or cat /etc/issue
on the board.
TensorFlow is a popular open-source platform for machine learning.Tensorflow Lite is a set of tools to convert and run Tensorflow models on embedded devices.
Through Torizon, Toradex provides Debian Docker images and deb packages that greatly ease the development process for several embedded computing applications. In this article, we will show how you can quickly build an application with Tensorflow Lite using Python for distinct NXP's i.MX SoC, such as i.MX8, i.MX8X, i.MX8MM, i.MX7 and i.MX6 with Torizon.
Attention: This Tensorflow Lite implementation executes in CPU only at this moment. We plan to provide Tensorflow Lite with GPU/NPU acceleration. Contact us if you need more information.
This example uses Tensorflow Lite libraries with Python. It executes a slightly modified version of the sample extracted from the official Tensorflow Lite tutorial to perform an inference using Image Classification model. You can adapt other machine learning models quickly from this sample implementation.
This example takes an image as input, resize it, use it as an input for the model, and prints its output.
Result:
image.jpg : Maltese dog
Inference time: 0.1774742603302002 s
If you only want to see the sample project in action, in your board terminal, download the specific docker-compose file targeting your architecture and run the containers:
# wget https://raw.githubusercontent.com/toradex/torizon-samples/bullseye/tflite/docker-compose.yaml
# docker-compose up
In this article, we will explore the demonstration example available on the Toradex samples repository.
To obtain the files, clone the torizon-samples repository to your computer:
$ cd ~
Select your SoM from the boxes below:
First, in your PC terminal, build the sample project:
$ cd torizon-samples/tflite
$ docker build -t <your-dockerhub-username>/tflite_example .
$ docker push <your-dockerhub-username>/tflite_example
$ docker build --build-arg ARCH_ARG=linux/arm --build-arg PKG_ARCH=armv7l -t <your-dockerhub-username>/tflite_example .
Please remember that if you once built your image for one architecture, you need to pass the --pull
argument to build for another architecture. According to the Docker documentation, the pull
argument will always attempt to pull a newer version of the image.
Example:
$ docker build --pull .
After building the Dockerfile image above and pushing it to your Dockerhub, you need to edit the docker-compose.
Edit the image field of the example with your image repository:
docker-composeversion: "2.4" services: tflite-example: image: your-username/tflite_example volumes: - /tmp:/tmp - /sys:/sys - /dev:/dev
After filling it, save and send this file to your module using scp
$ scp <your-docker-compose-file> torizon@<your-ip>:/home/torizon
Now enter your module's terminal using SSH:
$ ssh torizon@<target-ip>
Note: For more information about SSH, please refer to SSH on Linux.
Now you can launch the sample application by using the command:
# docker-compose -f <your-docker-compose-file> up
In our project, we implemented the code on the main.py
file.
First, our script imports the Tensorflow Lite, NumPy, and PIL Libraries:
import tflite_runtime.interpreter as tf
import numpy as np
from PIL import Image
On the main function, it loads the Image Classification model:
# Load the TFLite model and allocate tensors.
interpreter = tf.Interpreter(model_path="mobilenet_v1_1.0_224_quant.tflite")
interpreter.allocate_tensors()
# Load object labels
with open('labels_mobilenet_quant_v1_224.txt') as f:
labels = f.readlines()
# Get input and output tensors.
input_details = interpreter.get_input_details()
output_details = interpreter.get_output_details()
nn_input_size=input_details[0]['shape'][1]
We will resize the image to the corresponding input size of the network (224x224 in this example):
# Resize image to the input size of the model adding padding if necessary
width, height = img.size
if width>height:
img_resized=Image.new("RGB",(width,width))
if width<height:
img_resized=Image.new("RGB",(height,height))
img_resized.paste(img)
img_resized = img_resized.resize((nn_input_size,nn_input_size))
np_img = np.array(img_resized)
input_data=[np_img]
And finally, we will set the input tensor, execute the inference and print the result:
# Set the input tensor
interpreter.set_tensor(input_details[0]['index'], input_data)
# Execute the inference
t1=time()
interpreter.invoke()
t2=time()
# Find highest score into the result array and print the corresponding label
output_data = interpreter.get_tensor(output_details[0]['index'])
print(filename,':',labels[np.where(output_data[0]==np.amax(output_data[0]))[0][0]],flush=True)
print('Inference time:',t2-t1,'s')
This file configures the application's services. It informs the Docker runtime which containers the system will run, set privileges, among other options.
This example has a very simple Docker Compose to start the demo application.
In this section, you will go through some relevant snippets containing information about the Dockerfile.
Toradex provides several Debian Containers for Torizon. For this demonstration, we use the base image torizon/debian
, which is available for both 32 and 64-bit architectures.
If you are using an iMX8 (arm64v8 CPU) computer-on-module (COM) use --platform=linux/arm64
and set the variable PKG_ARCH=aarch64
. Otherwise, use --platform=linux/arm
and set PKG_ARCH=armv7l
Choose from the tabs:
ARG ARCH_ARG=linux/arm64
ARG PKG_ARCH=aarch64
FROM --platform=$ARCH_ARG torizon/debian:2-bullseye
The following Dockerfile lines of the example takes the .whl file from the Tensorflow Lite repository and use pip3
to install the required packages:
ENV TFLITE_LINK https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp37-cp37m-linux_aarch64.whl
RUN wget $TFLITE_LINK && pip3 install tflite_runtime-* && rm tflite_runtime-*
ARG PKG_ARCH=armv7l
ENV TFLITE_LINK https://dl.google.com/coral/python/tflite_runtime-2.1.0.post1-cp37-cp37m-linux_armv7l.whl
We also install Python in the example Dockerfile.
A Toradex's SoM with TorizonCore installed (To get instructions about how to install TorizonCore, see Quickstart Guide)
Basic knowledge of Docker containers. To learn more about Docker, visit the developer's website. To understand the first steps with Docker usage and TorizonCore, check the Quickstart Guide.
Configure Build Environment for Torizon Containers on your Linux development PC.
Result:
# wget https://github.com/toradex/torizon-samples/raw/master/tflite/docker-compose.yaml
# docker-compose up
$ cd ~
Example:
file.
import numpy as np
if width>height:
if width<height:
input_data=[np_img]
t1=time()
t2=time()
Toradex provides a basic Debian image in its Dockerhub page. If you are using an iMX8 (arm64v8 CPU) computer-on-module (COM) add torizon/arm64v8-debian-base
to your image. Otherwise, add torizon/arm32v7-debian-base
. It contains the repository package.
FROM torizon/arm64v8-debian-base
FROM torizon/arm32v7-debian-base
