Basic Wi-Fi Usage on Torizon OS
In this lesson, you will connect the board to the Internet using the integrated Wi-Fi module.
In this section you will:
- Scan for available Wi-Fi networks.
- Connect to and authenticate with a Wi-Fi access point.
The network manager used in Torizon is called NetworkManager. The command-line client is nmcli. This lesson was written based on the Torizon knowledge-base article Networking with Torizon OS.
Check if your Toradex SoM has a Wi-Fi module. See it highlighted in the example below and try to identify the same device on your SoM:
Note that not all modules come with Wi-Fi/Bluetooth connectivity. Check the datasheet of your module for more information.
If it doesn't, you can proceed to the next lesson.
Access the Linux terminal as explained in the previous lesson Linux Terminal and Basic Usage - Linux.
Scan for available Wi-Fi access points by running the command below:
# nmcli device wifi list
Wait for the output message:
IN-USE SSID MODE CHAN RATE SIGNAL BARS SECURITY
MY_WIFI_NETWORK Infra 5 270 Mbit/s 100 **** WPA1 WPA2
MY_WIFI_NETWORK_5GHZ Infra 36 405 Mbit/s 79 *** WPA1 WPA2
Step 3
Connect to a Wi-Fi network by locating the SSID of the network to which you want to connect and running the following command:
# nmcli -a device wifi connect <SSID>
Step 4
Authenticate with the Wi-Fi network:
Upon running the command in Step 3, you will be prompted for a password. Below, you will see the command to connect to SSID MY_WIFI_NETWORK, followed by the password request:
# nmcli -a device wifi connect MY_WIFI_NETWORK
Password: *********
After typing the password and pressing enter/return, the connection status message should appear:
Device 'wlp1s0' successfully activated with 'e17b1631-06c3-4720-a27d-6220775f8c6b'.
The next time you reboot the system, the network will connect automatically as long as the access point is within range.
Step 5
Verify and view the details of the Wi-Fi connection you made with the following command:
# nmcli
You should see a section that starts with wlp1s0, similar to the one below:
wlp1s0: connected to MY_WIFI_NETWORK
"Marvell Wi-Fi"
wifi (mwifiex_pcie), xx:xx:xx:xx:xx:xx, hw, mtu 1500
inet4 10.0.0.42/24
The IP Address of your Wi-Fi adapter is on the line starting with "inet4".
Step 6
Ping a website using the Wi-Fi interface to verify that you have Internet access:
# ping -I <interface> -c 4 google.com
Expected output:
PING google.com (216.58.202.142): 56 data bytes
64 bytes from 216.58.202.142: seq=0 ttl=52 time=16.131 ms
64 bytes from 216.58.202.142: seq=1 ttl=52 time=17.839 ms
64 bytes from 216.58.202.142: seq=2 ttl=52 time=17.629 ms
64 bytes from 216.58.202.142: seq=3 ttl=52 time=16.691 ms
--- google.com ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 16.131/17.072/17.839 ms
Common errors
Killing a connection command can make future commands fail. A reboot usually fixes this.
FAQ
How can I configure the network with a static IP
Please refer to the Networking with Torizon OS. The Static Network Configuration section describes how it can be achieved.
Where can I find more information about the on-SoM Wi-Fi?
You can start with the overview page Wi-Fi on Toradex Computer on Modules, or go straight to the Azurewave AW-CM276NF Wi-Fi & Bluetooth module page.
