Modem Support
Article updated at 26 Nov 2020
ModemManager is a DBus activated daemon and controls mobile broadband (2G/3G/4G) devices and connections. It is able to configure and setup connections with modem, whether they are built-in devices, USB cellular dongles, bluetooth-paired telephones, or professional RS232/USB devices with external power supplies. NetworkManager and Modemamanager in combination can be used to setup connection to cellular network on detection. Modemamanager uses libqmi and libmbim to communicate over Qualcomm MSM Interface (QMI) and Mobile Interface Broadband Model (MBIM) protocol.
  • ModemManager_workflow
    ModemManager Workflow
ModemManager on Torizon
TorizonCore provides ModemManager out-of-the-box, just like it also provides NetworkManager which is a program for providing detection and configuration for systems to automatically connect to networks. You can proceed on reading this article to learn how to use it.
Production Release
After you make the changes to the board, you can use the command isolate from the TorizonCore Builder Tool to generate your custom TorizonCore image for the Toradex Easy Installer.
ModemManager on BSP Layers and Reference Images for Yocto Project
If you have a custom Yocto build, you have to integrate ModemManager into your distribution. This article does not go through these steps, it only explains how to use ModemManager.
This article complies to the Typographic Conventions for Torizon Documentation
ModemManager
ModemManager provides a command line tool mmcli to control and monitor ModemManager. mmcli basic usage is shown below with Sierra MC7455 modem as an example. Sierra MC7455 modem is in QMI mode by default.
Note: Look into mmcli Manpage for more information.
Cellular Network
List Modems
A modem detection can be verified either through utilities of controlling subsystem(like lsusb) or using mmcli.
# mmcli -L
    /org/freedesktop/ModemManager1/Modem/0 [Sierra Wireless, Incorporated] MC7455
Here we have just one modem and 0 at the end of /org/freedesktop/ModemManager1/Modem/ is the index of the modem. Index of modem is to be used in rest of the commands to communicate with modem.
Enable Modem
To enable Modem
 # mmcli -m 0 -e
 successfully enabled the modem
Detailed Information
Detailed information of modem can be gotten by executing
# mmcli -m 0
  General  |            dbus path: /org/freedesktop/ModemManager1/Modem/0
           |            device id: d8a0301f39c8f3b959660cef109e3db4b41546a9
  Hardware |         manufacturer: Sierra Wireless, Incorporated
           |                model: MC7455
           |    firmware revision: SWI9X30C_02.24.05.06 r7040 CARMD-EV-FRMWR2 2017/05/19 06:23:09
           |         h/w revision: 1.0
           |            supported: gsm-umts, lte
           |              current: gsm-umts, lte
           |         equipment id: 123456789987654
  System   |               device: /sys/devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb2/2-1/2-1.1
           |              drivers: qmi_wwan, qcserial
           |               plugin: Sierra
           |         primary port: cdc-wdm1
           |                ports: wwan1 (net), ttyUSB0 (qcdm), ttyUSB2 (at), wwan0 (net),
           |                       cdc-wdm1 (qmi), ttyUSB1 (gps), cdc-wdm0 (qmi)
  Numbers  |                  own: 12345678910
  Status   |                 lock: sim-pin2
           |       unlock retries: sim-pin (3), sim-puk (10), sim-pin2 (10), sim-puk2 (10)
           |                state: registered
           |          power state: on
           |          access tech: lte
           |       signal quality: 96% (recent)
  Modes    |            supported: allowed: 3g; preferred: none
           |                       allowed: 4g; preferred: none
           |                       allowed: 3g, 4g; preferred: 3g
           |                       allowed: 3g, 4g; preferred: 4g
           |              current: allowed: 3g, 4g; preferred: 4g
  Bands    |            supported: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
           |                       eutran-1, eutran-2, eutran-3, eutran-4, eutran-5, eutran-7, eutran-8,
           |                       eutran-12, eutran-13, eutran-20, eutran-25, eutran-41
           |              current: utran-1, utran-3, utran-4, utran-5, utran-8, utran-2,
  IP       |            supported: ipv4, ipv6, ipv4v6
  3GPP     |                 imei: 123456789987654
           |          operator id: 123456
           |        operator name: HOME
           |         registration: home
  3GPP EPS | ue mode of operation: csps-2
  SIM      |            dbus path: /org/freedesktop/ModemManager1/SIM/0
There are different sections and status section tells us about state of modem and SIM inserted to it.
SIM Lock
As it can be seen in status section that SIM lock is enabled and is locked. SIM index can be found in the above detailed information i.e. /org/freedesktop/ModemManager1/SIM/0. Here 0 is the index of SIM to be used in commands to refer to it.
# mmcli -i 0 --pin=1234
successfully sent PIN code to the SIM
All other PIN related commands can be seen in mmcli Man-page.
Add Cellular Connection
NetworkManager is configured with ModemManager support so that NetworkManager can automatically bring up the cellular connection whenever ModemManager reports registration of modem. Following command can be executed to add cellular connection
# nmcli c add type gsm ifname * con-name home apn wap.tracfone
ifname option is usually a serial port with pattern tty* or a cdc-wdm* device, not a networking interface. It is the primary port in output of mmcli -m 0. * is used to use any modem device detected by ModemManager.
Enable the radio switch for mobile broadband(wwan)
# nmcli r wwan on
Connections managed by NetworkManager can be viewed by executing
# nmcli c
NAME      UUID                                  TYPE      DEVICE
home      72b3c630-265c-4357-8f1f-bb620d4adf14  gsm       cdc-wdm1
network0  958cc5e3-1bbf-3d64-beeb-020d4414e256  ethernet  --
network1  78c31df4-8c89-31a6-9aeb-d5603e230e42  ethernet  --
As it can be seen that home is in the list with device name cdc-wdm1(primary port).
Connect to Modem
After enabling the modem, now connection is to be made with cellular network.
# mmcli -m 0 --simple-connect="apn=wap.tracfone"
successfully connected the modem
A bearer object is created and can be seen at the bottom of output from mmcli -m 0
Bearer   |            dbus path: /org/freedesktop/ModemManager1/Bearer/0
Information related to this bearer can be gotten by
# mmcli -b 0
  General            |  dbus path: /org/freedesktop/ModemManager1/Bearer/0
                     |       type: default
  Status             |  connected: yes
                     |  suspended: no
                     |  interface: wwan1
                     | ip timeout: 20
  Properties         |        apn: wap.tracfone
                     |    roaming: allowed
                     |    ip type: ipv4v6
  IPv4 configuration |     method: static
                     |    address: 33.214.211.245
                     |     prefix: 30
                     |    gateway: 33.214.211.246
                     |        dns: 10.177.0.34, 10.177.0.210
                     |        mtu: 1500
  IPv6 configuration |     method: static
                     |    address: 2607:fb90:1c36:692c:c915:a30b:a0ec:18bb
                     |     prefix: 64
                     |    gateway: 2607:fb90:1c36:692c:d899:5368:2142:b474
                     |        dns: fd00:976a::9, fd00:976a::10
                     |        mtu: 1500
  Statistics         |   duration: 29
                     |   bytes rx: 584
                     |   bytes tx: 804
As it can be seen that cellular connection has been established. We had already configured NetworkManager to create routes for the new network interface.
It can be verified by looking at output of ifconfig (NetworkManager auto-connect on next modem registration onward)
# ifconfig
docker0   Link encap:Ethernet  HWaddr 02:42:0d:00:2d:d1
          inet addr:172.17.0.1  Bcast:172.17.255.255  Mask:255.255.0.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
ethernet0 Link encap:Ethernet  HWaddr 00:14:2d:a0:d5:9f
          collisions:0 txqueuelen:1000
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:80 errors:0 dropped:0 overruns:0 frame:0
          TX packets:80 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6128 (5.9 KiB)  TX bytes:6128 (5.9 KiB)
wwan1     Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:33.214.211.245  P-t-P:33.214.211.245  Mask:255.255.255.252
          inet6 addr: 2607:fb90:1778:8ea3:f8a3:e514:87f5:5971/64 Scope:Global
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:18 errors:0 dropped:0 overruns:0 frame:0
          TX packets:47 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1826 (1.7 KiB)  TX bytes:3494 (3.4 KiB)
GPS
ModemManager has also support for discovering location using Global Positioning System (GPS) or directly from mobile network infrastructure.
To check GPS-specific location capabilities
# mmcli -m 0 --location-status
  Location |         capabilities: 3gpp-lac-ci, gps-raw, gps-nmea, agps
           |              enabled: 3gpp-lac-ci
           |              signals: no
  GPS      |         refresh rate: 30 seconds
           | supported assistance: xtra
           |   assistance servers: http://xtrapath1.izatcloud.net/xtra3grc.bin
           |                       http://xtrapath2.izatcloud.net/xtra3grc.bin
           |                       http://xtrapath3.izatcloud.net/xtra3grc.bin
capabilities determines what location sources modem supports and can be enabled. To enable any of the listed capabilities
# sudo mmcli -m 0 \
>                  --location-enable-gps-raw \
>                  --location-enable-gps-nmea
Password:
successfully setup location gathering
To get location (dummy data is shown)
# mmcli -m 0 --location-get
  3GPP |      operator code: 111
       |      operator name: 222
       | location area code: FFFF
       | tracking area code: A1F9
       |            cell id: 005B2E0C
  GPS  |               nmea: $GPGSA,A,2,,,,,,,,,,,,,,,*1E
       |                     $GPRMC,,V,,,,,,,,,,N*55
       |                     $GPGSV,4,1,16,03,00,288,,04,07,319,,05,,,,08,20,274,*4C
       |                     $GPGSV,4,2,16,11,04,333,,12,,,,13,26,056,,13,13,234,*42
       |                     $GPGSV,4,3,16,15,65,260,,16,,,,17,,,,18,63,067,*72
       |                     $GPGSV,4,4,16,20,18,100,,21,49,296,,22,32,200,,24,50,078,*7B
       |                     $GPVTG,,T,,M,,N,,K,N*2C
       |                     $GPGGA,,,,,,0,,,,,,,,*66
