Version: Torizon OS 7.x.y
Commands Manual - TorizonCore Builder - 3.0.0 and Later
TorizonCore Builder is a tool that enables customizations such as including a splash screen, an overlay, preinstalled containers, capturing device configurations, and more, on Torizon OS in an easy way. The end result is a custom Torizon OS image prepared for production programming.
To learn more about the tool and how to get started, please refer to TorizonCore Builder Tool page.
This Commands Manual contains a detailed explanation of all TorizonCore Builder commands as well as examples of how to use them. At the end you can find quick reference examples.
Requirements​
TorizonCore Builder and OSTree​
TorizonCore Builder relies on the OSTree library to capture and apply changes to the filesystem. The tool is designed to abstract OSTree as much as possible, enabling users to focus on image customization without interacting directly with the underlying technology.
OSTree, officially named libostree, manages updates for the entire Linux root filesystem tree. The library uses a Git-like model to version, commit, and deploy bootable filesystem trees. OSTree is a core technology used by Torizon Updates and is essential to the operation of TorizonCore Builder.
Refer to OSTree documentation for more details on its architecture and integration with the Torizon OS ecosystem.
The torizoncore-builder Command​
TorizonCore Builder tool can work either by providing the working directory (capable of carrying Linux filesystem metadata) or Docker volumes for intermediate data storage. So all commands are explained with both approaches.
The usage of the torizoncore-builder command (or, more precisely, alias) can be shown by its --help switch:
Usage​
$ torizoncore-builder --help
usage: torizoncore-builder [-h] [--verbose] [--log-level LOG_LEVEL] [--log-file LOG_FILE] [-v]
{build,bundle,combine,deploy,dt,dto,images,isolate,kernel,ostree,platform,push,secboot,splash,ubootenv,union} ...
TorizonCore Builder is an utility that allows to create customized Torizon OS OSTree commits and Toradex Easy Installer
images without rebuilding the complete operating system.
optional arguments:
-h, --help show this help message and exit
--verbose show more output
set global log level (debug, info, warning, error, critical)
--log-file LOG_FILE write logs to a file instead of console
-v, --version show program's version number and exit
Commands:
build Customize a Toradex Easy Installer image based on settings specified via a configuration file.
bundle Create container bundle from a Docker Compose file. Can be used to combine with a TorizonCore base image.
combine Combines a container bundle with a specified Torizon OS image (Toradex Easy Installer or raw/WIC)
deploy Deploy unpacked image as a Toradex Easy Installer image or raw disk format.
dt Manage device trees
dto Manage device tree overlays
images Manage Toradex Easy Installer Images.
isolate capture /etc changes.
kernel Manage and modify TorizonCore Linux Kernel.
ostree OSTree operational commands
platform Execute operations that interact with the Torizon Platform Services (app.torizon.io) or a compatible server
push Push artifact to OTA server as a new update package.
secboot Sign different components of an unpacked Torizon OS image in Toradex Easy Installer format.
splash change splash screen
ubootenv Manage U-Boot environment for Torizon OS images.
union Create a commit out of isolated changes for unpacked Toradex Easy Installer Image
Learn more on https://developer.toradex.com/knowledge-base/torizoncore-builder-tool
The various arguments listed are common to all commands. For example, one could enable the debug messages during the dt status command by doing:
$ torizoncore-builder --log-level debug dt status
The following items describe the commands offered by the tool.
The build Command​
build provides full customization of an image as a single step based on a configuration file.
This is the command you should use to prepare images for production programming and provisioning multiple devices
Please refer to the following specific articles for details
Usage​
$ torizoncore-builder build --help
usage: torizoncore-builder build [-h] [--create-template] [--file CONFIG] [--force]
[--set ASSIGNMENT] [--no-subst]
optional arguments:
--create-template Request that a template file be generated with the name defined by --file;
dump to standard output if file name is set to '-'.
--file CONFIG Specify location of the build configuration file (default: tcbuild.yaml).
--force Force program output (remove output directory before starting the build
process).
--set ASSIGNMENT Assign values to variables (e.g. VER="1.2.3"). This can be used multiple
times.
--no-subst Disable the variable substitution feature.
Configuration File Contents​
The configuration file follows the YAML format and syntax. The tool expects it to be made up of three sections, represented by the top-level properties (keys): input, customization and output as outlined following:
# Configuration file outline:
input:
customization:
output:
The following sections describe each one of these properties. The descriptions follow the standard nested parameter layout, where input.easy-installer.local refers to the property local inside easy-installer, which is inside the input section.
The expected types of the elements in the file are indicated within parenthesis: objects are elements having child properties that in YAML parlance make up a mapping; string, boolean, number, integer types are leaf elements; properties of type array of a certain type represent sequences in the YAML naming.
It is recommended to use double quote " characters around string values (even though they are not required in YAML) just to avoid them to be interpreted as numbers in some cases.
Many properties in the configuration file accept file-system paths. Relative paths (those not starting with /) are interpreted relative to the working directory of torizoncore-builder -- typically defined when the tool’s invocation alias is created -- and must point to locations within that directory. Absolute paths (those beginning with /) are also supported; however, they must be specified from the perspective of the container in which torizoncore-builder runs. Because this can introduce confusion or unexpected lookup issues, the use of absolute paths in the configuration file is generally discouraged.
Input Section​
The input section defines the source artifact for customization. The definition can be provided in three different ways (mutually exclusive): easy-installer, raw-image, or ostree.
  • image-download-dir (string, optional): Path of a local directory where the input Torizon OS image is saved after being downloaded via the remote or toradex-feed sub-properties of easy-installer or raw-image. If not set, the image is downloaded to a temporary directory and not saved.
  • easy-installer (object): With this property, the source for customization is a Toradex Easy Installer image, which, in turn, can be specified in three different ways (also mutually exclusive):
    • local (string): Specifies a local directory or tarball containing the image.
    • remote (string): Specifies an HTTP or HTTPS URL used to download the image. For integrity checks, the expected SHA-256 checksum of the file can be appended to the path part of the URL using a semicolon as separator, for example: https://artifactory.toradex.com/.../tezi-image.tar;sha256sum=ad523…da02?key=val1&key2=val2. Notice that the sha256sum parameter comes before the query parameters (if any). The name of the downloaded file is determined from the last part of the path (the so called slug), if present. The parameter filename can be employed to force a specific name for the file, for example: https://artifactory.toradex.com/.../tezi-image.tar;filename=teziimage_new.zip?key=val1&key2=val2.
    • toradex-feed (object): Defines individual image attributes that are used by the tool to download a standard image from the official feed server. Images downloaded this way are automatically verified against a SHA-256 checksum provided by the feed server.
      • version (string): Software version in the form major.minor.patch (for example, “7.5.0”).
      • release (string: nightly/monthly/quarterly) Release type (to choose the feed used).
      • machine (string): One of the supported module types (for example, aquila-imx95, verdin-imx8mp, toradex-smarc-imx95, apalis-imx8, colibri-imx7-emmc, etc.).
      • distro (string: torizon/torizon-rt/torizon-upstream/torizon-upstream-rt): Distribution type (at the moment, the supported options are regular kernel or PREEMPT_RT).
      • variant (string: torizon-docker/torizon-podman, optional): Variant of the Torizon image.
      • build-number (string or number): Build number as a string or number, for example “252” or 252.
      • build-date (string or number): Build date as a string or number, for example "20210408" or 20210408 -- this property is not required when using a quarterly release.
  • raw-image (object): With this property, the source for customization is a Torizon OS image in raw disk format (a .wic or .img file), such as the images produced for Common Torizon boards. It can be specified in the same three mutually exclusive ways as easy-installer:
    • local (string): Specifies a local .wic or .img file.
    • remote (string): Specifies an HTTP or HTTPS URL used to download the image, accepting the same filename and sha256sum options described for easy-installer.remote preceding.
    • toradex-feed (object): Accepts the same properties as easy-installer.toradex-feed described preceding. For raw images, distro may also be set to a Common Torizon value (for example, common-torizon) matching the image being downloaded.
    • rootfs-label (string, optional): Filesystem label identifying the rootfs partition inside the raw image. Default: otaroot.
  • ostree (object): not available yet.
For more information about the input parameters, refer to Build Torizon OS from Source With Yocto Project/OpenEmbedded and Reference Documentation for Toradex BSP Layers and Reference Images for Yocto Project articles.
Customization Section​
The customization section determines the modifications to be applied to the input to produce the desired output. It has the following structure:
  • splash-screen (string, optional): Local path of a PNG file used to generate the splash screen image.
  • filesystem (array of strings, optional): List of directories to be merged with the input -- the corresponding directory trees are applied on top of the ones present in the input image, in the listed order. These directory trees can be created manually or as a result of customizing a live device and running the torizoncore-builder isolate command.
  • device-tree (object, optional): This entry allows the configuration of a base device tree (describing the whole hardware setup of the target device) and of additional overlays (describing specific peripherals or configurations).
    • include-dirs (array of strings, optional): List of directories where to look for include files while compiling device tree source files (used both for full device trees and for overlays).
    • custom (string, optional): Path of a device tree source (dts) file that is built and integrated with the image, replacing existing ones. Beware that when a custom device tree is set, all overlays possibly present in the base image are cleared.
    • overlays (object, optional):
      • clear (boolean, optional): Boolean indicating whether or not to ignore all the binary overlays (dtbo files) that may already be present in the base image. This property is useful only if no custom device tree was set. Default: false.
      • remove (array of strings, optional): List of specific binary overlays (only the base names of the dtbo files) to be ignored or not taken from the base image. This property is useful only if no custom device tree was set.
      • add (array of strings, optional): List of paths for device tree source files that are compiled and added to the image. Those overlays provide specific changes to the base device tree and are applied in the order listed in the configuration file. The tool tests the overlay against the current device tree (DT) only if a DT has been set (via the custom property or predefined in the base image).
  • kernel (object, optional): This property provides access to the facilities provided by the torizoncore-builder kernel command.
    • arguments (array of strings, optional): List of custom arguments to be passed to the kernel of the customized image.
    • modules (array of objects): List of kernel modules to be built from source and deployed with the image.
      • source-dir (string): Path to directory containing the kernel module source code. For further details, please refer to Building External Kernel Modules With Torizon.
      • autoload (boolean, optional): Boolean indicating whether the module should be automatically loaded upon system boot.
  • secboot (object, optional): This section includes configurations related to Secure Boot.
    • sign-bootloader-hab (object, optional): Bootloader signing configuration for NXP SoCs supporting HAB.
      • cst-dir (string): Path to the pre-configured CST directory.
      • cst-args (object): CST related options.
        • crypto (string): Type of cryptographic keys used to sign the bootloader.
        • key-size (string): RSA key length in bits; ECDSA string from generated cert file.
        • key-exp (string): RSA key exponent.
        • dig-algo (string): Digest algorithm as provided in CST.
        • srk-index (string): Index of the SRK table to be used for signing.
        • srk-table (string): SRK table binary filename.
        • srk-fuse (string): SRK fuse binary filename.
        • srk-no-ca-flag (boolean): Indicates if the CA flag was not set when generating the SRK certificates.
      • kernel-key-dir (string): Path to kernel key directory.
      • kernel-key (array): List of keys to be used to verify the kernel FIT.
        • name (string): Name of the key, corresponding to its filename without the file extension.
        • algo (string): Hashing and crypto algorithms used to verify and sign the kernel.
    • sign-kernel (object, optional): Kernel signing configuration.
      • kernel-key (array): List of keys used to sign the kernel FIT image.
        • algo (string): Hashing and crypto algorithms used to sign the kernel.
      • ostree-key-dir (string): Path to OSTree key directory.
      • ostree-key (array): List of OSTree public signing keys to be added to the kernel FIT image.
        • algo (string): Crypto algorithm used to generate the key.
    • sign-ostree (object, optional): OSTree signing configuration.
      • ostree-key (array): List of private keys to sign the OSTree commit.
Output Section​
The output section provides the details about the output artifacts to be produced by the torizoncore-builder build command. Exactly one of raw-image or easy-installer must be provided to define the output image; ostree is optional and applies regardless of the chosen output format. The section has this structure:
  • ostree (object, optional): The configuration items that are specific to OSTree are kept under this property; they directly relate to the torizoncore-builder union command.
    • branch (string, optional): Name of the OSTree repository branch that contains the commit with the changes applied by the tool.
    • commit-subject (string, optional): OSTree commit subject. Default: "TorizonCore Builder <timestamp>"
    • commit-body (string, optional): OSTree commit body message.
  • easy-installer (object, optional): The configuration items specific to the Toradex Easy Installer image output are under this property.
    • local (string): Name of a local directory for the generated image.
    • name (string, optional): Name of the image as shown by the installer.
    • description (string, optional): Short description of the image (displayed in the image list screen of the installer).
    • licence (string, optional): Path of an HTML file with the image licence (displayed before installation when running interactively).
    • release-notes (string, optional): Path of an HTML file with the image release notes (accessible from the installer UI).
    • accept-licence (boolean, optional): Accept/Deny the licence. Licence acceptance is required when autoinstall is enabled.
    • autoinstall (boolean, optional): Set the value of the autoinstall property on the image.json file.
    • autoreboot (boolean, optional): Add/Remove auto-reboot in the wrapup.sh file.
    • bundle (object, optional)—first form: Specifies a Docker compose file to be processed. The container images referenced by the compose file are fetched during build time and a modified version of the compose file referencing the fetched image IDs is stored in the output image.
      • compose-file (string): Path of a Docker Compose file that is included in the final image along with the required container images (that is, with the images referenced by it). This is considered only if the image variant is torizon-core-docker.
      • platform (string, optional): Platform for fetching multi-platform container images. If not specified, the tool selects between linux/arm/v7 or linux/arm64 depending on the architecture of the input image.
      • username (string, optional): Docker login username to be used if accessing a private registry is required.
      • password (string, optional): Docker login password to be used if accessing a private registry is required.
      • registry (string, optional): Registry host name (for example, docker.io); this is used only if username is also set.
      • ca-certificate (string, optional): Path to a CA certificate file to be used for accessing a private registry; this is used only if registry is also set.
      • keep-double-dollar-sign (boolean, optional): Keep double dollar sign instead of replacing it with a single one when parsing string values of the compose file.
      • dind-params (array of strings, optional): List of parameters to pass to the Docker-in-Docker container executed by the tool when fetching containers to produce a bundle.
      • dind-env (array of strings, optional): List of environment variables to pass to the Docker-in-Docker container executed by the tool when fetching containers to produce a bundle; each string should be in the form VARIABLE=VALUE.
    • bundle (object, optional)—second form:
      • dir (string): Path to directory containing the container images bundle to be combined with the installer image. Such bundle can be obtained by executing the torizoncore-builder bundle command beforehand.
    • provisioning (object, optional): Data for provisioning a device for secure updates are under this property.
      • mode (string): This string field defines the provisioning mode and can be set to one of the following three values:
        • disabled: Disable provisioning completely;
        • offline: With this mode, a device where the resulting image is installed is ready to accept offline-updates produced by the Torizon Cloud account from where the "shared data" came from;
        • online: With this mode, a device where the resulting image is installed contains information allowing it to automatically register itself to the Torizon Cloud (using credentials contained in the "online data" coming from a certain Torizon Cloud account); besides it is also able to accept offline-updates.
      • shared-data (string): Path to archive containing shared data; such an archive can be obtained from the Torizon Cloud via the torizoncore-builder platform provisioning-data command. This property must be set both in offline and online modes.
      • online-data (string, optional): String containing sensitive data required for online provisioning (base64-encoded); such data can also be obtained from the Torizon Cloud via the torizoncore-builder platform provisioning-data command or even directly from the UI. The property must be set only in online mode and it is recommended to set it by employing variable substitution whenever possible - this way, its value can be kept outside of version control (for example, one can keep the sensitive data as an environment variable in their CI system which would be passed to torizoncore-builder upon build time only).
      • hibernated (boolean, optional): Add/Remove flag to auto-provision in hibernated mode (Torizon OS 6.8+). Hibernated devices are registered, but cannot receive updates from Torizon Cloud nor send data to it. Check this section for more details about hibernation.
      • fleets (array of strings, optional): List of Torizon Cloud fleet UUIDs (Torizon OS 7.7+) that a self-provisioning device tries to join; only meaningful in online mode. Check Devices Fleet Management for more details about fleets.
--hibernated is currently only available in the early access version of TCB. For more details about this version, check the setup script section.
warning
Hibernation Mode is deprecated. Do not use it in new projects. Refer to Hibernation Mode for details, or please contact us if your project depends on it.
  • raw-image (object, optional): The configuration items specific to a raw disk (.wic/.img) image output are under this property; use it instead of easy-installer to produce the customized image in raw disk format, such as for Common Torizon boards.
    • local (string): Path of the output .wic/.img file to be generated.
    • base-rootfs-label (string, optional): Filesystem label identifying the rootfs partition inside the base raw image. Default: otaroot.
    • base-image (string, optional): Path to the base raw image to use as the starting point for the output. Defaults to the same image specified in input.raw-image; avoid changing this unless necessary.
    • bundle (object, optional): Same structure as the bundle property described preceding for easy-installer. The root filesystem of the raw disk image is automatically expanded if the bundled containers would not otherwise fit.
    • provisioning (object, optional): Same structure as the provisioning property described preceding for easy-installer, including the fleets property.
Command-Line Interface​
The build command has two different modes of operation. The first one allows the creation of a template configuration file that can then be modified to suit one's needs. In this case, usage is:
torizoncore-builder build [--file NAME] --create-template
If NAME is not passed, the tool assumes the default filename of tcbuild.yaml. It is possible to check how a template configuration file is created before creating it. To do this, one would provide the tool with a filename like - which causes it to dump the template file contents to standard output, for example:
$ torizoncore-builder build --file - --create-template
The second mode of operation, when the switch --create-template is not passed, corresponds to the normal operation mode of the tool where it actually processes the configuration file to perform the customization. Usage:
torizoncore-builder build [--file NAME] [--set VAR=VALUE] [--no-subst] [--force]
Again, if NAME is not passed the tool assumes the default filename of tcbuild.yaml (taken as input in this case). Variables used in the configuration file can be set via the --set parameter (for example, --set USERNAME="user1"). The variable substitution feature which is enabled by default can be disabled completely by the --no-subst switch. The --force switch tells the tool to automatically remove the output if it already exists (by default, build fails in that case).
Bundling Options​
The tcbuild.yaml file allows you to include containers in the generated images using different configuration options. The most straightforward method is to reference the Docker Compose file directly in tcbuild.yaml:
tcbuild.yaml
output:
easy-installer:
bundle:
compose-file: docker-compose.yml
This is the simplest mechanism and works for most use cases. However, the bundle standalone command supports additional options that are not available when using the tcbuild.yaml approach. Notably, it allows you to specify login credentials for multiple Docker registries, which may be required by some commercial registry providers.
In addition, running the bundle command directly gives users control over how frequently containers are pulled from the registry. In this workflow, you create the bundle directory separately and then reference it in your tcbuild.yaml file, rerunning the bundle command only when the upstream container images change.
tcbuild.yaml
output:
easy-installer:
bundle:
dir: bundle
$ torizoncore-builder bundle --bundle-directory bundle docker-compose.yml
Image Handling​
The images Command​
images gets the base Torizon OS image, either in Toradex Easy Installer or raw disk (.wic/.img) format, and unpacks the rootfs (OSTree filesystem) to a Docker volume. This command has the following subcommands and options:
$ torizoncore-builder images --help
usage: torizoncore-builder images [-h] [--remove-storage]
{download,provision,serve,unpack} ...
options:
--remove-storage Automatically clear storage prior to unpacking a new
Easy Installer image.
Commands:
download Download image from Toradex Artifactory and unpack it.
provision Generate a Toradex Easy Installer or WIC/disk image
with provisioning data for secure updates.
serve Serve TorizonCore Toradex Easy Installer images via
HTTP.
unpack Unpack a specified Toradex Easy Installer or WIC/raw
image so it can be modified with the union subcommand.
images download​
warning
Pre-production level Easy Installer images (monthly, nightly) are regularly pruned from the Toradex Artifacts server. This may result in download not being able to locate the image.
Connects to a remote Torizon device and via the version information determines the source Easy Installer image. The deduced image is then downloaded from the Toradex Artifacts repository into the user's working directory, and automatically verified against a SHA-256 checksum provided by the server. Finally, the command unpacks the rootfs (OSTree filesystem) of the downloaded image to a Docker volume.
Usage​
$ torizoncore-builder images download --remote-host <hostname/IP address of target board> --remote-username <username on target board> --remote-password <password of user on target board> --remote-port <ssh port of the remote target machine>
Arguments​
--remote-host: the IP or hostname of the target board
--remote-username: username of the target board, to be used for creating SSH session.
--remote-password: user password of the target board, to be used for creating SSH session
--remote-port: the SSH port of the target board, to be used for creating SSH session
Example​
With Docker Volume​
$ torizoncore-builder images download --remote-host <hostname/IP address of target board> --remote-username <username on target board> --remote-password <password of user on target board> --remote-port <ssh port of the target board>
Without Docker Volume​
Additional argument --storage-directory specified with alias torizoncore-builder, sets the path (capable of handling Linux filesystem metadata) to be used to store intermediate data. It is used to store unpacked OSTree rootfs as a result of this command.
$ torizoncore-builder --storage-directory <path to user storage directory> images download --remote-host <hostname/IP address of target board> --remote-username <username on target board> --remote-password <password of user on target board> --remote-port <ssh port of the target board>
images provision​
Generate a Toradex Easy Installer image or a raw disk (.wic/.img) image with provisioning data so that when deployed during production programming, the programmed devices can be configured for using Torizon Cloud features, such as secure updates, devices monitoring, and new features to be released.
When generating images deployed as updates, you should not generate the new images with the provisioning data. You just have to maintain the configuration changes in case of using offline updates.
There are two types of provisioning at the moment:
  • offline: a device where the resulting image is installed is ready to accept offline-updates produced by the Torizon Cloud account from where the "shared data" came from;
  • online: a device where the resulting image is installed contains information allowing it to automatically register itself to the Torizon Cloud (using credentials contained in the "online data" coming from a certain Torizon Cloud account); besides it is also able to accept offline-updates.
In online mode, the --fleet switch (Torizon OS 7.7+) assigns the device to one or more existing fleets on the Torizon Cloud account; a device that provisions itself also tries to join the fleets corresponding to the provided UUIDs.
warning
Usage​
$ torizoncore-builder images provision -h
usage: torizoncore-builder images provision [-h] --mode {offline,online}
[--force]
[--shared-data SHARED_DATA_FILE]
[--online-data ONLINE_DATA]
[--hibernated] [--fleet FLEETS]
[--raw-rootfs-label LABEL]
INPUT_PATH OUTPUT_PATH
positional arguments:
INPUT_PATH Path to input Torizon OS image.
OUTPUT_PATH Path to output Torizon OS image, which will hold
provisioning data.
options:
Select type of provisioning; online mode encompasses
offline mode.
starting process).
Archive containing shared provisioning data.
provisioning (base64-encoded).
--hibernated (Torizon OS 6.8+) Add flag to auto-provision in
hibernated mode. Hibernated devices are registered,
data to it.
--fleet FLEETS (Torizon OS 7.7+) Add fleet UUID to the provisioning.
Devices that provision themselves will also try to be
added to the fleet corresponding to the provided UUID.
Can be passed multiple times to signify multiple
fleets.
(raw images only) rootfs filesystem label of source
WIC/raw image. (default: otaroot)
INPUT_PATH and OUTPUT_PATH accept either a Toradex Easy Installer image (directory or tarball) or a raw disk (.wic/.img) image; the --raw-rootfs-label switch is only relevant when provisioning a raw disk image.
Example​
$ torizoncore-builder images provision \
--mode online \
--shared-data shared-data.tar.gz --online-data DEFAULT \
--fleet 0dfab76b-5b71-4435-ab6f-c6cdc62690c6 \
torizon-core-docker-verdin-imx8mp-Tezi_7.7.0+build.1.tar \
torizon-core-docker-verdin-imx8mp-Tezi_7.7.0+build.1-provisioned.tar
images serve​
Serve (via HTTP) Torizon OS images from a directory so those images can be installed in a Toradex device using Toradex Easy Installer.
The torizoncore-builder image serve command only works for TorizonCore Builder running on Linux.
Usage​
$ torizoncore-builder images serve <Easy Installer images directory>
Example​
warning
The following example assumes that the customer has already built or downloaded a Torizon OS image and that it is stored inside an images/apalis-imx6-img directory.
Create a JSON file, called image_list.json, that defines images which should be shown as installation options to Toradex Easy Installer. The image_list.json file must be stored inside the images directory and should have the following format:
./images/image_list.json
"config_format": 1,
"images": [
"apalis-imx6-img/image.json"
An example of the layout of the image directory would be:
$ tree images/
images/
├── apalis-imx6-img
│ ├── image.json
│ ├── LA_OPT_NXP_SW.html
│ ├── marketing.tar
│ ├── prepare.sh
│ ├── SPL
│ ├── torizon-core-docker-apalis-imx6.ota.tar.zst
│ ├── u-boot.img
│ ├── u-boot-initial-env-spl
│ └── wrapup.sh
└── image_list.json
1 directory, 11 files
With this directory structure in place, execute:
$ torizoncore-builder images serve images/
From this moment on, TorizonCore Builder serves images to any board with Toradex Easy Installer executing on the local network.
It is possible to provide more than one image at the same time. In order to do this, you should list all the images directories inside the image_list.json file. For example:
"config_format": 1,
"images": [
"apalis-imx6-img1/image.json",
"apalis-imx6-img2/image.json",
"apalis-imx6-img3/image.json",
images unpack​
Takes a user-provided Toradex Easy Installer image or raw disk (.wic/.img) image and unpacks the rootfs (OSTree filesystem) to a Docker volume. It is not necessary to use this command if you have previously used images download.
Usage​
$ torizoncore-builder images unpack --help
usage: torizoncore-builder images unpack [-h] [--raw-rootfs-label LABEL] IMAGE
IMAGE Path to .wic/.img file, Easy Installer .tar file or
directory.
options:
--raw-rootfs-label is only relevant when unpacking a raw disk image; it identifies the filesystem label of the rootfs partition inside the image.
Example​
If there is already an unpacked OSTree filesystem, the user is prompted to delete it because currently, a single OSTree filesystem can be handled. This prompt can be automated via the --remove-storage argument of the images command.
With Docker Volume​
$ torizoncore-builder images unpack <path to base Toradex Easy Installer image of Torizon in the working directory>
Additional argument --storage-directory specified with alias torizoncore-builder, sets the path(capable of handling Linux filesystem metadata) to be used to store intermediate data. It is used to store unpacked OSTree rootfs as a result of this command.
$ torizoncore-builder --storage-directory <path to user storage directory> images unpack <path to base Toradex Easy Installer image of Torizon in working directory>
The union Command​
union makes an OSTree branch (containing the commit for changes) for all changes provided by the user to be made in OSTree rootfs of unpacked base Torizon image. It commits changes made by isolate, splash, dt and kernel commands to the OSTree repo, that is, the unpacked Torizon OS image (Toradex Easy Installer or raw disk format).
If the user has used the union command, the deploy command is necessary to deploy the OSTree branch either on the target machine connected via SSH OR onto the OSTree file system (from the unpacked Torizon OS image) and to create a new Toradex Easy Installer or raw disk image of Torizon.
When using the optional --changes-directory parameter, the user has the possibility to set attributes (permissions and ownership) for files and directories that they would like to have set in the OSTree rootfs. That could be made using the .tcattr file.
The union command supports the Root filesystem protection feature available in Torizon OS. When using Torizon OS images with this feature enabled (referred to as torizon-signed images), users must provide an OSTree private signing key via the --ostree-key switch. If needed, they should also specify the directory containing the key files with the --ostree-key-dir option. Technically, this information is utilized by TorizonCore Builder to sign the hash of the composefs image that represents the root filesystem of an OSTree deployment. For simplicity, it can be said that the OSTree private key signs the root filesystem. At runtime, the corresponding public key embedded in the kernel FIT image is used by the system to validate this signature. Before executing the union command with the private signing key, users should set the corresponding public key in the kernel image using the secboot sign-kernel command.
warning
The Secure Boot features in TorizonCore Builder are currently in early access status. As a result, breaking changes may occur at any time. When working with Secure Boot, it is recommended to use the early-access version of TorizonCore Builder to ensure you have access to the latest features and an up-to-date CLI.
Usage​
$ torizoncore-builder union --help
usage: torizoncore-builder union [-h] [--changes-directory CHANGES_DIRS] [--subject SUBJECT]
[--body BODY] [--ostree-key OSTREE_KEY]
[--ostree-key-dir OSTREE_KEY_DIR]
UNION_BRANCH
UNION_BRANCH Name of branch containing the changes committed to the unpacked
repository.
options:
Path to the directory containing user changes (can be specified multiple
times). If you have changes in the storage, the changes passed in this
parameter will be applied on top of them.
--subject SUBJECT OSTree commit subject. Defaults to 'TorizonCore Builder [timestamp]'.
--body BODY OSTree commit body message
OSTree signing key information in the form 'name=<NAME>;algo=<ALGO>' where
<NAME> is the key name and <ALGO> corresponds to the signing algorithm
(e.g. 'name=prod;algo=ed25519'). If <ALGO> is not provided, it defaults to
'ed25519'. This switch must be specified if (and only if) the image being
customized has support for the root filesystem protection.
OSTree key directory path. This directory must contain a private key file
named <NAME>.sec, where <NAME> must be specified through the --ostree-key
switch.
The bundle Command​
This creates a tar archive of the container images referenced by the provided Docker Compose file and stores that archive in a bundle directory (which, by default, is named "bundle," but this can be changed via the --bundle-directory parameter). The bundle directory can later be provided to the combine command to create a Toradex Easy Installer image containing pre-installed container images. The Toradex Easy Installer tool copies containers data to appropriate places in rootfs while flashing the image on the target board.
warning
Container bundling relies on executing a Docker-in-Docker (DinD) instance on the host machine (which is automatically started/stopped by TorizonCore Builder).
For TorizonCore Builder versions before 3.15.0, the host's Docker daemon must use the overlay2 storage driver. Starting with version 3.15.0, either overlay2 or overlayfs (the default driver in Docker version 29) can be used.
Usage​
$ torizoncore-builder bundle --help
usage: torizoncore-builder bundle [-h] [--bundle-directory BUNDLE_DIRECTORY] [--force]
[--platform PLATFORM] [--keep-double-dollar-sign]
[--login USERNAME PASSWORD]
[--login-to REGISTRY USERNAME PASSWORD]
[--cacert-to REGISTRY CERTIFICATE] [--dind-param DIND_PARAM]
[--dind-env DIND_ENV]
[compose_file]
compose_file Compose file to be processed (REQUIRED); commonly named 'docker-
compose.yml'.
optional arguments:
Container bundle directory
--force Force program output (remove output directory before starting the bundle
generation process).
--platform PLATFORM Default platform for fetching container images when multi-platform images
are specified in the compose file (e.g. linux/arm/v7 or linux/arm64).
Don't replace '$$' with '$' when parsing string values of the input
compose file.
Request that the tool logs in to the default [Docker Hub] registry using
specified USERNAME and PASSWORD.
Request that the tool logs in to registry REGISTRY using specified
USERNAME and PASSWORD (can be employed multiple times).
Define a root CA CERTIFICATE (path to file in PEM format) to be used for
validating the certificate of the specified secure REGISTRY (when
connecting to it).
Parameter to forward to the Docker-in-Docker container executed by the
tool (can be employed multiple times). The parameter will be processed by
the Docker daemon (dockerd) running in the container. Please see Docker
documentation for more information.
--dind-env DIND_ENV Environment variable settings to forward to the Docker-in-Docker container
executed by the tool (can be employed multiple times), similar to passing
parameter --env to the 'docker' command.
NOTE: following switches have been removed: --docker-username, --docker-password, --registry,
--host-workdir and --file (-f); please review your command line if using any of them.
Example​
In its most basic form the command would be run simply as:
$ torizoncore-builder bundle docker-compose.yml
If the Docker Compose file references multi-platform images, then the --platform parameter would be required such as:
$ torizoncore-builder bundle docker-compose.yml --platform linux/arm/v7
The parameter --dind-param allows you to pass parameters to the Docker-in-Docker (DIND) container instance that torizoncore-builder uses to fetch images. One case where this is useful is when your Docker Compose file references insecure registries, in which case the DIND container needs to be informed about the registries to be accessed insecurely. In this example, registry running on machine with IP address 192.168.0.30, port 5001 is to be accessed in this manner:
$ torizoncore-builder bundle docker-compose.yml --platform linux/arm/v7 --dind-param="--insecure-registry=192.168.0.30:5001"
For more information about how to use the bundle command with Private Registries, read Remarks About using private registries
Similar to --dind-param, the parameter --dind-env allows one to pass environment variables to the DIND container instance responsible for fetching images. The following is an example of passing hypothetical variables VAR1 and VAR2 to the container instance:
$ torizoncore-builder bundle docker-compose.yml --platform linux/arm/v7 --dind-env VAR1='value 1' --dind-env VAR2='value 2'
Notice though that TorizonCore Builder also allows environment variables passed to the tool to be forwarded to the DIND container which may be more practical because their setting can be embedded into the torizoncore-builder alias. The TorizonCore Builder Setup Script employs that feature to deal with proxy connections, for example.
Limitations and Known Issues​
The combine Command​
combine command is used to create a Toradex Easy Installer or raw disk (.wic/.img) image of Torizon by combining a user-provided Torizon OS image (either base Torizon image OR output image from deploy command) with bundled Docker containers from bundle command.
When combining containers into a raw disk (.wic/.img) image, TorizonCore Builder automatically expands the image's root filesystem if the bundled containers would not otherwise fit.
Usage​
$ torizoncore-builder combine --help
usage: torizoncore-builder combine [-h] [--bundle-directory BUNDLE_DIRECTORY]
[--force] [--raw-rootfs-label LABEL]
[--image-name IMAGE_NAME]
[--image-description IMAGE_DESCRIPTION]
[--image-licence LICENCE_FILE]
[--image-accept-licence | --no-image-accept-licence]
[--image-release-notes RELEASE_NOTES_FILE]
[--image-autoinstall | --no-image-autoinstall]
[--image-autoreboot | --no-image-autoreboot]
IMAGE_PATH OUTPUT_PATH
IMAGE_PATH Path of Torizon OS image to be updated with docker
bundle.
OUTPUT_PATH Path of resulting Torizon OS image updated with docker
bundle.
options:
--force Force program output, overwriting any existing
file/directory.
(Easy Installer images only) Image name to be used in
Easy Installer image json.
(Easy Installer images only) Image description to be
used in Easy Installer image json.
(Easy Installer images only) Licence file which will
be shown on image installation.
--image-accept-licence, --no-image-accept-licence
(Easy Installer images only) Automatically accept the
image licence present in the input image or set by
--image-licence; Licence should be accepted every time
an image is generated.
(Easy Installer images only) Release notes file which
will be shown on image installation.
--image-autoinstall, --no-image-autoinstall
(Easy Installer images only) Automatically install
image upon detection by Toradex Easy Installer.
--image-autoreboot, --no-image-autoreboot
(Easy Installer images only) Enable automatic reboot
after image is flashed by Toradex Easy Installer.
NOTE: the switches --image-directory and --output_directory have been removed.
IMAGE_PATH and OUTPUT_PATH accept either a Toradex Easy Installer image (directory or tarball) or a raw disk (.wic/.img) image; the --raw-rootfs-label switch is only relevant when combining a raw disk image.
The deploy Command​
deploy takes a branch (containing the commit for changes) from the union command and deploys it to a Toradex Easy Installer image, a raw disk (.wic/.img) image, or a live device (via an SSH connection). When deploying to a Toradex Easy Installer image, the present command is commonly employed together with the commands bundle and combine; the former downloads container images and stores them into a bundle which can then be combined into a new installer image via the combine command. The bundled application containers can not be deployed using this command when targeting a live device.
Usage​
$ torizoncore-builder deploy --help
usage: torizoncore-builder deploy [-h] [--output-directory OUTPUT_DIRECTORY]
[--remote-host REMOTE_HOST]
[--remote-username REMOTE_USERNAME]
[--remote-password REMOTE_PASSWORD]
[--remote-port REMOTE_PORT]
[--mdns-source MDNS_SOURCE] [--reboot]
[--deploy-sysroot-directory DEPLOY_SYSROOT_DIRECTORY]
[--base-raw BASE] [--raw-rootfs-label LABEL]
[--output-raw OUT]
[REF]
REF OSTree reference to deploy.
options:
(Easy Installer images only) Output path for the
resulting Torizon OS image in Toradex Easy Installer
format.
Remote host machine to deploy to.
Username of remote machine (default value is torizon)
Password of remote machine (default value is torizon)
SSH port (default value is 22)
Use the given IP address as mDNS source. This is
useful when multiple interfaces are used, and mDNS
multicast requests are sent out the wrong network
interface.
--reboot Reboot machine after deploying
Work directory to store the intermittent deployment
sysroot. NOTE: OSTree need to be able to write
extended attributes in this directory. This seems to
only reliably work when using a Docker volume!
--base-raw BASE (raw images only) Base image that the deployment will
be based on i.e. the .wic/.img file used in the
'images unpack' command.
--output-raw OUT (raw images only) Output path for the .wic/.img file
to be deployed.
When deploying to a live device, at least switch --remote-host must be passed possibly along with the other --remote-... switches. Switches --image-... are relevant only when deploying to a Toradex Easy Installer image: they set properties inside the image.json file of the generated image. Switches --base-raw, --raw-rootfs-label, and --output-raw are relevant only when deploying to a raw disk image: --base-raw selects the source .wic/.img file (previously obtained with images unpack), and --output-raw sets the path of the resulting deployed image.
Example​
Deploying to a Live Device​
$ torizoncore-builder deploy my-branch --remote-host 192.168.0.34 --remote-username torizon --remote-password "1234"
Deploying to a Toradex Easy Installer Image​
$ torizoncore-builder deploy my-branch --output-directory my-custom-image-dir
Deploying to a Raw Disk Image​
$ torizoncore-builder deploy my-branch --base-raw torizon-core-common-docker-dev-intel-corei7-64.wic --output-raw my-custom-torizon-core-common-docker-dev-intel-corei7-64.wic
The ostree Command​
OSTree related operations.
Usage​
$ torizoncore-builder ostree --help
usage: torizoncore-builder ostree [-h] {serve} ...
optional arguments:
Commands:
{serve}
serve Serve OSTree on the local network using http
ostree serve​
Serve an OSTree repository via HTTP.
NOTE: users on Windows (WSL2) need to pass extra parameters to the environment setup script before using this command; this is required so that the port to which the server listens (8080) is published by the container running the tool. Example (Windows only):
$ . /path/to/tcb-env-setup.sh -- -p 8080:8080
Replace /path/to/tcb-env-setup.sh with the actual location of the setup script. The preceding note does not apply to users of Linux, where the setup script should be sourced as usual.
Usage​
$ torizoncore-builder ostree serve --help
usage: torizoncore-builder ostree serve [-h] [--ostree-repo-directory OSTREE_REPO_DIRECTORY]
optional arguments:
Path to the OSTree repository to serve (defaults to internal archive repository)
Image Customization​
The isolate Command​
isolate get configuration changes(modifications/addition/deletion/files and directories permissions and ownership) from the target board. It creates an SSH session with the target board to get changes and store them within Docker volume on the host.
isolate command gets the configuration (/etc) changes (modifications, additions, deletions, and files and directories permissions and ownership) from the user target module. It ignores the following files/directories for any change.
    'group-',
'shadow-',
'gshadow-',
'hostname',
'machine-id',
'ipk-postinsts',
'fw_env.conf',
'docker/key.json',
'.updated',
'.pwd.lock',
'ssh/ssh_host_rsa_key',
'ssh/ssh_host_rsa_key.pub',
'ssh/ssh_host_ecdsa_key',
'ssh/ssh_host_ecdsa_key.pub',
'ssh/ssh_host_ed25519_key',
'ssh/ssh_host_ed25519_key.pub',
'systemd/system/sysinit.target.wants/run-postinsts.service',
'ostree/remotes.d/toradex-nightly.conf',
Files and directories permissions and ownership are saved in the /etc/.tcattr metadata file together with all other isolated files.
Usage​
$ torizoncore-builder isolate --help
usage: torizoncore-builder isolate [-h] [--changes-directory CHANGES_DIR] [--force] --remote-host REMOTE_HOST
[--remote-username REMOTE_USERNAME] [--remote-password REMOTE_PASSWORD]
[--remote-port REMOTE_PORT] [--mdns-source MDNS_SOURCE]
optional arguments:
Directory to save the isolated changes from the device. Must be a file system capable of carrying Linux file system metadata (Unix file permissions and xattr). If not passed,
defaults to a directory in the storage volume.
--force Force removal of storage changes directory
name/IP of remote machine
Use the given IP address as mDNS source. This is useful when multiple interfaces are used, and mDNS multicast requests are sent out the wrong network interface.
Example​
You can find the example and detailed instructions on how to use isolate at the Capturing Changes in the Configuration of a Board on Torizon OS article.
The kernel Command​
kernel is used to make modifications related to the Linux kernel of Torizon OS, whether the unpacked image is a Toradex Easy Installer image or a raw disk (.wic/.img) image.
$ torizoncore-builder kernel --help
usage: torizoncore-builder kernel [-h] {build_module,set_custom_args,get_custom_args,clear_custom_args} ...
optional arguments:
Commands:
build_module Build the kernel module at the provided source directory.
set_custom_args Set the TorizonCore kernel arguments.
get_custom_args Get the TorizonCore kernel arguments.
clear_custom_args Clear the TorizonCore kernel arguments.
kernel build_module​
Build kernel modules from source and store the binary to be deployed to a Torizon OS system, whether the unpacked image is a Toradex Easy Installer image or a raw disk (.wic/.img) image. It can also configure the built kernel modules to be loaded at system boot.
Usage​
$ torizoncore-builder kernel build_module --help
usage: torizoncore-builder kernel build_module [-h] [--autoload] SRC_DIR
SRC_DIR Path to directory with kernel module source code.
optional arguments:
--autoload Configure kernel module to be loaded on startup.
Arguments​
--autoload: configures all built kernel modules to be loaded on system boot.
Example​
You can find an example and detailed instructions on how to use kernel build_module at the Building External Kernel Modules With Torizon article.
kernel set_custom_args​
Define custom arguments to be passed to the kernel of the image to be deployed, whether the unpacked image is a Toradex Easy Installer image or a raw disk (.wic/.img) image. Later executions of this command completely override the set of arguments previously defined.
tip
The article Customizing Kernel Arguments in Torizon explains the workflow for managing kernel arguments.
Normally, the custom arguments are appended to the default kernel arguments originally defined in the image. However, with Torizon OS images having support for Secure Boot, the behavior is different:
  • If the image was built with the Kernel command-line protection feature enabled, the custom arguments are instead prepended to the original arguments to ensure compatibility with that feature. This introduces a limitation whereby users may be unable to override the default arguments, as the custom arguments appear first on the kernel command-line.
  • When the mentioned feature is enabled, the fixed portion of the kernel command-line (which includes the original arguments plus the custom ones) is stored in an overlay (secboot-kargs_overlay) inside the kernel binary. TorizonCore Builder automatically updates the kernel command-line inside this overlay to meet the requirements of the Kernel command-line protection feature. Since this update modifies the kernel binary, users must re-sign it by running the secboot sign-kernel command to produce a valid, bootable image.
warning
With Secure Boot images:
  • Custom kernel arguments are prepended, rather than appended, to the kernel command-line; this may prevent users from overriding the default kernel arguments.
  • Changes to the kernel arguments require the re-signing of the kernel binary using the command secboot sign-kernel.
The method used by TorizonCore Builder to pass the custom arguments varies depending on the mechanisms available in the image:
  • With older images (before Torizon OS 7.5.0), custom arguments are stored into an overlay which is visible to and may be impacted by users. For example, that overlay (named custom-kargs_overlay) is shown by the command dto status and can be removed by dto remove; therefore, users need to take this into account when customizing device trees and overlays.
  • With newer images (Torizon OS 7.5.0 or later) the arguments are passed via environment variables stored in a file loaded by U-Boot (uEnv.txt) and device tree customizations do not affect custom kernel arguments.
warning
With Torizon OS images before version 7.5.0, users should take care when working with device trees and overlays to avoid unintentionally removing the custom-kargs_overlay, which stores the custom kernel arguments.
Usage​
$ torizoncore-builder kernel set_custom_args --help
usage: torizoncore-builder kernel set_custom_args [-h] KERNEL_ARGS [KERNEL_ARGS ...]
KERNEL_ARGS Kernel arguments to be added.
optional arguments:
Example​
$ torizoncore-builder kernel set_custom_args "param1=val1" "param2=val2"
Kernel custom arguments successfully configured with "param1=val1 param2=val2".
kernel get_custom_args​
Get the custom arguments to be passed to the Torizon OS kernel of the image to be deployed (as previously set by kernel set_custom_args).
Usage​
$ torizoncore-builder kernel get_custom_args --help
usage: torizoncore-builder kernel get_custom_args [-h]
optional arguments:
Example​
Currently configured custom kernel arguments: "param1=val1 param2=val2".
kernel clear_custom_args​
Clear the custom arguments to be passed to the kernel (previously set by kernel set_custom_args).
Usage​
$ torizoncore-builder kernel clear_custom_args --help
usage: torizoncore-builder kernel clear_custom_args [-h]
optional arguments:
Example​
Custom kernel arguments successfully cleared.
The secboot Command​
secboot is used to re-sign different components of a signed Torizon OS image with Secure Boot features enabled. The commands here require the signed Torizon OS image to be made available via the images command.
warning
$ torizoncore-builder secboot --help
usage: torizoncore-builder secboot [-h] {sign-bootloader-hab,sign-kernel} ...
options:
Commands:
sign-bootloader-hab
Sign bootloader components for images targeting devices based on NXP HAB.
sign-kernel Sign the kernel FIT image of an unpacked Torizon OS image.
secboot sign-bootloader-hab​
Sign the bootloader container for HABv4-compatible devices using NXP's Code Signing Tool (CST). Before proceeding, the user should ensure that the CST directory structure, including the required keys, certificates, SRK table, and e-fuse hash binary, has been set up according to the instructions in the Code-Signing Tool User's Guide available with NXP's documentation.
Usage​
$ torizoncore-builder secboot sign-bootloader-hab --help
usage: torizoncore-builder secboot sign-bootloader-hab [-h] --cst-dir CST_DIR
[--cst-crypto {rsa,ecdsa}]
[--cst-key-size CST_KEY_SIZE]
[--cst-key-exp CST_KEY_EXP]
[--cst-dig-algo {sha256}]
[--cst-srk-index {1,2,3,4}]
[--cst-srk-table CST_SRK_TABLE]
[--cst-srk-fuse CST_SRK_FUSE]
[--cst-srk-no-ca] [--kernel-key KERNEL_KEY]
[--kernel-key-dir KERNEL_KEY_DIR]
Sign bootloader components (SPL, DDR Firmware, U-Boot FIT image) for i.MX-based modules compatible
with HAB. The signing is performed using the Code Signing Tool (CST) from NXP. The CST directory
is specified with the --cst-dir argument. Keys and certificates (in PEM format, with the .pem
extension), SRK table and E-fuse hash binaries have to be generated beforehand by following the
NXP documentation.
options:
--cst-dir CST_DIR CST directory path.
Type of cryptographic keys being used. Allowed values: rsa, ecdsa.
(default: rsa)
Key length in bits if using RSA; for ECDSA this would be a string from the
generated certificate file name e.g. secp384r1 for
SRK1_sha256_secp384r1_v3_ca_crt.pem. (default: 2048)
Key exponent for RSA keys (only). (default: 65537)
Digest algorithm as entered into the CST tool. (default: sha256)
Index of the SRK table to be used for signing. Allowed values: 1, 2, 3, 4.
(default: 1)
SRK table binary filename in 'crts' inside the CST directory. (default:
SRK_1_2_3_4_table.bin)
SRK fuse binary filename in 'crts' inside the CST directory. (default:
SRK_1_2_3_4_fuse.bin)
--cst-srk-no-ca Enable this if the CA flag was *not* set when generating the SRK
certificates.
If specified, this switch causes the U-Boot DTB and its Control DTBs to be
updated with the specified (PUBLIC) key before signing the bootloader. The
string passed to the switch should have the form 'name=<NAME>;algo=<ALGO>'
where <NAME> is the key name and <ALGO> is a comma-separated pair of the
hashing and crypto algorithms used to sign the kernel (e.g.
'name=prod;algo=sha256,rsa2048'). If <ALGO> is not provided, it defaults
to 'sha256,rsa2048'.
Kernel key directory path. This directory must contain a certificate key
file named <NAME>.crt holding the PUBLIC key, and a PRIVATE key file named
<NAME>.key (both in PEM format), where <NAME> is specified through the
--kernel-key switch. (default: working directory)
Currently supported machines: <...>
secboot sign-kernel​
Sign the kernel FIT image using a user-provided private key. When a new key is used to sign the kernel, the bootloader (which is the previous component in the Chain of Trust) must be updated with the corresponding public key by running the secboot sign-bootloader-hab command.
The command secboot sign-kernel also allows updating the public key (stored inside the kernel FIT image) used to validate the next component in the Chain of Trust, that is, the root filesystem represented by an OSTree commit. For this update to occur, users must pass an OSTree key.
Usage​
$ torizoncore-builder secboot sign-kernel --help
usage: torizoncore-builder secboot sign-kernel [-h] --kernel-key KERNEL_KEY
options:
Kernel key information in the form 'name=<NAME>;algo=<ALGO>', where <NAME>
is the key name and <ALGO> is a comma-separated pair of the hashing and
crypto algorithms to be used for the signing process (e.g.
Kernel key directory path. This directory must contain a PRIVATE key file
named <NAME>.key in PEM format, where <NAME> is specified through the
If specified, this switch causes the ramdisk embedded in the kernel FIT
image to be updated with the PUBLIC key used for signing the root
filesystem (OSTree commit); this is done before the FIT image is signed.
The string passed to the switch should have the form
'name=<NAME>;algo=<ALGO>' where <NAME> is the key name and <ALGO>
corresponds to the signing algorithm (e.g. 'name=prod;algo=ed25519');
<ALGO> defaults to 'ed25519' if not provided.
OSTree key directory path. This directory must contain a PUBLIC key file
named <NAME>.pub, where <NAME> is specified through the --ostree-key
switch.
The splash Command​
Set a splash screen (image shown during boot) for the image. Refer to Splash Screen on Torizon OS for details.
Usage​
$ torizoncore-builder splash --help
usage: torizoncore-builder splash [-h] SPLASH_IMAGE
SPLASH_IMAGE Path and name of splash screen image (REQUIRED).
optional arguments:
NOTE: the switches --image and --work-dir have been removed.
The splash-config Command​
Manages the splash screen configuration for Torizon OS. This configuration controls aspects like the location of the splash screen image, or spinner. Refer to Splash Screen on Torizon OS for details.
Usage​
$ torizoncore-builder splash-config --help
usage: torizoncore-builder splash-config [-h] {set,dump} ...
optional arguments:
Commands:
{set,dump}
set Sets a new Plymouth configuration file as the new configuration.
dump Prints the current Plymouth configuration.
splash-config set​
Applies the provided file as the new splash screen configuration.
Usage​
$ torizoncore-builder splash-config set --help
usage: torizoncore-builder splash-config set [-h] SPLASH_CONFIG
SPLASH_CONFIG File path to the new configuration file.
optional arguments:
splash-config dump​
Outputs the currently active splash screen configuration to either standard output or a file.
Usage​
$ torizoncore-builder splash-config dump --help
usage: torizoncore-builder splash-config dump [-h] [--file OUTPUT_FILE] [--force]
optional arguments:
--file OUTPUT_FILE Writes current Plymouth configuration to the provided file name.
--force Overwrite file designated by '--file' (if it exists).
The dt Command - Device Tree Customization​
dt has subcommands to build and apply custom device trees to devices, whether the unpacked image is a Toradex Easy Installer image or a raw disk (.wic/.img) image. Refer to Device Tree Overlays on Torizon for details on usage.
 $ torizoncore-builder dt --help
usage: torizoncore-builder dt [-h] {status,checkout,apply} ...
Manage application of device trees.
optional arguments:
Commands::
status Show the current device tree
checkout Checkout the Toradex device tree and overlay repository
apply Compile and enable a device tree
dt checkout​
This command is deprecated
The dt checkout was a convenience wrapper for retrieving the Toradex device tree and overlays repository at https://github.com/toradex/device-trees.
This repository contains sources for common combinations of device trees and overlays compatible with Toradex SOMs and carrier boards. The repository is checked out in subdirectory device-trees in torizoncore-builder's working directory.
Usage​
$ torizoncore-builder dt checkout --help
Checkout Toradex device tree and overlays repository
optional arguments:
-h, --help show this help message and exit
--update Update device-trees repository (if existing)
If the --update switch is passed, the tool performs a git pull inside the device-trees directory if the directory already exists.
dt apply​
Compiles a device tree source file and, on success, stores the compiled device tree blob to be deployed as the current device tree of the deployed image (see the union and deploy commands).
A note for advanced users: the Torizon OS overrides the default value of the U-Boot environment variable fdtfile in a file named uEnv.txt, which is evaluated during U-Boot runtime. Therefore, if you read the value of fdtfile using a tool like U-Boot fw-utils or directly from the bootloader, you are not reading the value to which this variable evaluates; instead, you should check the contents of /boot/loader/uEnv.txt.
Usage​
$ torizoncore-builder dt apply --help
usage: torizoncore-builder dt apply [-h] [--include-dir DIR] DEVICE_TREE
DEVICE_TREE Path to the device tree source file
optional arguments:
--include-dir DIR Search directory for include files during device tree compilation.
Can be passed multiple times. If absent, defaults to 'device-trees/include'.
Example​
$ torizoncore-builder dt apply device-trees/dts-arm64/imx8qxp-colibri-aster.dts
/tmp/tmpiyorpx7w: Device Tree Blob version 17, size=120412, boot CPU=0, string block size=7360, DT structure block size=112996
Device tree imx8qxp-colibri-aster.dtb successfully applied.
dt status​
Shows the current device tree of the image, if any.
On some devices, the device tree is selected at boot time according to characteristics of the hardware. In such cases dt status does not show the enabled device tree.
Example​
$ torizoncore-builder dt status
Current device tree is: imx8qxp-colibri-aster.dtb
The dto Command - Device Tree Overlay Customization​
dto has subcommands to build and apply custom overlays to the current device tree, whether the unpacked image is a Toradex Easy Installer image or a raw disk (.wic/.img) image. Refer to Device Tree Overlays on Torizon for details on usage.
$ torizoncore-builder dto --help
usage: torizoncore-builder dto [-h] {apply,list,status,remove,deploy} ...
Manage device tree overlays
optional arguments:
Commands:
apply Apply a device tree overlay
list List the device tree overlays compatible with the current device tree
status List the applied device tree overlays
remove Remove a device tree overlay
deploy Deploy a device tree overlay in the device
dto apply​
Compiles a device tree overlay source file. On success, test if it's applicable against the current device tree (+ other previously applied overlays). On success, stores the compiled device tree overlay blob to be deployed as part of the set of overlays that are applied to the current device tree of the deployed image during boot.
Usage​
$ torizoncore-builder dto apply --help
usage: torizoncore-builder dto apply [-h] [--include-dir DIR] [--device-tree FILE] [--force] OVERLAY
Apply a further overlay to the current device tree.
OVERLAY Path to the overlay source file
optional arguments:
--include-dir DIR Search directory for include files during overlay compilation. Can be passed multiple times.
--device-tree FILE Test overlay application over this device tree blob instead of the current device tree.
--force Apply the overlay even on failure checking it against the current device tree.
Example​
$ torizoncore-builder dto apply device-trees/overlays/colibri-imx8x_dsihdmi_overlay.dts
/tmp/tmpfmxpe871: Device Tree Blob version 17, size=2323, boot CPU=0, string block size=275, DT structure block size=1992
Overlay 'device-trees/overlays/colibri-imx8x_dsihdmi_overlay.dts' compiles successfully.
/tmp/tmpp64__jp9: Device Tree Blob version 17, size=121434, boot CPU=0, string block size=7462, DT structure block size=113916
Overlay colibri-imx8x_dsihdmi_overlay.dtbo successfully applied.
dto list​
Scan subdirectory device-trees/overlays of TorizonCore Builder's working directory for overlay source files that are declared to be compatible to the current device tree.
Usage​
$ torizoncore-builder dto list --help
usage: torizoncore-builder dto list [-h] [--device-tree FILE]
List overlays compatible to the current device tree.
optional arguments:
--device-tree FILE Check for overlay compatibility against this device tree blob instead of the current device tree.
Example​
Overlays compatible with device tree imx8qxp-colibri-aster.dtb:
- device-trees/overlays/colibri-imx8x_ad7879_overlay.dts
- device-trees/overlays/colibri-imx8x_atmel-mxt_overlay.dts
- device-trees/overlays/colibri-imx8x_dsihdmi_overlay.dts
- device-trees/overlays/colibri-imx8x_parallel-rgb_overlay.dts
- device-trees/overlays/display-dpi-lt170410_overlay.dts
dto status​
Shows the applied device tree overlays to be deployed.
Usage​
 $ torizoncore-builder dto status --help
usage: torizoncore-builder dto status [-h]
List the applied overlays.
optional arguments:
Example​
Enabled overlays over device tree imx8qxp-colibri-aster.dtb:
- colibri-imx8x_dsihdmi_overlay.dtbo
- colibri-imx8x_atmel-mxt_overlay.dtbo
dto remove​
Remove a device tree overlay blob from the set of applied overlays.
Usage​
$ torizoncore-builder dto remove --help
usage: torizoncore-builder dto remove [-h] [--all] [OVERLAY]
Remove an overlay that is not yet deployed.
OVERLAY Name of the device tree overlay blob
optional arguments:
--all Remove all overlays instead.
Example​
$ torizoncore-builder dto remove colibri-imx8x_dsihdmi_overlay.dtbo
dto deploy​
warning
This command is deprecated. Use the build command instead.
Refer to the build command documentation for more information.
Deploy a device tree overlay in the device with a single command. This command downloads a Toradex Easy Installer image based on the running device, unpacks this image, applies the Device Tree overlay, creates a union branch, and deploys the image to the device.
Usage​
$ torizoncore-builder dto deploy --help
usage: torizoncore-builder dto deploy [-h] --remote-host REMOTE_HOST [--remote-username REMOTE_USERNAME] [--remote-password REMOTE_PASSWORD]
[--remote-port REMOTE_PORT] [--reboot] [--mdns-source MDNS_SOURCE] [--include-dir DIR]
[--force] [--device-tree FILE] [--clear] OVERLAY [OVERLAY ...]
[DEPRECATED] Deploy a device tree overlay in the device. This command is deprecated. Use the 'build' command instead.
For more information: https://developer.toradex.com/torizon/os-customization/torizoncore-builder-tool-commands-manual#the-build-command
OVERLAY Path to the device tree overlay source file(s)
optional arguments:
Name/IP of remote machine
--reboot Reboot device after deploying device tree overlay(s)
--include-dir DIR Search directory for include files during overlay compilation. Can be passed multiple times. If absent, defaults to 'device-trees/include'
--force Apply the overlay even on failure checking it against a device tree.
--device-tree FILE Test the overlay against an specific device tree.
--clear Remove all currently applied device tree overlays.
Example​
$ torizoncore-builder dto deploy --remote-host <Hostname/IP address of target board> --remote-username <User on target board> --remote-password <Password of user on target board> --remote-port <ssh port of the remote target machine> --force --reboot device-trees/overlays/display-lt161010_overlay.dts
Downloading image from: https://artifacts.toradex.com/artifactory/torizoncore-oe-prod-frankfurt/dunfell-5.x.y/release/1/verdin-imx8mm/torizon/torizon-core-docker/oedeploy/torizon-core-docker-verdin-imx8mm-Tezi_5.1.0+build.1.tar
The download may take some time. Please wait...
Download Complete!
Unpacking Toradex Easy Installer image.
Copying Toradex Easy Installer image.
Unpacking TorizonCore Toradex Easy Installer image.
Importing OSTree revision 8c514a595469283bb69603f2fa32395b5dbbc3d80a8f9d824dc661f1b68c4d82 from local repository...
0 metadata, 0 content objects imported; 0 bytes content written
Unpacked OSTree from Toradex Easy Installer image:
Commit checksum: 8c514a595469283bb69603f2fa32395b5dbbc3d80a8f9d824dc661f1b68c4d82
TorizonCore Version: 5.1.0+build.1
'device-trees' directory already exists
'display-lt161010_overlay.dts' compiles successfully.
warning: --force was used, bypassing checking overlays against the device tree.
Overlay display-lt161010_overlay.dtbo successfully applied.
Commit 40aec4200054c9865aa6e0b13acdeb9ed63ac5a91e9276800e4a22850f42d84b has been generated for changes and ready to be deployed.
Pulling OSTree with ref dto_deploy (checksum 40aec4200054c9865aa6e0b13acdeb9ed63ac5a91e9276800e4a22850f42d84b) from local archive repository...
Starting http server to serve OSTree.
Starting OSTree pull on the device...
Deploying new OSTree on the device...
Deploying successfully finished.
Device reboot initiated...
Images on Torizon Cloud - The platform Command​
The platform executes operations that interact with Torizon Cloud or a compatible server. The command has the following subcommands and options:
$ torizoncore-builder platform --help
usage: torizoncore-builder platform [-h] {lockbox,provisioning-data,push} ...
optional arguments:
Commands:
{lockbox,provisioning-data,push,static-delta}
lockbox Generate a Lockbox for secure offline updates, in a format ready to copy
to an SD Card or USB Stick.
provisioning-data Fetch provisioning data for secure updates.
push Push artifact to OTA server as a new update package.
static-delta Commands for managing static deltas on Torizon Cloud.
platform lockbox​
Generates a Lockbox by fetching the metadata from Torizon Cloud, creating a unique secure image for offline updates in a format ready to copy to an SD Card or USB Stick.
Usage​
$ torizoncore-builder platform lockbox --help
usage: torizoncore-builder platform lockbox [-h] --credentials CREDENTIALS [--force]
[--platform PLATFORM] [--login USERNAME PASSWORD]
[--dind-param DIND_PARAM] [--dind-env DIND_ENV]
LOCKBOX_NAME
LOCKBOX_NAME Name of the Lockbox (as defined at the OTA server)
optional arguments:
Relative path to credentials.zip.
--force Force program output (remove output directory before generating the
Lockbox image).
--platform PLATFORM Define platform to select when not specified in the compose file (can be
specified multiple times; default: linux/arm/v7, linux/arm64).
connecting to it).
Relative path to the output directory (default: update/). If parent
directories are passed such as in a/b/update/, they will be automatically
created.
After the Lockbox is generated, the output directory should be copied (and possibly renamed) to
the removable media used for the offline updates; the name of the directory in the media should be
in accordance with the update client (aktualizr) configuration.
For additional information regarding parameters --dind-param and --dind-env, please refer to the bundle command which has parameters with the same names and operation.
Example​
Creating a Lockbox​
After defining a Lockbox on the Torizon Cloud, run the command following:
$ torizoncore-builder platform lockbox my_lockbox_name --credentials credentials.zip
platform provisioning-data​
More information on what types of provisioning data exist is available on Production Programming in Torizon page.
Usage​
$ torizoncore-builder platform provisioning-data --help
usage: torizoncore-builder platform provisioning-data [-h] --credentials CREDENTIALS
[--online-data CLIENT_NAME] [--force]
optional arguments:
Destination archive for shared provisioning data; currently, this must
have the ".tar.gz" extension.
Client name for which online provisioning data will be obtained and
displayed; pass a value of DEFAULT (all capitals) to get the default
provisioning data from your credentials file.
--force Overwrite output file if it already exists.
Switch --shared-data is normally employed with "offline" provisioning mode while with "online"
provisioning both --shared-data and --online-data switches are commonly used together.
Example​
Offline Provisioning​
To get the data required for offline secure updates provisioning one can execute:
$ torizoncore-builder platform provisioning-data \
--credentials credentials.zip \
The tool generates file shared-data.tar.gz which can be used with the build command or with the images provision command.
Online Provisioning​
To get the data required for online secure updates provisioning one can execute:
In this case, the tool generates file shared-data.tar.gz and displays a base64 encoded string that can be used with the build command or with the images provision command.
At the moment, the only supported value for the argument to the switch --online-data is the string DEFAULT; in the future the argument represents the name of an API client as defined in the Platform web UI.
platform push​
The platform push command takes an OSTree reference (commit or branch) a Docker Compose file or generic package and uploads it to the Torizon Cloud server using the specified account credentials. Additionally, it adds the uploaded file to the list of packages available at the server-side so that the package could be assigned for deployment to devices using remote or offline updates.
Usage​
$ torizoncore-builder platform push --help
usage: torizoncore-builder platform push [-h] [--credentials CREDENTIALS] [--repo OSTREE] [--hardwareid HARDWAREIDS]
[--description DESCRIPTION] [--package-name TARGET] [--package-version VERSION]
[--compatible-with SHA256] [--canonicalize | --no-canonicalize]
[--login USERNAME PASSWORD] [--login-to REGISTRY USERNAME PASSWORD]
[--cacert-to REGISTRY CERTIFICATE] [--canonicalize-only] [--force] [--verbose]
REF
REF OSTree reference, docker-compose or generic package file to push to Torizon OTA.
optional arguments:
--repo OSTREE OSTree repository to push from.
Define the hardware ID which the package is compatible with; this can be specified multiple
times. Use only with OSTree and generic packages.
Add a description to the package
Package name for docker-compose or generic package file (default: name of file being pushed to OTA)
or OSTree reference (default: same as REF).
Package version for docker-compose or generic package file
(default: current date in the 'yyyy-mm-dd' format) or OSTree reference (default: OSTree subject).
Restrict an application package so it can only be installed with a compatible OS image.
OS image hash must be accessible in your Platforms account; Pass the string
'sha256=<hash>' as parameter to this switch; The switch can be used multiple times.
--canonicalize, --no-canonicalize
Generates a canonicalized version of the docker-compose file, changing its extension to
'.lock.yml' or '.lock.yaml' and pushing it to Torizon OTA; The package name is the name of
the generated file if no package name is provided.
Request that the tool logs in to registry REGISTRY using specified USERNAME and PASSWORD
Define a root CA CERTIFICATE (path to file in PEM format) to be used for validating the
certificate of the specified secure REGISTRY (when connecting to it).
--canonicalize-only Canonicalize the docker-compose.yml file but do not send it to OTA server.
--force Force removal of the canonicalized file if it already exists.
--verbose Show more output
--custom-meta CUSTOM_META
Custom Uptane metadata for the package.
Note: for a docker-compose file to be suitable for use with offline-updates it must be in canonical form; this can be achieved
by passing the '--canonicalize' switch to the program in which case the file will be translated into canonical form before being
uploaded to the server.
Example​
You can find the example and detailed instructions on how to use platform push at Signing and pushing the image to Torizon Cloud.
platform static-delta create​
Create and upload to Torizon Cloud a static delta (difference in the changed files) of an OS package update.
This approach helps distributing updates more efficiently by transmitting only the delta.
Usage​
$ platform static-delta create --help
usage: torizoncore-builder platform static-delta create [-h] --credentials
CREDENTIALS
FROM_HASH TO_HASH
FROM_HASH The OSTree commit to create a static delta from
TO_HASH The OSTree commit to create a static delta to
optional arguments:
Static delta generation pre-computes a binary diff between two specific OS
packages, making that particular upload path more efficient. You must specify
the 'from' and 'to' packages by their sha256 commit ID.
Example​
After uploading an OS package and a updated version of this package to the Torizon Cloud, get the HASH of the old and new versions.
$ torizoncore-builder platform static-delta --credentials credentials.zip FROM_HASH TO_HASH
The push Command​
warning
The push command is deprecated and is removed in an upcoming major release of TorizonCore Builder. Please use platform push instead.
Setting Attributes to Files and Directories Using the ".tcattr" File​
When using --changes-directory (or --extra-changes-directory in older versions of the tool), you can create a ".tcattr" file which sets the attributes for files and directories in the OSTree filesystem. Basically, you just have to provide the permissions and ownership for files and directories that you want to be set in your final Torizon OS image. The .tcattr file uses the Linux utility getfacl format, so you can learn more about that format by reading the man getfacl.
Example of Creating a ".tcattr" File for an Additional Changes Directory​
To set attributes for files and directories under /usr/dir1 in your final image or OSTree rootfs of Torizon OS, you should create, in your host machine, the directory ./extra/usr. Inside that directory, you can have whatever files and or directories you like. For each file and directory, you must create entries in the ./extra/.tcattr file with the desired attributes.
For example, imagine that you want the directory usr/dir1 in your ./extra changes directory to have user id 1000, group id 1000 and that only the owner of this directory has execute, read and write permissions. So, you should create an entry in the ./extra/.tcattr file for that directory using the following steps:
$ cd extra/
$ mkdir -p usr/dir1
$ chown 1000.1000 usr/dir1
$ chmod 700 usr/dir1
$ getfacl -n usr/dir1 >> .tcattr
You should end up with a ".tcattr" file with the content:
./extra/.tcattr
# file: usr/dir1
# owner: 1000
# group: 1000
user::rwx
group::---
other::---
If you want to set more attributes for other files, you just need to follow the same logic and add more entries to the .tcattr file. For example, if you want a ./extra/usr/dir1/file1 having user id 1000, group id 2000 and only read and write execution permissions for the owner and the group of this file but no permissions at all for the others, you can do the following:
$ cd extra/
$ touch usr/dir1/file1
$ chown 1000.2000 usr/dir1/file1
$ chmod 660 usr/dir1/file1
$ getfacl -n usr/dir1/file1 >> .tcattr
And after these two changes, you should have an ./extra/.tcattr file, in your host machine, with the following content:
./extra/.tcattr
# file: usr/dir1
# owner: 1000
# group: 1000
user::rwx
group::---
other::---
# file: usr/dir1/file1
# owner: 1000
# group: 2000
user::rw-
group::rw-
other::---
Files and directories not explicitly listed in the ".tcattr" file are set with default attributes: regular files (user id root, group id root, and 660 permissions) - executable files (user id root, group id root, and 0770 permissions) - directories (user id root, group id root, and 755 permissions).
All .tcattr files are not committed to the OSTree rootfs, so they do not exist in your final Torizon OS image or OSTree filesystem.
Reference Command Application​
Here are simplified customization examples with TorizonCore Builder commands for quick reference.
Please refer to the following specific articles for additional resources:
Build Custom Images with build Command​
Create a Configuration File​
$ torizoncore-builder build [--file NAME] --create-template
tcbuild.yaml
# Configuration file outline:
input:
customization:
output:
Before running the build command, it is necessary to have all the input artifacts, according to the desired customizations. This includes:
  • A splash screen image.
  • The source code of the device tree and the device tree overlays.
  • The source code of the external kernel modules.
  • The file with the configuration changes captured from the device.
  • The Docker Compose (YAML) configuration file of the application container or the directory with the container images.
  • The Easy Installer image tarball of Torizon from Toradex (depending on the input mode) that can be obtained in the Toradex Download Links article.
You can be easily obtain the configuration changes files with the isolate command:
$ torizoncore-builder isolate --remote-host <board-ip-address> --remote-username <board-ip-user> --remote-password <board-ip-password> --changes-directory <changes-directory>
Customize the Configuration File​
Below is an example file that:
  • As input, specifies:
    • a locally downloaded tarball of a Toradex Easy Installer image
  • As customizations, applies:
    • a splash screen
    • a specific device tree
    • a display overlay
    • a directory containing configuration changes captured from the device
  • As output, specifies:
    • a docker-compose.yml file to bundle into the generated Toradex Easy Installer image
    • the directory name where the generated Toradex Easy Installer image with the containers and customizations is stored
    • the parameters defining the OSTree commit for the custom image
tcbuild.yaml
input:
easy-installer:
local: torizon-core-docker-colibri-imx6-Tezi_5.3.0+build.7.tar
customization:
splash-screen: splash.png
filesystem:
- changes/
device-tree:
include-dirs:
- linux/include/
overlays:
add:
- device-trees/overlays/colibri-imx6_lcd-edt7_overlay.dts
output:
ostree:
branch: "test-release-1"
commit-subject: "Test Release 1"
commit-body: "This is the first test release for my great product"
easy-installer:
bundle:
compose-file: docker-compose.yml
username: "docker_hub_username"
password: "docker_hub_password"
Note that as a best practice, Toradex suggests you use Variable Substitution to provide the container registry credentials rather than placing them in the file in clear text.
Build the Image​
To build this custom Toradex Easy Installer image of Torizon from this configuration file, simply execute the build command.
$ torizoncore-builder build --file tcbuild.yaml
As tcbuild.yaml is the default name, the --file argument is not required in this case and is just included here for demonstration purposes.
Deploy the Image​
Follow the steps from the Build Custom Torizon OS Images article
Customize Using Standalone Commands​
Download and Unpack the Base Torizon OS Image​
There are two different ways to obtain an unpacked image of Torizon from Toradex.
For the first way, it is necessary an Easy Installer image tarball of Torizon from Toradex (depending on the input mode), that can be obtained in the Toradex Download Links article.
After downloading this image, unpack it with the images unpack command. As TorizonCore Builder is a container, it is unpacked in a Docker volume that is later used by the customization and deployment commands without the need of passing it.
$ torizoncore-builder images unpack torizon-core-docker-colibri-imx6-Tezi_7.4.0+build.28.tar
Another way to obtain this unpacked image is with the images download command. This command connects to the board and downloads the appropriate Easy Installer image of Torizon from Toradex, unpacking the image in the same way as the images unpack command after the download. In this way, instead of passing the image tarball, the arguments passed are the device's IP address, username, and password.
$ torizoncore-builder images download --remote-host <board-ip-address> --remote-username <board-ip-username> --remote-password <board-ip-password>
Differently from the build command, unless you want to change the version of Torizon or the directory with the unpacked image after you unpack the image once, it is not necessary to run these steps again. Making a different custom image from the same base image can be done without executing this step again.
Before applying the customizations to the custom Torizon OS image, it is necessary to have all the input artifacts according to the desired customizations. This includes:
  • The Easy Installer image tarball of Torizon from Toradex (depending on the input mode) that can be obtained in the Toradex Download Links (Torizon, Linux BSP, WinCE and Partner Demos) article.
  • The directory with the container images.
The container images can be generated from the Docker Compose configuration file with the bundle command.
$ torizoncore-builder bundle docker-compose.yml --bundle-directory bundle
Apply the Customizations​
TorizonCore Builder has standalone commands for each desired customization.
To generate the image exemplified in the approach using the build command with the same customizations, one should run the following commands:
  • Run the splash command to apply the splash-screen.
  • Run the dt apply command to compile the device tree and store the generated device tree blob.
$ torizoncore-builder dt apply --include-dir linux/include/ device-trees/dts-arm32/imx6dl-colibri-eval-v3.dts
  • Run the dto apply command to compile the device tree overlay (of the display in this example) and store the generated device tree overlay blob.
$ torizoncore-builder dto apply --include-dir linux/include/ device-trees/overlays/display-edt7_overlay.dts
Merge the Customizations into the Image​
The union command them merges all these customizations generated by the isolate, splash, kernel, dt, and dto commands. It generates a custom image of Torizon with all these customizations included.
$ torizoncore-builder union custom-branch --changes-directory changes
Combine With Containers​
First, the custom image generated with the union command needs to be deployed into an output directory with the deploy command. This output directory contains a Custom Easy Installer image of Torizon without containers.
After this, combine this custom image with the container images generated with the bundle command as explained in the preceding section. This is done using the combine command. The second argument passed on the command refers to the IMAGE_DIRECTORY, and the third argument refers to the OUTPUT_DIRECTORY.
$ torizoncore-builder combine --bundle-directory bundle torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM-WITHOUT-CONTAINERS torizon-core-docker-colibri-imx6-Tezi_5.3.0.CUSTOM-WTIH-CONTAINERS
Deploy the Image​
