Build U-Boot From Source Code
This series of articles describes how to build the U-Boot without using a higher-level build system such as the Yocto Project/OpenEmbedded. This procedure mostly makes sense during bootloader development.
We provide OpenEmbedded recipes that build U-Boot and Linux as part of a complete BSP image. If you plan to build a full BSP image, follow the Build a Reference Image with Yocto Project/OpenEmbedded article.
This is an overview article of the necessary process for building the bootloader from source code. If you are looking for specific information regarding module- or SoC-specific instructions, check the Additional Module-specific Steps section.
The required git branch and Linux binaries to be used depend on the module type and BSP version, as we will explain in this article. For a BSP Versions overview, refer to the Embedded Linux Release Matrix.
Prepare the Environment for Cross-Compilation
Install the GCC toolchain for bare-metal targets on your host machine. It's recommended to use version 9.2 or higher of the ARM GNU Toolchain to cross-compile software for Toradex modules.
From the command line:
Download and unpack the 32-bit and/or 64-bit Arm cross-toolchain files:
$ wget -O arm-gnu-toolchain-12.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz "https://developer.arm.com/-/media/Files/downloads/gnu/12.3.rel1/binrel/arm-gnu-toolchain-12.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz?rev=cf8baa0ef2e54e9286f0409cdda4f66c&hash=4E1BA6BFC2C09EA04DBD36C393C9DD3A"
$ tar xvf arm-gnu-toolchain-12.3.rel1-x86_64-aarch64-none-linux-gnu.tar.xz$ wget -O arm-gnu-toolchain-12.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz "https://developer.arm.com/-/media/Files/downloads/gnu/12.3.rel1/binrel/arm-gnu-toolchain-12.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz?rev=9d73bfdd64a34550b9ec38a5ead7c01a&hash=774AAE1A6D6996CFB89FD7E367C0B59B"
$ tar xvf arm-gnu-toolchain-12.3.rel1-x86_64-arm-none-linux-gnueabihf.tar.xz -
Set the toolchain path:
$ ln -s arm-gnu-toolchain-12.3.rel1-x86_64-aarch64-none-linux-gnu gcc-linaro-aarch64$ ln -s arm-gnu-toolchain-12.3.rel1-x86_64-arm-none-linux-gnueabihf gcc-linaro-arm -
Prepare the environment variables:
$ export ARCH=arm64
$ export DTC_FLAGS="-@"
$ export PATH=~/gcc-linaro-aarch64/bin/:$PATH
$ export CROSS_COMPILE=aarch64-none-linux-gnu-$ export ARCH=arm
$ export PATH=~/gcc-linaro-arm/bin/:$PATH
$ export CROSS_COMPILE=arm-none-linux-gnueabihf-
Install Tools and Dependencies
Install Bison, Flex, Swig and OpenSSL and other dependencies: The Bison, Flex and Swig packages are necessary to configure U-Boot from a defconfig and to build the device tree compiler, while the OpenSSL development package is used in the U-Boot compilation. Other dependencies listed are also necessary to complete the build process:
$ sudo apt-get install bc build-essential git libncurses5-dev lzop perl libssl-dev bison flex swig libyaml-dev pkg-config python3-devinfoThose dependencies are based on tests made for Ubuntu/Debian environments. Other distributions may have different dependencies.
Install the Device Tree Compiler (DTC) Tool: U-Boot and the device tree overlays compilation for some modules need a device tree compiler (DTC). We recommend DTC version 1.6.0 or higher.
$ git clone git://git.kernel.org/pub/scm/utils/dtc/dtc.git -b v1.6.0 ~/dtc
$ cd ~/dtc
$ make
$ export PATH=$HOME/dtc/:$PATHinfoOn Ubuntu 22.04, there are known DTC build errors:
libfdt/libfdt.h:251:28: warning: array subscript 'struct fdt_header[0]' is partly outside array bounds of 'unsigned char[4]' [-Warray-bounds].To prevent DTC from treating warnings as errors, remove the
-Werrorflag from theCFLAGSvariable in the Makefile. Note: The implications of this change have not been fully evaluated. Proceed with caution. -
Install U-Boot Tools: The
uImagetarget of the Linux kernel compilation needs a recentmkimagetool.$ sudo apt-get install u-boot-toolsAlternatively, mkimage tool is also built during the U-Boot compilation. You can follow the U-Boot building instructions as explained further in this article, and after that, include it in PATH.
U-Boot Version Information
The required git branch, U-Boot configuration, and U-Boot/Linux binaries to be used depend on the module type and the BSP version, as we will explain in this article.
| SoC | U-Boot Source | U-Boot Git Branch | U-Boot Configuration | U-Boot Binary |
| TI AM69 | Downstream | toradex_ti-u-boot-2024.04 | aquila-am69_a72_defconfig aquila-am69_r5_defconfig | u-boot.img tispl.bin tiboot3-am69-hs-fs-aquila.bin |
| TI AM62Px | Downstream | toradex_ti-u-boot-2024.04 | verdin-am62p_a53_defconfig verdin-am62p_r5_defconfig | u-boot.img tispl.bin tiboot3-am62px-hs-fs-verdin.bin |
| TI AM62x | Downstream | toradex_ti-u-boot-2024.04 | verdin-am62_a53_defconfig verdin-am62_r5_defconfig | u-boot.img tispl.bin tiboot3-am62x-hs-fs-verdin.bin |
| i.MX 8MM/8MP | Upstream | v2024.07 | verdin-imx8mm_defconfig verdin-imx8mp_defconfig | imx-boot |
| i.MX 8/8X | Downstream | toradex_imx_lf_v2024.04 | apalis-imx8_defconfig colibri-imx8x_defconfig | imx-boot |
| i.MX 7 | Upstream | v2024.07 | colibri_imx7_defconfig colibri_imx7_emmc_defconfig | u-boot-nand.imx u-boot.imx |
| i.MX 6 | Upstream | v2024.07 | apalis_imx6_defconfig colibri_imx6_defconfig | u-boot.img |
| i.MX 6ULL | Upstream | v2024.07 | colibri-imx6ull_defconfig colibri-imx6ull-emmc_defconfig | u-boot-nand.imx u-boot.imx |
In the case of TI AM62x-based and AM69-based modules, both defconfig configurations are used.
The meta-toradex-bsp-common hashes for each BSP version to be used in the following steps are presented in the table below:
| BSP Version | Hash |
| 7.0.0 | 6cdf564762805ec382409a2ba23d33bcde5bec9f |
| 7.1.0 | 9ddc957972a0375d283e3871769bce48156d0d29 |
| 7.2.0 | 354aebd1796c4ad5eaeee52b8dc768fcc2dad32d |
Building U-Boot
In the following instructions, you will be directed to create a directory called ~/workdir to store all the source and build files. You can, of course, replace this directory name with any other name you prefer.
Fetch U-Boot Sources
Clone the U-Boot source code using Git:
- For upstream-based modules: https://gitlab.com/u-boot/u-boot.git
- For downstream-based modules: https://git.toradex.com/cgit/u-boot-toradex.git/
$ mkdir -p ~/workdir
$ cd ~/workdir
$ git clone https://gitlab.com/u-boot/u-boot.git
$ cd ~/workdir
$ git clone https://git.toradex.com/u-boot-toradex.git
$ cd u-boot-toradex
$ git checkout <branch>
Once inside the root folder of your local copy of the U-Boot repository, checkout to the required <branch> according to the U-Boot Git Branch for your specific configuration. Check the section U-boot Version for this specific information.
The following section is only necessary if using an upstream-based module. If you are using a downstream-based module please go to the Configure U-Boot section.
Get and Apply the Necessary Patches (Upstream-Only)
Create a branch based on the
<branch>you just checked out. Also, create apatchesdirectory to store the patches you are going to fetch.$ cd u-boot
$ git checkout -b toradex-<branch>
$ mkdir patches
$ cd patches -
Clone the meta-toradex-bsp-common repository, which contains recipes common to all modules. Checkout to the BSP release commit hash and copy the patches to the U-Boot patches directory.
$ cd ~/workdir
$ git clone https://git.toradex.com/cgit/meta-toradex-bsp-common.git
$ cd meta-toradex-bsp-common
$ git checkout <meta-toradex-bsp-common-hash>
$ cp recipes-bsp/u-boot/u-boot-toradex/*.patch ../u-boot/patches -
Apply the patches with
git am <patch files>from within the patches directory. The patches must be applied in the correct order (check the TDX_PATCHES variable on this recipe) and the application should be clean (without any errors or conflicts).Note that you can apply multiple patches in a single command (keeping the correct order), as in the following example:
$ cd ~/linux/patches
$ git am [first-patch-file-name].patch \
[second-patch-file-name].patch \
[third-patch-file-name].patch \
[fourth-patch-file-name].patch \
[fifth-patch-file-name].patch \For a double check, use
git log --onelineto see the patches commit messages.$ git log --oneline
Configure U-Boot
Find the right configuration file at the U-Boot Version Information table.
Go to the
u-bootdirectory and usemake mrproperfor a clean configuration. Then, executemake <board_defconfig>(check theboard_defconfigin the table of the section U-boot Version Information) to configure U-boot from a defconfig:$ cd ~/workdir/u-boot
$ make mrproper
$ make <board_defconfig>$ cd ~/workdir/u-boot-toradex
$ make mrproper
Compile U-Boot
After the configuration process, the sources of U-Boot are ready to be built.
$ make -j$(nproc) 2>&1 | tee build.log
$ make u-boot-dtb.imx
Additional Module-Specific Steps
The following articles contain mandatory specific steps for a full bootloader build and configuration:
- Build U-Boot for NXP i.MX 6/6ULL/7-based System on Modules
- Build U-Boot for NXP i.MX 8/8X-based System on Modules
- Build U-Boot for NXP i.MX 8M Mini/Plus-based System on Modules
- Build U-Boot for TI AM62x-based System on Modules
- Build U-Boot for TI AM62Px-based System on Modules
- Build U-Boot for TI AM69-based SoMs
Deploy the U-Boot binary to an Image
To deploy your custom U-Boot binary to an image, follow the steps described below:
Start from an existing sample image: Download and extract one of the Toradex prebuilt images. Choose the appropriate image for your SoM in the Reference Images for Yocto Project Software Downloads.
Integrate artifacts: Integrate the U-Boot artifacts into the standard Toradex Easy Installer package by replacing the bootloader binaries listed in the U-Boot Version Information table with the ones you have built.
Adjust image.json: When building U-Boot manually, the binaries' names might differ from the U-Boot Version Information table. Therefore, adjust the
image.jsonfile accordingly, ensuring the bootloader binaries are being loaded correctly. For example, the following snippet shows the configuration for the Verdin iMX8M Plus:image.json"name": "mmcblk0boot0",
"erase": true,
"content": {
"filesystem_type": "raw",
"rawfiles": [
"filename": "u-boot.imx",
"dd_options": "seek=2"
}For more information about the available customizations, see the Toradex Easy Installer documentation.
Deploy the Toradex Easy Installer image: You may now use the above prepared Toradex Easy Installer package with the Toradex Easy Installer.
