or cat /etc/issue
on the board.
Networking with TorizonCore can refer to different topics:
The first part of this article explains about host network configuration: the TorizonCore image currently provides NetworkManager, a program that provides detection and configuration for the system to automatically connect to networks.
The second part of this article explains about container network configuration and how to share a network between containers using docker-compose.
In order to take full advantage of this article, the following read is proposed:
The nmcli is a command-line client for NetworkManager. You can show the status of your network devices, detected by NetworkManager:
# nmcli device
Show our available connections and devices, on which the active connection is applied to:
# nmcli connection show
To disconnect from a network:
# nmcli con down id '<Connection_name>'
To delete a connection:
# nmcli con delete '<Connection_name>'
If you looking for a way to configure a Static Network Configuration, nmcli provides the following commands:
# nmcli con mod '<Connection_name>' ipv4.addresses "<10.0.0.164/23>"
# nmcli con mod '<Connection_name>' ipv4.gateway "<10.0.0.1>"
# nmcli con mod '<Connection_name>' ipv4.dns "<10.0.0.2>,<8.8.8.8>"
# nmcli con mod '<Connection_name>' ipv4.method "manual"
After running the commands above, you can visualize your entire network configuration by opening the <connection-name>.nmconnection
file:
# cd /etc/NetworkManager/system-connections/
# sudo cat <connection-name>.nmconnection
Expected file output:
connection_name.nmconnection[connection] id=<connection-name> uuid=a690e7e8-a413-331d-830d-d0df5bad3983 type=ethernet autoconnect-priority=-999 permissions= timestamp=1581530428 [ethernet] mac-address=00:14:2D:63:47:64 mac-address-blacklist= [ipv4] address1=<board-ip>,10.0.0.1 dns-search= method=manual [ipv6] addr-gen-mode=stable-privacy dns-search= method=auto
After the changes were made, do not forget to reload the configuration file:
# sudo nmcli connection reload
Along with Static Network Configuration, ncmli provides a way to configure a dynamic connection:
# nmcli con mod '<Connection_name>' ipv4.method "auto"
You must read the nmcli man page, either running man nmcli
on a computer with nmcli installed or Googling after it. For quick reference, man --help
is also useful.
To see a list of available Wi-Fi hotspots:
# nmcli device wifi list
Connect to a Wi-Fi:
# nmcli -a device wifi connect <WIFI_NAME>
After you make the changes to the board, you can use the command isolate
from the TorizonCore Builder Tool to generate your custom TorizonCore image for the Toradex Easy Installer.
This section is all about showing the drivers and ways to use network inside a Docker container.
Show the list of networks:
# docker network ls
Inspect network to see what containers are connected to it:
# docker network inspect <NETWORK_NAME>
Network drivers:
Bridge (containers communicate on the same Docker host)
Host (uses the host's networking directly)
Overlay (when containers running on different Docker hosts to communicate)
Macvlan (when you need your containers to look like physical hosts )
None
3rd-party- network plugins
When you run a new container, it automatically connects to the bridge network. A private network internal to the host is created in order to provide communication to the containers.
Create a user-defined bridge network:
# docker network create --subnet=<172.18.0.0/16> <NETWORK_NAME>
Create a container connected to our user-defined network:
# docker run --name <CONTAINER_NAME> -d --net <NETWORK_NAME> <IMAGE_NAME>
Specify the IP to a container and publish port 80 in the container to port 8080 to allow connections from other machine on the network :
# docker run --name <CONTAINER_NAME> -d --net <NETWORK_NAME> --ip <172.18.0.5> --publish <8080>:<80> <IMAGE_NAME>
Connect a running container to a network:
# docker network connect <NETWORK_NAME> <CONTAINER_NAME>
Macvlan driver can be configured in different ways. The advantage is to use the newest built-in and a lightweight driver, allowing the container to connect directly to host interfaces.
Create a macvlan network:
# docker network create -d macvlan --subnet=<172.16.86.0/24> \
--gateway=<172.16.86.1> -o parent=<ETHERNET_INTERFACE> \
<NETWORK_NAME>
Attach the container to the macvlan network:
# docker run -dit --network <NETWORK_NAME> \
--name <CONTAINER_NAME> <IMAGE_NAME> /bin/bash
To understand more about Docker networking drivers and which one is more advised to use on your application, please take a look at Understanding Docker Networking Driver Use Cases.
When you start your application, Docker Compose sets up a bridge network by default. Each service connects to the network, which makes them reachable with each other.
You can create your own networks to provide isolation and more options:
docker-compose.ymlservices: app1: image: app networks: - frontend app2: image: app networks: - frontend - backend app3: image: app networks: - backend networks: backend: # here you can configure your network frontend:
App2 is connected to frontend and backend network, so it can communicate with app1 and app3. App1 and app3 can't communicate with each other, because they are on separate networks.
Connect to the external network:
networks: default: external: name: <pre-existing-network>
Docker compose looks for the pre-existing-network.
For more information about, please take a look at Docker Compose Documentation.
The TorizonCore image currently provides NetworkManager, a program that provides detection and configuration for the system to automatically connect to networks. This article will show you instructions on how to use it.
# nmcli device
file:
Connect to a Wi-Fi:
# docker network ls
Network drivers:
None
<NETWORK_NAME>
