Article updated
at 08 Apr 2021
The Apalis standard provides two SPI interfaces compatible with all modules of the Apalis family.
MXM3 Pin |
Apalis Signal Name |
Description |
225 |
SPI1_MOSI |
SPI Master Output, Slave Input; SPI Data Out (DOUT) |
223 |
SPI1_MISO |
SPI Master Input, Slave Output; SPI DATA In (DIN) |
227 |
SPI1_CS |
SPI Chip Select; SPI Enable Signal; SPI Slave Select |
221 |
SPI1_CLK |
SPI Serial Clock; (SCK) |
231 |
SPI2_MOSI |
229 |
SPI2_MISO |
233 |
SPI2_CS |
235 |
SPI2_CLK |
The Colibri standard provides one SPI interface compatible with all modules of the Colibri family which historically is called Synchronous Serial Port (SSP).
SODIMM Pin |
Colibri Signal Name |
SSP Description |
SPI Description |
86 |
SSPFRM |
Synchronous Serial Port Frame |
88 |
SSPSCLK |
Synchronous Serial Port Clock |
90 |
SSPRXD |
Synchronous Serial Port Receive |
SPI Master Input / Slave Output (MISO); SPI DATA In (DIN) |
92 |
SSPTXD |
Synchronous Serial Port Transmit |
SPI Master Output / Slave Input (MOSI); SPI Data Out (DOUT) |
The Verdin standard provides one SPI interface compatible with all modules of the Verdin family.
SODIMM Pin |
Verdin Signal Name |
SPI Description |
196 |
SPI_1_CLK |
Serial Clock |
198 |
SPI_1_MISO |
Master Input, Slave Output |
200 |
SPI_1_MOSI |
Master Output, Slave Input |
202 |
SPI_1_CS |
Slave Select |
The standard SPI interfaces are enabled by default. Most modules offer additional (non-standard) SPI interfaces, to enable these device trees or board file aka platform data customization is required.
The Colibri Evaluation Board provides an MCP2515 SPI CAN controller. For Colibri modules the kernel driver for this CAN controller is active by default and no userspace SPI access is possible, i.e. the /dev/spidevA.B device files are not available. See the carrier board section for further information.
Toradex Name |
NXP/Freescale Name |
Device |
Apalis SPI1 |
ECSPI1 SS0 |
spidev0.0 |
Apalis SPI2 |
ECSPI2 SS0 |
spidev1.0 |
Toradex Name |
Device |
Apalis SPI1 |
LPSPI0 |
spidev0.0 |
Apalis SPI2 |
LPSPI2 |
spidev1.0 |
Toradex Name |
Device |
Apalis SPI1 |
LPSPI0 |
spidev0.0 |
Apalis SPI2 |
LPSPI2 |
spidev1.0 |
Toradex Name |
Device |
Colibri SSP |
ECSPI4 SS1 |
spidev3.0 |
Toradex Name |
Device |
Colibri SSP |
ECSPI1 SS0 |
spidev0.0 |
Toradex Name |
Device |
Colibri SSP |
ECSPI2 SS0 |
spidev2.0 |
Toradex Name |
Device |
Colibri SSP |
LPSPI2 |
spidev0.0 |
Toradex Name |
NVIDIA Name |
Device |
Colibri SSP |
SPI4 CS0 |
spidev3.0 |
Toradex Name |
NVIDIA Name |
Device |
Colibri SSP |
SPI1A CS0 |
spidev0.0 |
Toradex Name |
Device |
Colibri SSP |
SPI1 PCS0 |
spidev1.0 |
Toradex Name |
Device |
Note |
Verdin SPI_1 |
ECSPI1 |
spidev1.0 |
By default our BSPs use the MCP2515 SPI CAN controller as available on our Colibri Evaluation board V3.x. In order to use spidev instead one needs to disable (e.g. status = "disabled") the mcp2515 device tree node and enable (e.g. status = "okay") the spidev one and re-generate and deploy the device tree to the target. The specific changes are outlined below, as an example, the device tree for a Colibri iMX7 is given:
diff --git a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
index 1db5aa5..28a8bc7 100644
--- a/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
+++ b/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
@@ -101,14 +101,14 @@
interrupt-parent = <&gpio5>;
interrupts = <2 IRQ_TYPE_EDGE_FALLING>;
spi-max-frequency = <10000000>;
- status = "okay";
+ status = "disabled";
spidev0: spidev@0 {
compatible = "toradex,evalspi";
reg = <0>;
spi-max-frequency = <23000000>;
- status = "disabled";
+ status = "okay";
Aster doesn't include the mcp2515 SPI CAN controller, so spidev is enabled by default. As SPI is accessible on both X18 and X20 two chip selects are configured, one for the X18 connector and the other one for the X20 connector.
Thus two spidev devices appear, for a Colibri iMX7 e.g. spidev2.0 CS signal is available on X18 ONLY, and spidev2.1 CS signal is available on X20 ONLY. Refer to the following table:
SODIMM Pin |
Signal |
X18 pin |
X20 pin |
86 |
SSPFRM |
CS0 |
3 |
65 |
CIF_D9 |
CS1 |
24 |
88 |
SSPSCLK |
CLK |
6 |
23 |
90 |
SSPRXD |
MISO |
5 |
21 |
92 |
SSPTXD |
MOSI |
4 |
19 |
SPI access from user-space is provided through the spidev driver which exports device files under /dev. See Documentation/spi/spidev in the kernel sources for more information.
The following shows a read of an ADC082S021 using the sample code in the kernel sources (Documentation/spi/spidev_test.c) using spidev interface:
# ./spidevtest -D /dev/spidevB.C
spi mode: 0
bits per word: 8
max speed: 500000 Hz (500 KHz)
02 E0 00 00 00 00
00 00 02 E0 02 E0
02 E0 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00 00 00 00 00
00 00
The Linux kernel already provides drivers for various SPI devices, hence before writing your own driver checking your Linux kernels configuration options and/or searching through the kernel mailing list is best practice.
If you plan to write an SPI device driver you can use the SPI MCP2515 CAN controller driver as an example. The MCP2515 CAN controller is available and connected to the Colibri SPI port on the v3 series of the Colibri Evaluation Board.
By default, the regular SPI interface is configured for 3 MHz operation. The sbc4 clock which is four times the SPI clock is configured for 12 MHz operation with pll_p as its parent. As the divider between its parent and sbc4 only supports 7.1 bits (e.g. 7 bits of mantissa and 1 bit of fraction) and pll_p runs at 216 MHz the lowest possible SPI clock in that configuration lays somewhere around 424 kHz. If a lower clock is desired one has to choose another parent clock like clk_m operating at 13 MHz. This allows SPI clocks as low as 25 kHz. In the Linux kernel sources that configuration can be found here.
As follows some clock tree excerpts for a few use-cases:
DEFAULT spidev configuration
clk_m on 11 13000000
pll_p on 11 x16.6.. 216000000
sbc4 off 0 18 12000000
MCP2515 CAN configuration
sbc4 off 0 5.5 39272727
=> 9.830 MHz measured at SSP_SCLK pin
sbc4 off 0 127.5 1694117
=> 423.6 kHz measured at SSP_SCLK pin
sbc4 off 0 65 200000
=> 50 kHz measured at SSP_SCLK pin
