Version: Torizon OS 7.x.y
Partner Demo Container - CODESYS
The CODESYS Demo Container allows you to use your device as a PLC (Programmable Logic Controller) running a basic application. The container is handled entirely via the CODESYS IDE, with no need for you to configure the module yourself. Learn more about CODESYS Software PLC in our overview article.
The Demo Container is also referred to as the CODESYS Runtime or the CODESYS Control container. Additionally, this article also shows how to use the CODESYS Gateway container, which allows you to use the device itself as the network bridge between the IDE and the CODESYS Runtime.
This article covers the basic usage of the CODESYS IDE, and it will guide you on how to:
  • Deploy the CODESYS demo to your device through the Torizon Demo Gallery
  • Deploy and run the Gateway and CODESYS Runtime containers to your device through the CODESYS IDE
  • Create a basic graphical CODESYS application
  • Host the application through your device, and access it via a web browser
warning
The CODESYS runtime provided in this guide is meant for demonstration purposes and has a limited time to run of 2 hours from the start of the container. For licensing information, refer to the CODESYS licensing page. To run the runtime in licensed mode, refer to the CODESYS Licensing with CodeMeter on Torizon OS article. If you want to license CODESYS on Toradex hardware, contact our partners BE.services, CODESYS GmbH or neXo.
The Torizon Demo Gallery offers a curated collection of demos and samples that deploy directly to the target device in a few clicks, without manual container setup.
Supported Modules​
CODESYS is supported in Arm-based Toradex System-on-Modules running Torizon OS. The CODESYS demo on the Torizon Demo Gallery is available for modules based on the following System-on-a-Chip (SoC) families:
  • NXP i.MX 95
  • NXP i.MX 93
  • NXP i.MX 8
  • NXP i.MX 6 and i.MX 7
  • TI AM69
  • TI AM62P
  • TI AM62
  • Synaptics SL1680
Intended Use​
This partner demo container is meant for evaluating the technology. It is not suitable for development or production.
Prerequisites​
  • A Toradex System-on-Module (SoM) running Torizon OS with Docker (PREEMPT_RT)
    To get full performance, CODESYS requires the Linux kernel with the PREEMPT_RT patch applied. The support for PREEMPT_RT on Torizon is in its early stages. For evaluation, you can run this container using the default Torizon OS without PREEMPT_RT at your discretion.
    You don't need to apply configurations to your image or run commands on your SoM. This article will show you how to handle the CODESYS containers entirely through the CODESYS IDE.
  • To deploy the demo from the Torizon Demo Gallery: an account on the Torizon Cloud, with your device provisioned. For instructions, refer to the Toradex Quickstart Guide. To see the demo on the device itself, you also need a display connected to it.
The CODESYS Demo runs a sample "Simon Says" game on the CODESYS runtime. The demo shows the WebVisualization of the game in a Chromium browser in kiosk mode, on a display connected to the device. You can also open the game from a web browser on another machine on the same network, using the hostname or the IP address of the device as the URL, for example http://<hostname>.
The demo is deployed from the Torizon Demo Gallery through the Torizon Cloud, in a few clicks and with no manual container setup:
  1. Open the CODESYS Demo page on the Torizon Demo Gallery.
  2. Select the hardware you want to deploy the demo to.
  3. You are directed to the Torizon Cloud, where you select one of your provisioned devices and deploy the demo.
The Torizon Demo Gallery article describes the whole flow in detail. If the demo does not show up on the Torizon Cloud, refer to its Troubleshoot section.
Run an Application with the Demo Container​
This section shows how to:
  • Develop a basic PLC application on CODESYS
  • Use your device as a CODESYS Gateway, which runs the logic of your application and exposes it through an URL.
By the end of this section, you will be able to view and interact with a basic CODESYS application through a web browser. This browser can be run on the controller device or on an external device connected to the same network.
Install the CODESYS IDE​
  1. Download the CODESYS Installer from the CODESYS store;
    Download CODESYS Installer
  2. Install the lastest version of the CODESYS Development System;
    Install CODESYS
  3. Install the following Add-Ons:
    • CODESYS Virtual Control for Linux SL
    • CODESYS LD/FBD
    CODESYS Addons
    CODESYS LD/FBD
Download and Deploy the Demo Container​
  1. Click the Tools tab and Open the Deploy Control SL Menu;
    note
    If you can't see the Deploy Control SL option, check if Virtual Control for Linux SL was installed correctly in step 3.
    CODESYS Control Menu
  2. Connect to the Target Device. You can connect using the hostname or the IP address of your target device. You should see the Connected status.
    CODESYS Connect
  3. In the "Deployment" tab, install the CODESYS Virtual Control and Virtual Edge Gateway containers.
    The edgearm is a Gateway Application and the virtuallinuxarm is the Runtime Application.
    CODESYS Docker Pull
  4. In the "Operation" tab, add instances (images) of each of the containers installed in the last step. For this example, we named the images codesys_gateway and codesys_control.
    CODESYS Add Instances
  5. Configure the CODESYS Control container to expose port 8080 and save. This is the port that you will use to access the application interface at the end of this guide. If you have trouble finding the interface to configure the container, select it, close all other tabs and scroll to the side.
  6. Start all the containers. The status on all images should change to "Running":
    CODESYS Docker Run
Create a Basic Application​
  1. Create a new Standard project, give the project a name and click ok:
    Create a new Standard Project
  2. Select the Virtual Control for Linux SL. In PLC_PRG select Ladder Logic Diagram (LD):
    Setup device and PLC programming language
  3. Now a new project is created. You will see a menu listed on the left-hand side of the project window.
  4. Double click on Device. A new tab will open. Click on Gateway -> Manage Gateways:
    Find your device in the network
  5. Click Add to create a new Gateway using the target device IP:
  6. Change to the new Gateway and Click Scan Network:
  7. In the Select Device window make sure the device was found and then double click on it. If no device is found under the Gateway, verify if the CODESYS Control container is running.
    Select your CODESYS device
  8. With the device connected to the development environment, we can start programming the logic. Click PLC_PRG in the project tree. In Toolbox drag and drop a Contact and a Coil to the Ladder area:
    Create a basic project logic
  9. Add the INPUT_01 variable name in the Contact text box and select as type BOOL:
    Configure the input device
  10. Add the OUTPUT_01 variable name in the Coil text box and select as type BOOL:
    Configure the output device
  11. Add a Visualization to the project. In the project tree, right click on Application > Add Object > Visualization:
    Add visualization
  12. On Add Visualization window just click Add button:
    Add visualization
  13. On the Visualization tab, which can be opened with double click on Visualization in the project tree, select Visualization Toolbox > Lamps/Switches/Bitmaps one DipSwitch and one Lamp1, drag and drop one at a time for the Visualization tab:
    Create the visualization user interface
  14. Connect the elements of the visualization to the elements of the ladder.
  15. Select DipSwitch and in Properties select Variable:
    Configure the dip switch
  16. The DipSwitch must be connected to the Contact element of the Ladder. In the window Input Assist select Application > PLC_PRG > INPUT_01 (the variable which has been added to Contact):
  17. Select Lamp1 and in Properties select Variable. In the window Input Assist select Application > PLC_PRG > OUTPUT_01 (the variable which has been added to Coil):
    Configure the lamp
Run the Application​
  1. With the connections made, we expect that on toggling the input DipSwitch, the output Lamp1 also toggles. To test, download the project for the device. Click the Online menu and select Login (always choose download):
    Download the application to the device
  2. With the project downloaded and online, the following screen will be shown and the project will be in the STOP state:
    Project ready to run on the device
  3. To start the application, click on play:
    Start the application
    At this point, the application will be in the RUN state. On the Visualization the elements can already be tested. Pressing the DipSwitch should light the Lamp1 on.
    Video illustration of the application running
  4. The Visualization feature also adds to the project the WebVisualization. Click on Visualization Manager -> WebVisualization on project tree. In the WebVisualization tab you can find the settings:
    Web visualization
    You can open your browser and remotely connect to the web visualization tool using the board hostname and port 8080: http://<hostname>:8080/webvisu.htm
    Triggering the DipSwitch will act both on the WebVisualization of the browser as in development environment Visualization:
    Video illustration of the web visualization
Local WebVisualization​
To visualize the application on your target device (instead of accessing it from another machine's browser), you can also run a web browser in full screen (kiosk) mode on a touch screen display connected to the target device. To do that, you need to create two separate containers in addition to the CODESYS Demo Container:
  1. Run a Torizon Weston Container as the graphical backend.
  2. Run a Chromium Container, passing it the http://<hostname>:8080/webvisu.htm URL to it as an argument.
WebVisualization on the device
Next Steps​
For general information about CODESYS on Torizon OS, read the CODESYS on Torizon OS article. It also summarizes the options to visualize CODESYS applications.
To be able to display your graphical application on the target device's graphical backend, without running it inside a browser, refer to the CODESYS TargetVisu Container article.
This container is a demonstration meant solely for evaluation purposes. For more information and custom requests (for instance if you need a solution ready to deploy on the field), please contact one of our partners BE.services, CODESYS GmbH or neXo.
