Unboxing and Setup Cables - Mallow Carrier Board
In this first lesson, you will go through the process of unboxing your computer on module and carrier board and assembling the hardware.
List of required items |
Accessory kit : |
- 12V 30W power supply |
- Power Supply Adapter |
- USB Type-C to Type-A cable |
- Ethernet cable |
USB keyboard and mouse |
2x 2.4GHz SMA antennas |
2x SMA to MHF4 cables |
List of recommended items |
Verdin Industrial Heatsink |
1.1 Remove the Mallow Carrier Board and the Verdin System on Module from the blisters.
Note that not all modules come with Wi-Fi/Bluetooth connectivity. Check the datasheet of your module for more information.
1.2 Unpack the SMA antennas and the SMA to MHF4 cables.
1.3 Connect the SMA antennas to the SMA to MHF4 cables as shown in the picture below:
1.4 Connect the antennas to the MHF4 connectors on the module as follows. The MHF4 terminations are tiny and fragile. Because of this, it is strongly recommended not to apply too much pressure when connecting it. Further, be careful not to slip and damage it. Using a tool is also not advised as the risk of damaging the MHF4 connector is higher.
For more information on how to connect antennas, refer to the article Operating Toradex Wi-Fi/BT Capable Modules Using Dual and Single Antenna Configuration.
Screw the Verdin Industrial Heatsink on top of the SoM, using the screws that come with it:
Step 3
Note that tha Mallow carrier board HDMI is only compatible with Verdin iMX8M Plus modules
3.1 Plug a USB keyboard/mouse into the Mallow Carrier Board's USB 3.x Host (X9) connector(s).
3.2 Plug the Ethernet cable into the Mallow Carrier Board's GBIT ETH (X2) connector.
The network shall be capable of providing the module with an IP address (via DHCP) and internet access.
3.3 Plug a USB Type-C to Type-A cable into the DRP (X8) connector if you want to enter Recovery Mode and load the Toradex Easy Installer.
3.4 Plug the power supply into the Mallow Carrier Board's power input connector X6.
Double-check that your power supply is within the rating board limits (7-27V for the X6 connector) and that the polarity is not reversed. Also, ensure the power supply's current capacity is sufficient, or the system may shut down unexpectedly. For evaluation purposes, a 12V 2A power supply is recommended.
