Capturing Changes in the Configuration of a Board on Torizon OS
During the development process with Torizon OS, usually it is required to capture configuration changes on the /etc directory that needs to be committed to the Torizon OS image.
Here are some examples of procedures that require changes in the configuration of the system:
- Custom networking configuration
- Touch screen calibration
- Cellular modem configuration
- Torizon OS boot time optimization
- Use of private registries with Torizon Cloud
- Enable additional reliability services on Torizon
- Apply udev rules to tweak configurations related to Weston
- Storage of Docker data on an external storage device (USB/SD Card)
- Enforcing strong passwords in Torizon OS
- Device Monitoring in Torizon OS
- Modifying updates configuration in Aktualizr
This article shows how to capture these system configurations.
Pre-requisites
The pre-requisite to complete these instructions are:
- Prerequisites from Configure Build Environment for Torizon Containers installed.
- A Toradex SoM with Torizon installed.
- Having read the Torizoncore Builder - Getting Started article can be helpful.
- A Torizon OS image downloaded.
If you have made any configuration changes, they will be saved in the /etc directory of your board. The isolate command will fetch all those changes (modifications, addition, deletion, and files and directories permissions and ownership). It requires an SSH connection for the communication between the host PC and the target board.
Get configuration changes from the target board, saving them in a specific directory, in this case changes1, with this command:
$ torizoncore-builder isolate --remote-host 192.168.1.117 --remote-username torizon --remote-password torizon --changes-directory changes1
Changes in /etc successfully isolated.
In order to keep credentials (files and directories permissions and ownership) the isolate command will create the file /etc/.tcattr which will be automatically used later by the union command.
For more details about the isolate command, please check the isolate command in the commands manual.
Applying Captured Changes to a Custom Image
Approach 1: Applying Changes to a Custom Image Using the Build Command
TorizonCore Builder build command generates a custom Torizon OS image with the captured configuration changes, ready to be installed with Toradex Easy Installer, named torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM in the example below. This is achieved using a configuration YAML file, tcbuild.yaml as default.
It requires a Toradex Easy Installer image of Torizon OS (preferably without containers), torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar in this case, as input. The directory (or directories) with the captured configuration changes is passed as customization: filesystem.
# Sample configuration file:
input:
easy-installer:
#Sample customization: insert the configuration changes made in the device
customization:
filesystem:
- changes1/
output:
easy-installer:
Build The Custom Image
$ torizoncore-builder build
Pulling done.
Deploying done.
Packing rootfs...
Packing rootfs done.
- Using Toradex Easy Installer, the recommended method for production programming.
- Directly on the board through SSH, the recommended method during development.
- Through Torizon Cloud server, the recommended method to perform updates on a device already deployed to the field.
- It's also possible to use a static-delta approach, which is more network efficient.
Copy the output image into a USB stick and follow the steps in the Toradex Easy Installer article linked preceding. The copy of the output image can be done with the command following:
Directly, through SSH
In this case, before deployment the output image needs to be unpacked, using the command following:
To deploy it directly to the board, through SSH, use the command following:
Torizon Cloud
To deploy it to the Torizon Cloud Update Service, use the command following:
Approach 2: Applying Changes to a Custom Image: Using Standalone Commands
In this second approach, instead of using a configuration YAML file and a one-step command, the generation of the custom Torizon OS with the captured configuration changes is done using standalone commands, each performing one step towards this generation.
This approach is especially useful when making incremental changes, generating multiple images with captured configuration changes (or other customizations like different device tree overlays). Including a directory with captured changes on an image of Torizon OS is just a matter of passing it as a --changes-directory argument to the union command. Therefore, it is just necessary to perform the union and deploy stages (also the isolate step is necessary if you want to capture the new configuration changes from the device).
To generate a custom Toradex Easy Installer image with the desired directories with captured configuration changes follow the sequence of steps below.
You just need to execute once. Then, you are ready to apply multiple changes to the image. For example, in addition to applying configuration changes captured from the device, you can also apply a custom splash screen, a new device tree, among other possibilities.
Merge Changes
As a reminder, you must have captured changes as explained previously.
Merge the captured configuration changes (as well as other customizations like a kernel module or a device tree) into the base Toradex Easy Installer image of Torizon OS - use whatever branch name you want.
- Versions 3.0.0 or Later
- Versions Before 3.0.0
$ torizoncore-builder union --union-branch=custom-branch
First, to generate a Toradex Easy Installer image, into the output directory torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM, use the command following:
Copy the output image into a USB stick and follow the steps in the Toradex Easy Installer Tool article linked preceding. The copy of the output image can be done with the command following:
To deploy it to the Torizon Cloud Remote Update Service, use the command following:
Verifying The New Custom Image On The Device
# sudo ostree admin status
Password:
- The one in the output of the
unioncommand in the case of the standalone commands - The one in the "Deploying OSTree with checksum ..." part of the output of the
buildcommand.
