GPIO Alphanumeric to GPIO Numeric Assignment
This article describes the relationship between a SOC's GPIO Name and GPIO number used in various SW APIs.
Most pins on a SOC can be configured for different functions, one of them GPIO.
A SOC pin has an alphanumeric name, the GPIO functionality usually has an alphanumeric name and in the SW APIs the GPIO is often referenced as a number.
To make matters more complicated the SOC pin is then routed to the modules connector and gets an additional module pin name and number.
The WinCE GPIOLib.h provides a MACRO for the conversion from alphanumeric to numbers (TEGRA_GPIONUM). We recommend to use the SODIMM pin number instead of GPIO Numbers for better compatibility with other Colibri modules when ever possible.
The Linux kernel uses the numeric-only representation in its GPIO subsystem and in the sysfs interface to the GPIO functionality.
E.g. on a Colibri T20 the T20 pin SDIO3_DAT0 has the following relationships.
Module Pin Name | Module Pin Number | SOC Pin Name | SOC GPIO Name | GPIO number |
GPIO: PS2.SCL1 SODIMM_63 | 63 | SDIO3_DAT0 | B7 | 15 |
The relationship between Module Pin Name / Module Pin Number / SOC Pin Name / SOC GPIO Name can be found in the modules datasheet.
The i.MX 8 modules have GPIO controllers which can control up to 32 GPIOs.
The GPIO names are formed "LSIO.GPIO<controller>.IO<gpio>" with controller in 0..6 and gpio in 00..31.
E.g. a GPIO function could be named LSIO.GPIO2.IO04.
The numeric value is calculated as follows:
480 - 32 x controller + gpio
E.g. LSIO.GPIO0.IO00 becomes 480, LSIO.GPIO2.IO04 becomes 420.
You must find the correspondence between GPIO and the edge connector pin (X1) that you want to use in the CoM datasheet. A good place to start is the SoC Function List:
Apalis iMX8 GPIO table
this table is automatically generated from the formula above. Some of the GPIO lines from the table may not be available in a specific Toradex SoM or NXP SoC.
Gpio | Numeric Representation |
LSIO.GPIO00.IO00 | 480 |
LSIO.GPIO00.IO01 | 481 |
LSIO.GPIO00.IO02 | 482 |
LSIO.GPIO00.IO03 | 483 |
LSIO.GPIO00.IO04 | 484 |
LSIO.GPIO00.IO05 | 485 |
LSIO.GPIO00.IO06 | 486 |
LSIO.GPIO00.IO07 | 487 |
LSIO.GPIO00.IO08 | 488 |
LSIO.GPIO00.IO09 | 489 |
LSIO.GPIO00.IO10 | 490 |
LSIO.GPIO00.IO11 | 491 |
LSIO.GPIO00.IO12 | 492 |
LSIO.GPIO00.IO13 | 493 |
LSIO.GPIO00.IO14 | 494 |
LSIO.GPIO00.IO15 | 495 |
LSIO.GPIO00.IO16 | 496 |
LSIO.GPIO00.IO17 | 497 |
LSIO.GPIO00.IO18 | 498 |
LSIO.GPIO00.IO19 | 499 |
LSIO.GPIO00.IO20 | 500 |
LSIO.GPIO00.IO21 | 501 |
LSIO.GPIO00.IO22 | 502 |
LSIO.GPIO00.IO23 | 503 |
LSIO.GPIO00.IO24 | 504 |
LSIO.GPIO00.IO25 | 505 |
LSIO.GPIO00.IO26 | 506 |
LSIO.GPIO00.IO27 | 507 |
LSIO.GPIO00.IO28 | 508 |
LSIO.GPIO00.IO29 | 509 |
LSIO.GPIO00.IO30 | 510 |
LSIO.GPIO00.IO31 | 511 |
LSIO.GPIO01.IO00 | 448 |
LSIO.GPIO01.IO01 | 449 |
LSIO.GPIO01.IO02 | 450 |
LSIO.GPIO01.IO03 | 451 |
LSIO.GPIO01.IO04 | 452 |
LSIO.GPIO01.IO05 | 453 |
LSIO.GPIO01.IO06 | 454 |
LSIO.GPIO01.IO07 | 455 |
LSIO.GPIO01.IO08 | 456 |
LSIO.GPIO01.IO09 | 457 |
LSIO.GPIO01.IO10 | 458 |
LSIO.GPIO01.IO11 | 459 |
LSIO.GPIO01.IO12 | 460 |
LSIO.GPIO01.IO13 | 461 |
LSIO.GPIO01.IO14 | 462 |
LSIO.GPIO01.IO15 | 463 |
LSIO.GPIO01.IO16 | 464 |
LSIO.GPIO01.IO17 | 465 |
LSIO.GPIO01.IO18 | 466 |
LSIO.GPIO01.IO19 | 467 |
LSIO.GPIO01.IO20 | 468 |
LSIO.GPIO01.IO21 | 469 |
LSIO.GPIO01.IO22 | 470 |
LSIO.GPIO01.IO23 | 471 |
LSIO.GPIO01.IO24 | 472 |
LSIO.GPIO01.IO25 | 473 |
LSIO.GPIO01.IO26 | 474 |
LSIO.GPIO01.IO27 | 475 |
LSIO.GPIO01.IO28 | 476 |
LSIO.GPIO01.IO29 | 477 |
LSIO.GPIO01.IO30 | 478 |
LSIO.GPIO01.IO31 | 479 |
LSIO.GPIO02.IO00 | 416 |
LSIO.GPIO02.IO01 | 417 |
LSIO.GPIO02.IO02 | 418 |
LSIO.GPIO02.IO03 | 419 |
LSIO.GPIO02.IO04 | 420 |
LSIO.GPIO02.IO05 | 421 |
LSIO.GPIO02.IO06 | 422 |
LSIO.GPIO02.IO07 | 423 |
LSIO.GPIO02.IO08 | 424 |
LSIO.GPIO02.IO09 | 425 |
LSIO.GPIO02.IO10 | 426 |
LSIO.GPIO02.IO11 | 427 |
LSIO.GPIO02.IO12 | 428 |
LSIO.GPIO02.IO13 | 429 |
LSIO.GPIO02.IO14 | 430 |
LSIO.GPIO02.IO15 | 431 |
LSIO.GPIO02.IO16 | 432 |
LSIO.GPIO02.IO17 | 433 |
LSIO.GPIO02.IO18 | 434 |
LSIO.GPIO02.IO19 | 435 |
LSIO.GPIO02.IO20 | 436 |
LSIO.GPIO02.IO21 | 437 |
LSIO.GPIO02.IO22 | 438 |
LSIO.GPIO02.IO23 | 439 |
LSIO.GPIO02.IO24 | 440 |
LSIO.GPIO02.IO25 | 441 |
LSIO.GPIO02.IO26 | 442 |
LSIO.GPIO02.IO27 | 443 |
LSIO.GPIO02.IO28 | 444 |
LSIO.GPIO02.IO29 | 445 |
LSIO.GPIO02.IO30 | 446 |
LSIO.GPIO02.IO31 | 447 |
LSIO.GPIO03.IO00 | 384 |
LSIO.GPIO03.IO01 | 385 |
LSIO.GPIO03.IO02 | 386 |
LSIO.GPIO03.IO03 | 387 |
LSIO.GPIO03.IO04 | 388 |
LSIO.GPIO03.IO05 | 389 |
LSIO.GPIO03.IO06 | 390 |
LSIO.GPIO03.IO07 | 391 |
LSIO.GPIO03.IO08 | 392 |
LSIO.GPIO03.IO09 | 393 |
LSIO.GPIO03.IO10 | 394 |
LSIO.GPIO03.IO11 | 395 |
LSIO.GPIO03.IO12 | 396 |
LSIO.GPIO03.IO13 | 397 |
LSIO.GPIO03.IO14 | 398 |
LSIO.GPIO03.IO15 | 399 |
LSIO.GPIO03.IO16 | 400 |
LSIO.GPIO03.IO17 | 401 |
LSIO.GPIO03.IO18 | 402 |
LSIO.GPIO03.IO19 | 403 |
LSIO.GPIO03.IO20 | 404 |
LSIO.GPIO03.IO21 | 405 |
LSIO.GPIO03.IO22 | 406 |
LSIO.GPIO03.IO23 | 407 |
LSIO.GPIO03.IO24 | 408 |
LSIO.GPIO03.IO25 | 409 |
LSIO.GPIO03.IO26 | 410 |
LSIO.GPIO03.IO27 | 411 |
LSIO.GPIO03.IO28 | 412 |
LSIO.GPIO03.IO29 | 413 |
LSIO.GPIO03.IO30 | 414 |
LSIO.GPIO03.IO31 | 415 |
LSIO.GPIO04.IO00 | 352 |
LSIO.GPIO04.IO01 | 353 |
LSIO.GPIO04.IO02 | 354 |
LSIO.GPIO04.IO03 | 355 |
LSIO.GPIO04.IO04 | 356 |
LSIO.GPIO04.IO05 | 357 |
LSIO.GPIO04.IO06 | 358 |
LSIO.GPIO04.IO07 | 359 |
LSIO.GPIO04.IO08 | 360 |
LSIO.GPIO04.IO09 | 361 |
LSIO.GPIO04.IO10 | 362 |
LSIO.GPIO04.IO11 | 363 |
LSIO.GPIO04.IO12 | 364 |
LSIO.GPIO04.IO13 | 365 |
LSIO.GPIO04.IO14 | 366 |
LSIO.GPIO04.IO15 | 367 |
LSIO.GPIO04.IO16 | 368 |
LSIO.GPIO04.IO17 | 369 |
LSIO.GPIO04.IO18 | 370 |
LSIO.GPIO04.IO19 | 371 |
LSIO.GPIO04.IO20 | 372 |
LSIO.GPIO04.IO21 | 373 |
LSIO.GPIO04.IO22 | 374 |
LSIO.GPIO04.IO23 | 375 |
LSIO.GPIO04.IO24 | 376 |
LSIO.GPIO04.IO25 | 377 |
LSIO.GPIO04.IO26 | 378 |
LSIO.GPIO04.IO27 | 379 |
LSIO.GPIO04.IO28 | 380 |
LSIO.GPIO04.IO29 | 381 |
LSIO.GPIO04.IO30 | 382 |
LSIO.GPIO04.IO31 | 383 |
LSIO.GPIO05.IO00 | 320 |
LSIO.GPIO05.IO01 | 321 |
LSIO.GPIO05.IO02 | 322 |
LSIO.GPIO05.IO03 | 323 |
LSIO.GPIO05.IO04 | 324 |
LSIO.GPIO05.IO05 | 325 |
LSIO.GPIO05.IO06 | 326 |
LSIO.GPIO05.IO07 | 327 |
LSIO.GPIO05.IO08 | 328 |
LSIO.GPIO05.IO09 | 329 |
LSIO.GPIO05.IO10 | 330 |
LSIO.GPIO05.IO11 | 331 |
LSIO.GPIO05.IO12 | 332 |
LSIO.GPIO05.IO13 | 333 |
LSIO.GPIO05.IO14 | 334 |
LSIO.GPIO05.IO15 | 335 |
LSIO.GPIO05.IO16 | 336 |
LSIO.GPIO05.IO17 | 337 |
LSIO.GPIO05.IO18 | 338 |
LSIO.GPIO05.IO19 | 339 |
LSIO.GPIO05.IO20 | 340 |
LSIO.GPIO05.IO21 | 341 |
LSIO.GPIO05.IO22 | 342 |
LSIO.GPIO05.IO23 | 343 |
LSIO.GPIO05.IO24 | 344 |
LSIO.GPIO05.IO25 | 345 |
LSIO.GPIO05.IO26 | 346 |
LSIO.GPIO05.IO27 | 347 |
LSIO.GPIO05.IO28 | 348 |
LSIO.GPIO05.IO29 | 349 |
LSIO.GPIO05.IO30 | 350 |
LSIO.GPIO05.IO31 | 351 |
LSIO.GPIO06.IO00 | 288 |
LSIO.GPIO06.IO01 | 289 |
LSIO.GPIO06.IO02 | 290 |
LSIO.GPIO06.IO03 | 291 |
LSIO.GPIO06.IO04 | 292 |
LSIO.GPIO06.IO05 | 293 |
LSIO.GPIO06.IO06 | 294 |
LSIO.GPIO06.IO07 | 295 |
LSIO.GPIO06.IO08 | 296 |
LSIO.GPIO06.IO09 | 297 |
LSIO.GPIO06.IO10 | 298 |
LSIO.GPIO06.IO11 | 299 |
LSIO.GPIO06.IO12 | 300 |
LSIO.GPIO06.IO13 | 301 |
LSIO.GPIO06.IO14 | 302 |
LSIO.GPIO06.IO15 | 303 |
LSIO.GPIO06.IO16 | 304 |
LSIO.GPIO06.IO17 | 305 |
LSIO.GPIO06.IO18 | 306 |
LSIO.GPIO06.IO19 | 307 |
LSIO.GPIO06.IO20 | 308 |
LSIO.GPIO06.IO21 | 309 |
LSIO.GPIO06.IO22 | 310 |
LSIO.GPIO06.IO23 | 311 |
LSIO.GPIO06.IO24 | 312 |
LSIO.GPIO06.IO25 | 313 |
LSIO.GPIO06.IO26 | 314 |
LSIO.GPIO06.IO27 | 315 |
LSIO.GPIO06.IO28 | 316 |
LSIO.GPIO06.IO29 | 317 |
LSIO.GPIO06.IO30 | 318 |
LSIO.GPIO06.IO31 | 319 |
The i.MX 8X modules have GPIO controllers which can control up to 32 GPIOs.
E.g. LSIO.GPIO0.IO00 becomes 0, LSIO.GPIO2.IO04 becomes 68.
Colibri iMX8X GPIO table
LSIO.GPIO00.IO00 | 0 |
LSIO.GPIO00.IO01 | 1 |
LSIO.GPIO00.IO02 | 2 |
LSIO.GPIO00.IO03 | 3 |
LSIO.GPIO00.IO04 | 4 |
LSIO.GPIO00.IO05 | 5 |
LSIO.GPIO00.IO06 | 6 |
LSIO.GPIO00.IO07 | 7 |
LSIO.GPIO00.IO08 | 8 |
LSIO.GPIO00.IO09 | 9 |
LSIO.GPIO00.IO10 | 10 |
LSIO.GPIO00.IO11 | 11 |
LSIO.GPIO00.IO12 | 12 |
LSIO.GPIO00.IO13 | 13 |
LSIO.GPIO00.IO14 | 14 |
LSIO.GPIO00.IO15 | 15 |
LSIO.GPIO00.IO16 | 16 |
LSIO.GPIO00.IO17 | 17 |
LSIO.GPIO00.IO18 | 18 |
LSIO.GPIO00.IO19 | 19 |
LSIO.GPIO00.IO20 | 20 |
LSIO.GPIO00.IO21 | 21 |
LSIO.GPIO00.IO22 | 22 |
LSIO.GPIO00.IO23 | 23 |
LSIO.GPIO00.IO24 | 24 |
LSIO.GPIO00.IO25 | 25 |
LSIO.GPIO00.IO26 | 26 |
LSIO.GPIO00.IO27 | 27 |
LSIO.GPIO00.IO28 | 28 |
LSIO.GPIO00.IO29 | 29 |
LSIO.GPIO00.IO30 | 30 |
LSIO.GPIO00.IO31 | 31 |
LSIO.GPIO01.IO00 | 32 |
LSIO.GPIO01.IO01 | 33 |
LSIO.GPIO01.IO02 | 34 |
LSIO.GPIO01.IO03 | 35 |
LSIO.GPIO01.IO04 | 36 |
LSIO.GPIO01.IO05 | 37 |
LSIO.GPIO01.IO06 | 38 |
LSIO.GPIO01.IO07 | 39 |
LSIO.GPIO01.IO08 | 40 |
LSIO.GPIO01.IO09 | 41 |
LSIO.GPIO01.IO10 | 42 |
LSIO.GPIO01.IO11 | 43 |
LSIO.GPIO01.IO12 | 44 |
LSIO.GPIO01.IO13 | 45 |
LSIO.GPIO01.IO14 | 46 |
LSIO.GPIO01.IO15 | 47 |
LSIO.GPIO01.IO16 | 48 |
LSIO.GPIO01.IO17 | 49 |
LSIO.GPIO01.IO18 | 50 |
LSIO.GPIO01.IO19 | 51 |
LSIO.GPIO01.IO20 | 52 |
LSIO.GPIO01.IO21 | 53 |
LSIO.GPIO01.IO22 | 54 |
LSIO.GPIO01.IO23 | 55 |
LSIO.GPIO01.IO24 | 56 |
LSIO.GPIO01.IO25 | 57 |
LSIO.GPIO01.IO26 | 58 |
LSIO.GPIO01.IO27 | 59 |
LSIO.GPIO01.IO28 | 60 |
LSIO.GPIO01.IO29 | 61 |
LSIO.GPIO01.IO30 | 62 |
LSIO.GPIO01.IO31 | 63 |
LSIO.GPIO02.IO00 | 64 |
LSIO.GPIO02.IO01 | 65 |
LSIO.GPIO02.IO02 | 66 |
LSIO.GPIO02.IO03 | 67 |
LSIO.GPIO02.IO04 | 68 |
LSIO.GPIO02.IO05 | 69 |
LSIO.GPIO02.IO06 | 70 |
LSIO.GPIO02.IO07 | 71 |
LSIO.GPIO02.IO08 | 72 |
LSIO.GPIO02.IO09 | 73 |
LSIO.GPIO02.IO10 | 74 |
LSIO.GPIO02.IO11 | 75 |
LSIO.GPIO02.IO12 | 76 |
LSIO.GPIO02.IO13 | 77 |
LSIO.GPIO02.IO14 | 78 |
LSIO.GPIO02.IO15 | 79 |
LSIO.GPIO02.IO16 | 80 |
LSIO.GPIO02.IO17 | 81 |
LSIO.GPIO02.IO18 | 82 |
LSIO.GPIO02.IO19 | 83 |
LSIO.GPIO02.IO20 | 84 |
LSIO.GPIO02.IO21 | 85 |
LSIO.GPIO02.IO22 | 86 |
LSIO.GPIO02.IO23 | 87 |
LSIO.GPIO02.IO24 | 88 |
LSIO.GPIO02.IO25 | 89 |
LSIO.GPIO02.IO26 | 90 |
LSIO.GPIO02.IO27 | 91 |
LSIO.GPIO02.IO28 | 92 |
LSIO.GPIO02.IO29 | 93 |
LSIO.GPIO02.IO30 | 94 |
LSIO.GPIO02.IO31 | 95 |
LSIO.GPIO03.IO00 | 96 |
LSIO.GPIO03.IO01 | 97 |
LSIO.GPIO03.IO02 | 98 |
LSIO.GPIO03.IO03 | 99 |
LSIO.GPIO03.IO04 | 100 |
LSIO.GPIO03.IO05 | 101 |
LSIO.GPIO03.IO06 | 102 |
LSIO.GPIO03.IO07 | 103 |
LSIO.GPIO03.IO08 | 104 |
LSIO.GPIO03.IO09 | 105 |
LSIO.GPIO03.IO10 | 106 |
LSIO.GPIO03.IO11 | 107 |
LSIO.GPIO03.IO12 | 108 |
LSIO.GPIO03.IO13 | 109 |
LSIO.GPIO03.IO14 | 110 |
LSIO.GPIO03.IO15 | 111 |
LSIO.GPIO03.IO16 | 112 |
LSIO.GPIO03.IO17 | 113 |
LSIO.GPIO03.IO18 | 114 |
LSIO.GPIO03.IO19 | 115 |
LSIO.GPIO03.IO20 | 116 |
LSIO.GPIO03.IO21 | 117 |
LSIO.GPIO03.IO22 | 118 |
LSIO.GPIO03.IO23 | 119 |
LSIO.GPIO03.IO24 | 120 |
LSIO.GPIO03.IO25 | 121 |
LSIO.GPIO03.IO26 | 122 |
LSIO.GPIO03.IO27 | 123 |
LSIO.GPIO03.IO28 | 124 |
LSIO.GPIO03.IO29 | 125 |
LSIO.GPIO03.IO30 | 126 |
LSIO.GPIO03.IO31 | 127 |
LSIO.GPIO04.IO00 | 128 |
LSIO.GPIO04.IO01 | 129 |
LSIO.GPIO04.IO02 | 130 |
LSIO.GPIO04.IO03 | 131 |
LSIO.GPIO04.IO04 | 132 |
LSIO.GPIO04.IO05 | 133 |
LSIO.GPIO04.IO06 | 134 |
LSIO.GPIO04.IO07 | 135 |
LSIO.GPIO04.IO08 | 136 |
LSIO.GPIO04.IO09 | 137 |
LSIO.GPIO04.IO10 | 138 |
LSIO.GPIO04.IO11 | 139 |
LSIO.GPIO04.IO12 | 140 |
LSIO.GPIO04.IO13 | 141 |
LSIO.GPIO04.IO14 | 142 |
LSIO.GPIO04.IO15 | 143 |
LSIO.GPIO04.IO16 | 144 |
LSIO.GPIO04.IO17 | 145 |
LSIO.GPIO04.IO18 | 146 |
LSIO.GPIO04.IO19 | 147 |
LSIO.GPIO04.IO20 | 148 |
LSIO.GPIO04.IO21 | 149 |
LSIO.GPIO04.IO22 | 150 |
LSIO.GPIO04.IO23 | 151 |
LSIO.GPIO04.IO24 | 152 |
LSIO.GPIO04.IO25 | 153 |
LSIO.GPIO04.IO26 | 154 |
LSIO.GPIO04.IO27 | 155 |
LSIO.GPIO04.IO28 | 156 |
LSIO.GPIO04.IO29 | 157 |
LSIO.GPIO04.IO30 | 158 |
LSIO.GPIO04.IO31 | 159 |
LSIO.GPIO05.IO00 | 160 |
LSIO.GPIO05.IO01 | 161 |
LSIO.GPIO05.IO02 | 162 |
LSIO.GPIO05.IO03 | 163 |
LSIO.GPIO05.IO04 | 164 |
LSIO.GPIO05.IO05 | 165 |
LSIO.GPIO05.IO06 | 166 |
LSIO.GPIO05.IO07 | 167 |
LSIO.GPIO05.IO08 | 168 |
LSIO.GPIO05.IO09 | 169 |
LSIO.GPIO05.IO10 | 170 |
LSIO.GPIO05.IO11 | 171 |
LSIO.GPIO05.IO12 | 172 |
LSIO.GPIO05.IO13 | 173 |
LSIO.GPIO05.IO14 | 174 |
LSIO.GPIO05.IO15 | 175 |
LSIO.GPIO05.IO16 | 176 |
LSIO.GPIO05.IO17 | 177 |
LSIO.GPIO05.IO18 | 178 |
LSIO.GPIO05.IO19 | 179 |
LSIO.GPIO05.IO20 | 180 |
LSIO.GPIO05.IO21 | 181 |
LSIO.GPIO05.IO22 | 182 |
LSIO.GPIO05.IO23 | 183 |
LSIO.GPIO05.IO24 | 184 |
LSIO.GPIO05.IO25 | 185 |
LSIO.GPIO05.IO26 | 186 |
LSIO.GPIO05.IO27 | 187 |
LSIO.GPIO05.IO28 | 188 |
LSIO.GPIO05.IO29 | 189 |
LSIO.GPIO05.IO30 | 190 |
LSIO.GPIO05.IO31 | 191 |
LSIO.GPIO06.IO00 | 192 |
LSIO.GPIO06.IO01 | 193 |
LSIO.GPIO06.IO02 | 194 |
LSIO.GPIO06.IO03 | 195 |
LSIO.GPIO06.IO04 | 196 |
LSIO.GPIO06.IO05 | 197 |
LSIO.GPIO06.IO06 | 198 |
LSIO.GPIO06.IO07 | 199 |
LSIO.GPIO06.IO08 | 200 |
LSIO.GPIO06.IO09 | 201 |
LSIO.GPIO06.IO10 | 202 |
LSIO.GPIO06.IO11 | 203 |
LSIO.GPIO06.IO12 | 204 |
LSIO.GPIO06.IO13 | 205 |
LSIO.GPIO06.IO14 | 206 |
LSIO.GPIO06.IO15 | 207 |
LSIO.GPIO06.IO16 | 208 |
LSIO.GPIO06.IO17 | 209 |
LSIO.GPIO06.IO18 | 210 |
LSIO.GPIO06.IO19 | 211 |
LSIO.GPIO06.IO20 | 212 |
LSIO.GPIO06.IO21 | 213 |
LSIO.GPIO06.IO22 | 214 |
LSIO.GPIO06.IO23 | 215 |
LSIO.GPIO06.IO24 | 216 |
LSIO.GPIO06.IO25 | 217 |
LSIO.GPIO06.IO26 | 218 |
LSIO.GPIO06.IO27 | 219 |
LSIO.GPIO06.IO28 | 220 |
LSIO.GPIO06.IO29 | 221 |
LSIO.GPIO06.IO30 | 222 |
LSIO.GPIO06.IO31 | 223 |
The i.MX 6/6ULL/7/8M Mini/8M Plus modules have GPIO controllers which can control up to 32 GPIOs.
The GPIO names are formed "GPIO<controller>_IO<gpio>" or "gpio<controller>.IO[<gpio>]" with controller in 1..7 and gpio in 00..31.
E.g. a GPIO function could be named GPIO2_IO04
or gpio2.IO04
, depending on the processor.
32 x (controller- 1) + gpio
E.g. GPIO1_IO00 becomes 0, GPIO2_IO04 becomes 36.
Note that not all GPIO controllers provide all 32 possible GPIOs, so the list has gaps.
iMX6, iMX6ULL, iMX7, iMX8M Mini/Plus GPIO table
GPIO1_IO00 | 0 |
GPIO1_IO01 | 1 |
GPIO1_IO02 | 2 |
GPIO1_IO03 | 3 |
GPIO1_IO04 | 4 |
GPIO1_IO05 | 5 |
GPIO1_IO06 | 6 |
GPIO1_IO07 | 7 |
GPIO1_IO08 | 8 |
GPIO1_IO09 | 9 |
GPIO1_IO10 | 10 |
GPIO1_IO11 | 11 |
GPIO1_IO12 | 12 |
GPIO1_IO13 | 13 |
GPIO1_IO14 | 14 |
GPIO1_IO15 | 15 |
GPIO1_IO16 | 16 |
GPIO1_IO17 | 17 |
GPIO1_IO18 | 18 |
GPIO1_IO19 | 19 |
GPIO1_IO20 | 20 |
GPIO1_IO21 | 21 |
GPIO1_IO22 | 22 |
GPIO1_IO23 | 23 |
GPIO1_IO24 | 24 |
GPIO1_IO25 | 25 |
GPIO1_IO26 | 26 |
GPIO1_IO27 | 27 |
GPIO1_IO28 | 28 |
GPIO1_IO29 | 29 |
GPIO1_IO30 | 30 |
GPIO1_IO31 | 31 |
GPIO2_IO00 | 32 |
GPIO2_IO01 | 33 |
GPIO2_IO02 | 34 |
GPIO2_IO03 | 35 |
GPIO2_IO04 | 36 |
GPIO2_IO05 | 37 |
GPIO2_IO06 | 38 |
GPIO2_IO07 | 39 |
GPIO2_IO08 | 40 |
GPIO2_IO09 | 41 |
GPIO2_IO10 | 42 |
GPIO2_IO11 | 43 |
GPIO2_IO12 | 44 |
GPIO2_IO13 | 45 |
GPIO2_IO14 | 46 |
GPIO2_IO15 | 47 |
GPIO2_IO16 | 48 |
GPIO2_IO17 | 49 |
GPIO2_IO18 | 50 |
GPIO2_IO19 | 51 |
GPIO2_IO20 | 52 |
GPIO2_IO21 | 53 |
GPIO2_IO22 | 54 |
GPIO2_IO23 | 55 |
GPIO2_IO24 | 56 |
GPIO2_IO25 | 57 |
GPIO2_IO26 | 58 |
GPIO2_IO27 | 59 |
GPIO2_IO28 | 60 |
GPIO2_IO29 | 61 |
GPIO2_IO30 | 62 |
GPIO2_IO31 | 63 |
GPIO3_IO00 | 64 |
GPIO3_IO01 | 65 |
GPIO3_IO02 | 66 |
GPIO3_IO03 | 67 |
GPIO3_IO04 | 68 |
GPIO3_IO05 | 69 |
GPIO3_IO06 | 70 |
GPIO3_IO07 | 71 |
GPIO3_IO08 | 72 |
GPIO3_IO09 | 73 |
GPIO3_IO10 | 74 |
GPIO3_IO11 | 75 |
GPIO3_IO12 | 76 |
GPIO3_IO13 | 77 |
GPIO3_IO14 | 78 |
GPIO3_IO15 | 79 |
GPIO3_IO16 | 80 |
GPIO3_IO17 | 81 |
GPIO3_IO18 | 82 |
GPIO3_IO19 | 83 |
GPIO3_IO20 | 84 |
GPIO3_IO21 | 85 |
GPIO3_IO22 | 86 |
GPIO3_IO23 | 87 |
GPIO3_IO24 | 88 |
GPIO3_IO25 | 89 |
GPIO3_IO26 | 90 |
GPIO3_IO27 | 91 |
GPIO3_IO28 | 92 |
GPIO3_IO29 | 93 |
GPIO3_IO30 | 94 |
GPIO3_IO31 | 95 |
GPIO4_IO05 | 101 |
GPIO4_IO06 | 102 |
GPIO4_IO07 | 103 |
GPIO4_IO08 | 104 |
GPIO4_IO09 | 105 |
GPIO4_IO10 | 106 |
GPIO4_IO11 | 107 |
GPIO4_IO12 | 108 |
GPIO4_IO13 | 109 |
GPIO4_IO14 | 110 |
GPIO4_IO15 | 111 |
GPIO4_IO16 | 112 |
GPIO4_IO17 | 113 |
GPIO4_IO18 | 114 |
GPIO4_IO19 | 115 |
GPIO4_IO20 | 116 |
GPIO4_IO21 | 117 |
GPIO4_IO22 | 118 |
GPIO4_IO23 | 119 |
GPIO4_IO24 | 120 |
GPIO4_IO25 | 121 |
GPIO4_IO26 | 122 |
GPIO4_IO27 | 123 |
GPIO4_IO28 | 124 |
GPIO4_IO29 | 125 |
GPIO4_IO30 | 126 |
GPIO4_IO31 | 127 |
GPIO5_IO00 | 128 |
GPIO5_IO02 | 130 |
GPIO5_IO04 | 132 |
GPIO5_IO05 | 133 |
GPIO5_IO06 | 134 |
GPIO5_IO07 | 135 |
GPIO5_IO08 | 136 |
GPIO5_IO09 | 137 |
GPIO5_IO10 | 138 |
GPIO5_IO11 | 139 |
GPIO5_IO12 | 140 |
GPIO5_IO13 | 141 |
GPIO5_IO14 | 142 |
GPIO5_IO15 | 143 |
GPIO5_IO16 | 144 |
GPIO5_IO17 | 145 |
GPIO5_IO18 | 146 |
GPIO5_IO19 | 147 |
GPIO5_IO20 | 148 |
GPIO5_IO21 | 149 |
GPIO5_IO22 | 150 |
GPIO5_IO23 | 151 |
GPIO5_IO24 | 152 |
GPIO5_IO25 | 153 |
GPIO5_IO26 | 154 |
GPIO5_IO27 | 155 |
GPIO5_IO28 | 156 |
GPIO5_IO29 | 157 |
GPIO5_IO30 | 158 |
GPIO5_IO31 | 159 |
GPIO6_IO00 | 160 |
GPIO6_IO01 | 161 |
GPIO6_IO02 | 162 |
GPIO6_IO03 | 163 |
GPIO6_IO04 | 164 |
GPIO6_IO05 | 165 |
GPIO6_IO06 | 166 |
GPIO6_IO07 | 167 |
GPIO6_IO08 | 168 |
GPIO6_IO09 | 169 |
GPIO6_IO10 | 170 |
GPIO6_IO11 | 171 |
GPIO6_IO14 | 174 |
GPIO6_IO15 | 175 |
GPIO6_IO16 | 176 |
GPIO6_IO17 | 177 |
GPIO6_IO18 | 178 |
GPIO6_IO19 | 179 |
GPIO6_IO20 | 180 |
GPIO6_IO21 | 181 |
GPIO6_IO22 | 182 |
GPIO6_IO23 | 183 |
GPIO6_IO24 | 184 |
GPIO6_IO25 | 185 |
GPIO6_IO26 | 186 |
GPIO6_IO27 | 187 |
GPIO6_IO28 | 188 |
GPIO6_IO29 | 189 |
GPIO6_IO30 | 190 |
GPIO6_IO31 | 191 |
GPIO7_IO00 | 192 |
GPIO7_IO01 | 193 |
GPIO7_IO02 | 194 |
GPIO7_IO03 | 195 |
GPIO7_IO04 | 196 |
GPIO7_IO05 | 197 |
GPIO7_IO06 | 198 |
GPIO7_IO07 | 199 |
GPIO7_IO08 | 200 |
GPIO7_IO09 | 201 |
GPIO7_IO10 | 202 |
GPIO7_IO11 | 203 |
GPIO7_IO12 | 204 |
GPIO7_IO13 | 205 |
The Tegra CPU defines GPIOs with an alphanumeric term, e.g. A1 or T5 (GPIO-Q.01).
8 x (Character - 'A') + Digit
So A0 becomes 0, A7 becomes 7, B0 becomes 8, ...
The Linux kernel defines macros in arch/arm/mach-tegra/gpio-names.h for each GPIO.
Apalis TK1 GPIO table
The following table lists all assignments of Tegra GPIO to their numeric representation.
A0 | 0 |
A1 | 1 |
A2 | 2 |
A3 | 3 |
A4 | 4 |
A5 | 5 |
A6 | 6 |
A7 | 7 |
B0 | 8 |
B1 | 9 |
B2 | 10 |
B3 | 11 |
B4 | 12 |
B5 | 13 |
B6 | 14 |
B7 | 15 |
C0 | 16 |
C1 | 17 |
C2 | 18 |
C3 | 19 |
C4 | 20 |
C5 | 21 |
C6 | 22 |
C7 | 23 |
D0 | 24 |
D1 | 25 |
D2 | 26 |
D3 | 27 |
D4 | 28 |
D5 | 29 |
D6 | 30 |
D7 | 31 |
E0 | 32 |
E1 | 33 |
E2 | 34 |
E3 | 35 |
E4 | 36 |
E5 | 37 |
E6 | 38 |
E7 | 39 |
F0 | 40 |
F1 | 41 |
F2 | 42 |
F3 | 43 |
F4 | 44 |
F5 | 45 |
F6 | 46 |
F7 | 47 |
G0 | 48 |
G1 | 49 |
G2 | 50 |
G3 | 51 |
G4 | 52 |
G5 | 53 |
G6 | 54 |
G7 | 55 |
H0 | 56 |
H1 | 57 |
H2 | 58 |
H3 | 59 |
H4 | 60 |
H5 | 61 |
H6 | 62 |
H7 | 63 |
I0 | 64 |
I1 | 65 |
I2 | 66 |
I3 | 67 |
I4 | 68 |
I5 | 69 |
I6 | 70 |
I7 | 71 |
J0 | 72 |
J1 | 73 |
J2 | 74 |
J3 | 75 |
J4 | 76 |
J5 | 77 |
J6 | 78 |
J7 | 79 |
K0 | 80 |
K1 | 81 |
K2 | 82 |
K3 | 83 |
K4 | 84 |
K5 | 85 |
K6 | 86 |
K7 | 87 |
L0 | 88 |
L1 | 89 |
L2 | 90 |
L3 | 91 |
L4 | 92 |
L5 | 93 |
L6 | 94 |
L7 | 95 |
M0 | 96 |
M1 | 97 |
M2 | 98 |
M3 | 99 |
M4 | 100 |
M5 | 101 |
M6 | 102 |
M7 | 103 |
N0 | 104 |
N1 | 105 |
N2 | 106 |
N3 | 107 |
N4 | 108 |
N5 | 109 |
N6 | 110 |
N7 | 111 |
O0 | 112 |
O1 | 113 |
O2 | 114 |
O3 | 115 |
O4 | 116 |
O5 | 117 |
O6 | 118 |
O7 | 119 |
P0 | 120 |
P1 | 121 |
P2 | 122 |
P3 | 123 |
P4 | 124 |
P5 | 125 |
P6 | 126 |
P7 | 127 |
Q0 | 128 |
Q1 | 129 |
Q2 | 130 |
Q3 | 131 |
Q4 | 132 |
Q5 | 133 |
Q6 | 134 |
Q7 | 135 |
R0 | 136 |
R1 | 137 |
R2 | 138 |
R3 | 139 |
R4 | 140 |
R5 | 141 |
R6 | 142 |
R7 | 143 |
S0 | 144 |
S1 | 145 |
S2 | 146 |
S3 | 147 |
S4 | 148 |
S5 | 149 |
S6 | 150 |
S7 | 151 |
T0 | 152 |
T1 | 153 |
T2 | 154 |
T3 | 155 |
T4 | 156 |
T5 | 157 |
T6 | 158 |
T7 | 159 |
U0 | 160 |
U1 | 161 |
U2 | 162 |
U3 | 163 |
U4 | 164 |
U5 | 165 |
U6 | 166 |
U7 | 167 |
V0 | 168 |
V1 | 169 |
V2 | 170 |
V3 | 171 |
V4 | 172 |
V5 | 173 |
V6 | 174 |
V7 | 175 |
W0 | 176 |
W1 | 177 |
W2 | 178 |
W3 | 179 |
W4 | 180 |
W5 | 181 |
W6 | 182 |
W7 | 183 |
X0 | 184 |
X1 | 185 |
X2 | 186 |
X3 | 187 |
X4 | 188 |
X5 | 189 |
X6 | 190 |
X7 | 191 |
Y0 | 192 |
Y1 | 193 |
Y2 | 194 |
Y3 | 195 |
Y4 | 196 |
Y5 | 197 |
Y6 | 198 |
Y7 | 199 |
Z0 | 200 |
Z1 | 201 |
Z2 | 202 |
Z3 | 203 |
Z4 | 204 |
Z5 | 205 |
Z6 | 206 |
Z7 | 207 |
AA0 | 208 |
AA1 | 209 |
AA2 | 210 |
AA3 | 211 |
AA4 | 212 |
AA5 | 213 |
AA6 | 214 |
AA7 | 215 |
BB0 | 216 |
BB1 | 217 |
BB2 | 218 |
BB3 | 219 |
BB4 | 220 |
BB5 | 221 |
Additionaly on T30
BB6 | 222 |
BB7 | 223 |
CC0 | 224 |
CC1 | 225 |
CC2 | 226 |
CC3 | 227 |
CC4 | 228 |
CC5 | 229 |
CC6 | 230 |
CC7 | 231 |
DD0 | 232 |
DD1 | 233 |
DD2 | 234 |
DD3 | 235 |
DD4 | 236 |
DD5 | 237 |
DD6 | 238 |
DD7 | 239 |
EE0 | 240 |
EE1 | 241 |
EE2 | 242 |
EE3 | 243 |
Additionaly on TK1
EE4 | 244 |
EE5 | 245 |
EE6 | 246 |
EE7 | 247 |
FF0 | 248 |
FF1 | 249 |
FF2 | 250 |
