Install Debian Packages on Target
Article updated at 24 Apr 2019
This guide shows how to start a container, install some packages and modify the container such that it will start a Python script on startup.
This steps and image modifications should be done in a Dockerfile for reproducibility. Executing those steps manually can be useful to develop the Dockerfile or for quick prototyping.
Start a base Debian container
To pull an execute a Debian container interactively use the docker run command. This starts the container privileged and with devices available inside the container. This allows to access the hardware (e.g. graphics in this case) directly from inside the container.
 # docker run -it --privileged \
                -v /dev:/dev debian:buster /bin/bash
This starts a new container interactively which can be used to build a new image interactively.
This drops us in a prompt with root privileges
root@3887607ebf2a:/#
Install Debian packages
With this prompt, use the typical commands to install Debian packages. This example installs Qt for Python, also known as PySide2.
## apt-get update
## apt-get install --no-install-recommends vim-tiny python3-pyside2.qtwidgets \
                python3-pyside2.qtgui python3-pyside2.qtcore
This installs a bunch of packages and takes a while.
Create a Qt for Python Hello World example
Create a small Hello World python script:
## vi qtdemo.py
Press i, insert the code below and exit with escape, :wq.
qtdemo.py
import sys from PySide2.QtWidgets import QApplication, QLabel if __name__ == "__main__": app = QApplication(sys.argv) label = QLabel("Hello World") label.show() sys.exit(app.exec_())
At this point we can execute the script manually by setting up the Qt environment to access the graphics hardware directly:
## export QT_QPA_PLATFORM=linuxfb
## export QT_QPA_FB_DRM=1
## python3 /qtdemo.py
Create a Docker image from a Container
Now lets stop the container by exiting the shell (simply type exit) and create a Docker image from that container. The container ID is the part after root@ from the prompt, or can be obtained from docker ps:
# docker ps -a
Now docker commit can be used to create a Docker image. The --change parameter can be used to customize the container:
# docker commit --change='ENV QT_QPA_PLATFORM=linuxfb' --change='ENV QT_QPA_FB_DRM=1' --change='ENTRYPOINT ["python3", "/qtdemo.py"]' 3887607ebf2a debian-qtdemo
Then create a container from the image. Use the --restart=always parameter to make sure that the container get started on system boot.
# docker run -d -it --restart=always --privileged -v /dev:/dev debian-qtdemo
