Hello World integration into OpenEmbedded
This article describes how you can create a new meta-layer for OpenEmbedded and how you can add your own hello-world application. We don't go into details, it should only give you an easy introduction on how to start. For further details please read the Yocto Project Mega-Manual.
Create a meta layer
First, you need to compile an image according to the following link: OpenEmbedded (core) For starting we recommend compiling the angstrom-lxde-image.
After that we need to create a new meta-customer layer:
cd layers
mkdir -p meta-customer/conf
cd meta-customer
Edit conf/layer.conf so that it looks as follows:
# We have a conf and classes directory, add to BBPATH
BBPATH .= ":${LAYERDIR}"
# We have recipes-* directories, add to BBFILES
BBFILES += "${LAYERDIR}/recipes-*/*/*.bb ${LAYERDIR}/recipes-*/*/*.bbappend"
BBFILE_COLLECTIONS += "customer"
BBFILE_PATTERN_customer = "^${LAYERDIR}/"
BBFILE_PRIORITY_customer = "1"
# This should only be incremented on significant changes that will
# cause compatibility issues with other layers
LAYERVERSION_customer = "1"
LAYERDEPENDS_customer = "core"
LAYERSERIES_COMPAT_customer = "rocko"
Create a recipe
Now that we have a meta layer we need to create a recipe.
# Hello world needs to be there twice
mkdir -p recipes-customer/hello-world/hello-world
Create a recipe file recipes-customer/hello-world/hello-world_1.0.0.bb:
# Package summary
SUMMARY = "Hello World"
# License, for example MIT
LICENSE = "MIT"
# License checksum file is always required
LIC_FILES_CHKSUM = "file://${COREBASE}/meta/files/common-licenses/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
# hello-world.c from local file
SRC_URI = "file://hello-world.cpp"
# Change source directory to workdirectory where hello-world.cpp is
S = "${WORKDIR}"
# Compile hello-world from sources, no Makefile
do_compile() {
    ${CXX} -Wall hello-world.cpp -o hello-world
# Install binary to final directory /usr/bin
do_install() {
    install -d ${D}${bindir}
    install -m 0755 ${S}/hello-world ${D}${bindir}
Add the hello world sources to recipes-customer/hello-world/hello-world/hello-world.cpp:
#include <stdio.h>
int main(int argc, char *argv[]){
    printf("Hello world!\n");
    return 0;
Add meta layer to buildsystem
After that you have to change to the build directory again and initialize the build system:
cd ../../
. export
Add the new meta-customer layer to conf/bblayers.conf so that it looks as follows:
# LAYER_CONF_VERSION is increased each time build/conf/bblayers.conf
# changes incompatibly
LCONF_VERSION = "7"
BBPATH = "${TOPDIR}"
BBFILES ?= ""
BBLAYERS ?= " \
  ${TOPDIR}/../layers/meta-angstrom \
  ${TOPDIR}/../layers/meta-toradex-nxp \
  ${TOPDIR}/../layers/meta-freescale \
  ${TOPDIR}/../layers/meta-freescale-3rdparty \
  ${TOPDIR}/../layers/meta-toradex-tegra \
  ${TOPDIR}/../layers/meta-jetson-tk1 \
  ${TOPDIR}/../layers/meta-toradex-bsp-common \
  ${TOPDIR}/../layers/meta-openembedded/meta-oe \
  ${TOPDIR}/../layers/meta-openembedded/meta-filesystems \
  ${TOPDIR}/../layers/meta-openembedded/meta-gnome \
  ${TOPDIR}/../layers/meta-openembedded/meta-xfce \
  ${TOPDIR}/../layers/meta-openembedded/meta-initramfs \
  ${TOPDIR}/../layers/meta-openembedded/meta-networking \
  ${TOPDIR}/../layers/meta-openembedded/meta-multimedia \
  ${TOPDIR}/../layers/meta-openembedded/meta-python \
  ${TOPDIR}/../layers/meta-lxde \
  ${TOPDIR}/../layers/meta-browser \
  ${TOPDIR}/../layers/meta-qt4 \
  ${TOPDIR}/../layers/meta-qt5 \
  ${TOPDIR}/../layers/meta-qt5-extra \
  ${TOPDIR}/../layers/meta-freescale-distro \
  ${TOPDIR}/../layers/meta-toradex-demos \
  ${TOPDIR}/../layers/openembedded-core/meta \
  ${TOPDIR}/../layers/meta-customer \
For testing you can build your hello-world package:
bitbake hello-world
Add package to the final image
To add the newly created recipe to your image, you can add the following line to conf/local.conf:
IMAGE_INSTALL_append = " hello-world"
After that you can build again your image. Now it will contain hello world under /usr/bin/hello-world.
bitbake angstrom-lxde-image
