini PCIe. The mini PCIe form factor standard has one USB interface. Almost always, modems with mini PCIe form factor only use the USB interface to exchange data. You must check the datasheet of the specific device for more details.
