Bluetooth Audio (Linux)
Article updated at 09 Mar 2021
This article describes how to play audio over a Bluetooth device using the A2DP profile with Embedded Linux. For modules that don’t come with Bluetooth hardware on-module, support can easily be added by using a USB Bluetooth module. The table below presents the modules with integrated Bluetooth:
Family Module Version Bluetooth adapter Description
Colibri iMX6ULL 512MB Wi-Fi / Bluetooth Wi2Wi WM828CC6 Bluetooth 4.2/BLE (Dual-Mode)
Supported BSP
The bluez-alsa package is included since BSP 2.8b3.
Configuring the Device
Enable Bluetooth as described in the Bluetooth (Linux) article.
After enabling Bluetooth, restart the bluez-alsa service:
systemctl restart bluez-alsa.service
Edit:
/etc/dbus-1/system.d/bluetooth.conf
... <policy user=”bluealsa”> <allow send_destination=”org.bluez”/> </policy> </busconfig>
Connect to the Bluetooth device as described in the Bluetooth (Linux) articele.
Using blue-alsa
To play an audio file:
aplay -D bluealsa:HCI=hci0,DEV=[Device MAC],PROFILE=a2dp audio.wav
To set HCI, DEV and PROFILE as default create or modify:
~/.asoundrc
defaults.bluealsa{ interface "hci0" device "[Device MAC]" profile "a2dp" }
With this configuration file in place aplay can be used without any device specification and it will play through Bluetooth.
To change volume level on the module use:
alsamixer -D bluealsa
