AirPrime MC7455 - Sierra Wireless
Manufacture: Sierra Wireless
Device Type: Cellular
Interface: PCIe
Operating Temperature: -30°C to +70°C
Features: GNSS: Yes
GSM/GPRS/EDGE
LTE
UMTS/HSPA
Device Page
Compatible Setups
Rev A / -Apalis iMX6 (QM 4GB WB IT V1.0A)Ixora (QM 4GB IT V1.0B)Yocto (Linux) (2.8)
It is necessary to install NetworkManager 1.21.1 and ModemManager 1.10.1. Currently this versions are not available in the standard BSP. Please see section below for more information.
2018-08-01
Add support for MC7455 to BSP2.8b6
Add NetworkManager and ModemManager from the following meta layer:
https://github.com/toradex/meta-mc7455
A short description on how to build the image can be found in the README file.
Mini PCIe Modems
Attention: The form factor is mini PCIe. The mini PCIe form factor standard has one USB interface. Almost always, modems with mini PCIe form factor only use the USB interface to exchange data. You must check the datasheet of the specific device for more details.
